Installing double thrust cam bearings - please help
garryv84
garryv84 is offline
PostPosted: Thu Aug 30, 2012 1:00 pm    Post subject: Installing double thrust cam bearings - please help Reply with quote
I have searched and cant find a clear answer.
When installing double thrust cam bearings in a 2.1 case that had single thrust bearing installed, one halve of the case has space for the bearing tang, while the other does not.
Do I have to cut a tang space in the other side of the case? Both of my new Mahle bearings have tangs on them.
Thanks.
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Thu Aug 30, 2012 1:38 pm    Post subject: Reply with quote
You only need one tang to secure the bearing. It was that way on Bug engines as well. I just carefully file off the tang on one of the two shell halves.
Pascal
Pascal is offline
PostPosted: Thu Aug 30, 2012 6:08 pm    Post subject: Reply with quote
That is interesting, my new KS double thrust bearing have no tangs at all, neither did the original KS double thrust that I took out of the engine. I know I'm not answering your question but you tweaked my interest so I has to go check. Also my 2.1 case has the notch for the tang on only one side, like yours.
'84 Westy - 2.2wbx, GT Torque-Biasing Differential
'91 EA Cabby
