Fitting 40hp and later flywheel on 36hp crank and case?
GüteAndTite
Early Convertible Güru
GüteAndTite is offline
PostPosted: Mon Jun 27, 2011 9:00 pm    Post subject: Fitting 40hp and later flywheel on 36hp crank and case? Reply with quote
what special flywheel do i need , or what maching/welding needs to be done to mount a 40hp flywheel to a 36hp motor?
i have a very specific reason for doing this- fitting a 61-67 saxomat clutch system to my 58's 36hp motor. the trans, throw out, pressure plate, and clutch disc all will work, as will the flywheel gland nut, but i need to know what to do to the flywheel to fit it up. and no- i dont want to just throw in a 40hp motor
Official 58-60 "Early Big Window" Convertible Thread & Registry
http://www.thesamba.com/vw/forum/viewtopic.php?t=426481
F&S Saxomat Automatic Clutch System Thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=462533
61-67 Delanair Air conditioning Thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=457944&highlight=air+conditioning
PUNCTUATION CHANGES THE WORLD: "I need to help my uncle, Jack, off a horse" is way better than, "I need to help my uncle jack off a horse"
Braukuche
Braukuche is offline
PostPosted: Tue Jun 28, 2011 6:43 am    Post subject: Re: fitting 40hp and later flywheel on 36hp crank and case?? Reply with quote
The holes in the flywheel for the dowels are smaller on a 36hp.
Go Reds! Smash state!
Retirement is here!
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
1989 Westfalia
slalombuggy
slalombuggy is offline
PostPosted: Tue Jun 28, 2011 7:26 am    Post subject: Reply with quote
Some of the landspeed guys cut the centers out of the 36 horse flywheel and have them machined and welded into the centers of later model flywheels and spin them at ungodly rpms (for a 36er). Would something like this work for you?
brad
Snort
Snort is offline
PostPosted: Tue Jun 28, 2011 7:48 am    Post subject: Reply with quote
36hp flywheel is about 12.5mm shorter than 40hp when you set them flat side-by-side. Part of it is the length of the flywheel seal collar, part of it is in the main casting. The crank end diameter is smaller diameter, and the the flywheel seal collar is smaller diameter. Crank pins smaller as noted above as well.
Would it be possible to rework a 36hp flywheel to fit the saxomat clutch instead?
GüteAndTite
PostPosted: Tue Jun 28, 2011 9:16 am    Post subject: Re: fitting 40hp and later flywheel on 36hp crank and case?? Reply with quote
Yes small pins and they are closer
Together in their Arrangement-
Also their is not oring
GüteAndTite
PostPosted: Tue Jun 28, 2011 9:18 am    Post subject: Reply with quote
brad
This sounds like it may be very feasible! Are there any threads written about this swapping of the center of a 36hp flywheel into. 40hp flywheel?
GüteAndTite
PostPosted: Tue Jun 28, 2011 9:23 am    Post subject: Reply with quote
it's not a matter of that as the flywheel for the saxomat is different than a regular flywheel. I'll have to rework this
Specific flywheel to fit on the 36hp crank.
GüteAndTite
PostPosted: Tue Jun 28, 2011 9:32 am    Post subject: Reply with quote
Here's some saxomat specific flywheel pics and diagrams- notice in the diagrams the part of the flywheel that bolts to the crank is split from the portion with the ring gear and is bolted to this as well
36hplandspeedracer
36hplandspeedracer is offline
PostPosted: Tue Jun 28, 2011 1:10 pm    Post subject: Reply with quote
Referencing Brads suggestion, contact Art Thraen at A.C.E.(Air Cooled Engineering) at the address below to find out if he can duplicate the Blackline Boys flywheel mods with your Saxo-Mat flywheel.
[email protected]
Good luck! A 36hp AutoStick. Way kool....................
Burly
GüteAndTite
PostPosted: Tue Jun 28, 2011 1:25 pm    Post subject: Reply with quote
[email protected]
Burly
not a 36hp auto stick. autostick isnt the same as saxomat
autostick is a 3 speed trans with torque converter
saxomat is a stock 4 speed trans, with a special double clutch/flywheel system. read more here: http://www.thesamba.com/vw/forum/viewtopic.php?t=462533&highlight=
a 36hp vintage speed motor saxomat- bitchin cool!
This message is German Dog approved!
36hplandspeedracer
PostPosted: Tue Jun 28, 2011 1:54 pm    Post subject: Reply with quote
Danke!
bally
bally is offline
PostPosted: Tue Jun 28, 2011 2:32 pm    Post subject: Reply with quote
Any thoughts on the modifications needed to fit a Saxomat flywheel to a 30 horse crank though?
Cheers,
Dave
earthquake
earthquake is offline
PostPosted: Tue Jun 28, 2011 3:44 pm    Post subject: Reply with quote
guteandtite
Can you use some thing like this and make it work?
http://aapistons.com/index.php?main_page=product_info&cPath=5&products_id=87
Casey
74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison]
Mr. Motorhead
Mad Scientist
Mr. Motorhead is offline
PostPosted: Tue Jun 28, 2011 7:21 pm    Post subject: Reply with quote
That -used- to be a 1600 flywheel, it now fits 36hp and Porsche. Jose at DPR can weld and remachine the hub center for 36hp either 8 or 4 dowel. The process is just a bit spendy, but it works well.
30 years experience in the sales of new and used auto parts!
36 horsepower parts for sale at http://www.aircooledresearch.com/
Or the new site at http://www.bugparts.com
Check out the Bonneville project:
http://aircooledresearch.com/docs/thebonnevilleproject.html#
"All limitations are self imposed."
Some Chinese guy
bally
bally is offline
PostPosted: Tue Jun 28, 2011 11:19 pm    Post subject: Reply with quote
When you say he welds and re-machines the hub centre do you mean he adds weld to it and then machines it or does he weld a different centre (from a 30 horse flywheel) in then machines it?
Dave
GüteAndTite
PostPosted: Wed Jun 29, 2011 12:07 am    Post subject: Reply with quote
earthquake wrote:
guteandtite
Casey
i cant just use a regular flywheel-, maybe for the center, but im guessing welding and maching will need to be done.
i will either have to rework this saxomat flywheel to fit the 36hp crank, or give up on 36hp (not an option) and run a 40hp motor. again not an option. so some way or another the saxomat flywheel will have to be modified.
bally
bally is offline
PostPosted: Wed Jun 29, 2011 3:50 am    Post subject: Reply with quote
I'm going to take my 36 horse flywheel along to the engineers who are refurbishing my Saxomat on Friday so we can look at the differences and find a solution. It's been suggested (by someone else in the know) it might be as simple as drilling a couple of holes but that depends how things line up and how much meat is left in the system.
I've also been told you really should consider a later full syncro box for yours as double declutching with a Saxomat is nigh on impossible.
Having said that, you're as stubborn as me so you'll probably find a way of doing it Smile My original box is long gone so I already have a later early 60s box in place.
blacklineracing
blacklineracing is offline
PostPosted: Wed Jun 29, 2011 8:05 am    Post subject: Reply with quote
We sent our flywheel to Jose at DPR. He has done this for a lot of other people too. He is great to work with and knows what he is talking about. Air cooled engineering did not make our flywheel.
Colton McAllister
BlackLine Racing Team
36hplandspeedracer
PostPosted: Wed Jun 29, 2011 10:25 am    Post subject: Reply with quote
Mr Guten..................
Saxomat Service Manual Flywheel Photo
Just dissassemble the flywheel/clutch assembly until you have item #3(the flywheel), in your parts diagram and my photo breakdown above, and send it along with a 36hp flywheel with a good center section locating dowel holes to DPR as Matt suggested and they can "blend" the two together by removing the 40hp section and install the 36hp section and balance the "new" 36hp Saxomat flywheel for you.
I noticed your Service Manual info and diagrams are in German. If you need that same info in English, just let me know and I will scan it from my 1960-68 dealer manual and send it your way.
Burly
GüteAndTite
PostPosted: Wed Jun 29, 2011 12:05 pm    Post subject: Reply with quote
Burly
That would be great- I'll post it all in a saxomat info thread i started so it can benefit all on the samba! Thanks- Bret
