SWbySWesty Samba Member
Joined: July 01, 2010 Posts: 327 Location: Adventureville, CA
Posted: Fri Aug 26, 2011 1:18 pm Post subject: Karma - Part it forward |
So the point of this thread is to get karma by giving things away that you don't need. Generally van related or connected.
(Moderator edit)
Here's how this thread works:
1) Post a list of parts you would like to give away for free (or for cost of shipping).
2) If you want any of the listed parts, send the "seller" a PM (private message).
3) Once you've parted-it-forward, please edit your post with GONE! at the top; if you have multiple items, place a GONE!=> in front of the part(s) you've karma'd. If it's too late to edit your post, please PM a moderator and s/he will do it for you.
Please keep pointless banter out of this thread, this includes "thanks!" replies. Any posts not listing parts up for grabs will be removed.
If you see something you want, but the seller won't ship, go to this topic to find someone who's willing to drive it to you:
https://www.thesamba.com/vw/forum/viewtopic.php?t=693686 .
Thread purged:
Nov. 3, 2012
June 2, 2013
April 3, 2015
March 6, 2018
October 16, 2022
July 30, 2023
(/moderator edit)
Karma idea:
*You may NOT receive an item and then sell it. Use it, give it back, or karma it again. Don't be that guy.
**You may NOT request any items. Either it comes up or it doesn't.
***Post your location; first come, first served.
GONE!
I have a 1986 stock chrome w/ black rubber rear bumper. Great condition. Includes end caps (one slightly busted). Sitting in the back yard with nothing to do. Who wants it?
I'm in Marina del Rey, CA. Come get it or parts train it somewhere. _________________ 1986 Westy - Billie Jean
A Westy with a Jeep heart (Pura Vida)
www.theadventurebrigade.blogspot.com - Latest update: Johnson Valley - Nov 22, 2011
buelteman Samba Member
Joined: November 25, 2009 Posts: 26 Location: Montara
Posted: Sun Feb 20, 2022 11:41 am Post subject: Re: Karma - Part it forward |
I have parts in a milk crate in my driveway on the coast in Montara California ready for the first lucky Vanagon owner to pick up! To wit:
1 - Blue Sea Automatic Charging Relay for your non Li-Ion battery, which works great and has served me well. Just intalled solar panels and new relay so this is surplus
1 - One Odyssey Extreme Battery (CCA: 810, PHCA: 1550) from the above mentioned setup. Used, but has held a 12.42 volt charge over the 18 months since I removed it without recharging. Case was carved with Dremel to perfectly fit second battery box behind driver's seat so lid can close.
3 - 2-plastic vanagon seat slider bushings for front seats, disused due to addition of Town and Country front seats from Small Car
4 - Bug Screen for front free air inlet, disused when I installed flapper control
5 - For bottom Cabinet below sink: Original riser that lifts base of front cabinet above sink drain along with nice vertical paper towel dowel and base.
6 - One 750 Watt DC to AC Power Inverter by Vector. Wheezes a bit when turns on due to a cooling fam bearing, but silences after restart. 1500 watt peak output. _________________ '91 Westfalia Camper - VW BNB
1.8 Turbo courtesy Stephan's
Custom Geared 5-speed tranny with
Peloquin Limited Slip Diff
H&R Progressive Rate Springs
300 Watt 13 speaker stereo
Audi Disc Brakes
LED driving and interior lights
the_benjamin_effect Samba Member
Joined: May 31, 2010 Posts: 345 Location: Gateway to the North Cascades, Washington State
Posted: Mon Feb 21, 2022 6:05 pm Post subject: Re: Karma - Part it forward |
Free for pickup. Clamshell and associated hardware. Its from my stock 1987 SYNCRO FWIW. Photo is from TS gallery, but you get the point. mine was working perfectly, normal wear as seen in photo. Just installed the GW skid plate and rear spare mount.
I'm in Sedro Woolley (Burlington) Washington.
Also, still trying to get rid of this (also free):
Let me know.
Benjamin _________________ -1967 Sundial Camper 1914cc "Sunny"
-1978 Deluxe Westfalia Jake Raby built PowerStroke 2109cc "Westy"
-1987 SYNCRO Westfalia GoWesty 2400cc "Ruby"
-2000 Subaru Impreza Sport EJ22 ¼ million miles "Trusty"
International Association of Machinists and Aerospace Workers. I.A.M. 751
International Brotherhood of Naval Flight Engineers. I.B.N.F.E. LOCAL 8251
U.S. NAVY Retired; Senior Chief Flight Engineer, P-3 Orion and EP-3E Aries II
U.S.S. Carl Vinson, VFA-22, VQ-2, VQ-1, VP-30 |
DuncanS Samba Member
Posted: Thu Feb 24, 2022 9:00 am Post subject: Re: Karma - Part it forward |
Will ship if you pay postage. Will be recycled by March 10th.
PM me if interested.
Duncan |
MootPoint Samba Member
Joined: September 16, 2006 Posts: 862 Location: ABQ, NM
Posted: Sun Mar 13, 2022 10:58 am Post subject: 84 Vanagon Fuel Sensor |
Fuel sensor, worked well when I removed it when cleaning and replumbing tank. Since the tank was out, I replaced it with a new sensor, but this one works. You will probably need a new o-ring. Whatever you feel would be fair postage to wherever you are.
_________________ 1984 Westy with tencentlife power! |
Californio Samba Member
Posted: Mon Mar 28, 2022 2:20 pm Post subject: Re: Karma - Part it forward |
I have front door interior and sliding door panels to give away, not perfect otherwise I wouldn't have replaced them, but useable as is or could be straightened. Grey, 1987 Syncro, electric windows. The original map pocket is there but cracked...could be repaired...
Pick up in Mendocino, CA, or possibly on one of my trips to East Bay area. PM if interested. |
revolution337 Samba Member
Joined: May 23, 2009 Posts: 400 Location: Pennsylvania
Posted: Tue Apr 05, 2022 6:20 pm Post subject: Re: Karma - Part it forward |
Free Spectra fuel tank VW3B, with the large filler neck opening and 7mm fuel outlet (for early vans)
https://ecat.spectrapremium.com/en/parts/VW3B
I purchased this a few months back and leak tested it prior to installation into my van. It was during this that I found out it was leaking from the seam along the rear of the tank. ( see this thread https://www.thesamba.com/vw/forum/viewtopic.php?t=764974 )
I reached out to Amazon and they refunded me for the tank, however they did not request to the have tank sent back to them. They simply told me to "dispose of it however I wish". I figured I would offer it up here for free before I take it to the scrap yard. Maybe someone who is more ambitious (see: cheap) than I can try and repair it and have a good new tank for free. Some of the poorly applied silver paint is also peeling off already
FYI this tank has NOT been filled with gasoline at all. I simply used an EVAP smoke machine to leak test it. In case you were thinking of trying to weld it, it should be safe to do so (insert legal disclaimer here)
Due to obvious large size, local pickup only (central PA)
Shot of where it is leaking from.
_________________ 1982 Westfalia AEB 1.8t
2017 VW Golf Sportwagen
2001 Audi A4 4.2 V8 swapped
2000 BMW Z3 roadster
-Mark |
nvaaron Samba Member
Joined: August 26, 2021 Posts: 26 Location: Northern Virginia
Posted: Mon Apr 11, 2022 7:10 pm Post subject: Re: Karma - Part it forward |
Free JVC CD Player from around 1998. Removable faceplate. Works fine. I upgraded to bluetooth. You pay shipping.
teej Samba Member
Joined: November 26, 2010 Posts: 908 Location: Seattle
Posted: Tue Apr 12, 2022 9:48 am Post subject: Re: Karma - Part it forward |
A bunch of stuff, free pickup in N Seattle area:
pair of VW heads, no obvious cracks between valves
GONE! Set of used Kolbenschmidt 94.5mm piston and cylinders, pulled from VW of Canada rebuild that ran for about 50k miles. Thought I would use to build up a WBX but never did.
GONE! Coolant bottle w/ Blau cap, spare cap, level sensor, spare sensor.
GONE! Brown dash vents from 86, not perfect but they work okay.
4 chrome hubcaps for 14" VW steel wheels, fair condition
used 21mm antisway bar, end links, and powerflex bushings for same
_________________ 1986+ Wolfsburg Weekender Pop-Top 2.3 WBX Manual Trans
Jennybenny Samba Member
Posted: Thu Jun 16, 2022 5:35 pm Post subject: Re: Karma - Part it forward |
Set of repro side mirrors from Bus Depot. Convex so you see more but objects are way closer than they appear. Used a couple of months but replaced with the land rover mirrors.
Stock tow hitch with hardware. Good used condition.
Stock replacement a/c receiver / dryer. Acm Germany 944 573 143 00
Pick-up in Brooklyn NY. Or for those in upstate NY, I’ll be in the Adirondack’s late July / early August so could meet up somewhere. |
mugford Samba Member
Posted: Wed Jun 22, 2022 1:57 pm Post subject: Desert camo curtain set |
As pictured. You can mount them with an elastic string along the top & bottom or use hooks on a sliding rail.
Bainbridge Island WA
xoo00oox Samba Member
Joined: February 11, 2010 Posts: 2734 Location: East Nassau, NY
Posted: Thu Jun 23, 2022 11:14 am Post subject: Re: Karma - Part it forward |
FREE!. Complete Dometic refrigerator except for the propane jet. It was in good working order when removed. I just put it on my dumpster. Come and get it quick! I will not ship it.
EDIT- It is now also missing the sparker |
space Samba Member
Posted: Fri Jun 24, 2022 3:12 pm Post subject: Re: Karma - Part it forward |
I have some rear drum brake parts for an 82 (rears converted to discs)
springs, cylinders etc
Let me know what you need
T _________________ 82 westy
w:
2.5 JDM Subie
Rear discs |
UngaWunga Samba Member
Posted: Sat Sep 03, 2022 3:00 pm Post subject: Re: Karma - Part it forward |
Need a brake caliper for a big brake upgrade? No carrier, but you can order those cheap from RockAuto and modify to suit. Two piston Girling caliper from an early 90s Audi used in the big brake kits. Pick up only. I can point you to the other Audi parts you'll need. Please only pick this up if you'll use it. Located in southern NH.
Never used, still in box.
Like these: https://www.rockauto.com/en/catalog/audi,1992,v8,4.2l+v8,1009459,brake+&+wheel+hub,caliper,1704
Posted: Tue Sep 06, 2022 4:58 pm Post subject: Re: Karma - Part it forward |
Free stock Dometic fridge. Worked well on 120v as well as 12v. Also worked well running on propane, once I got it started (which was finicky at times). Not sure why the photo uploaded sideways, but you know what it looks like. No shipping, pick up only in Central PA area.
-Mark |
VicVan  Samba Member
Joined: July 01, 2015 Posts: 2001 Location: Vancouver Island, BC
Posted: Mon Sep 19, 2022 4:42 pm Post subject: Re: Karma - Part it forward |
Not the best gift, but an old starter from a 2.1 WBX auto. It stopped working, I believe it was a stuck solenoid, but not sure anymore...
Works as a core though...
Local pick up in Victoria, BC (Vic West area).
_________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
indianpeaksjoe  Samba Member
Posted: Tue Sep 20, 2022 7:34 pm Post subject: Re: Karma - Part it forward |
I’ve got this rear cushion with what I think are cutouts for a/c. Free to anyone who wants to pick it up in Moab.
Mateo83 Samba Member
Joined: September 14, 2021 Posts: 647 Location: Lodi, CA
Posted: Fri Sep 23, 2022 8:59 am Post subject: Re: Karma - Part it forward |
Going through my parts shelf, let me know if anyone wants these:
Headrests
armrests for door cards
front Lowering coils
stock coils & shocks
4" kicker speakers for doors
AC - TEMP control plates. Brown & Black _________________ 83 Air-cooled 2.0 Tin Top |
uberaudi Samba Member
Joined: June 24, 2013 Posts: 660 Location: Hi-top Country
Posted: Sun Sep 25, 2022 9:25 pm Post subject: Re: Karma - Part it forward |
Anyone need a Terrawagen 2wd partial flare?
A Terrawagen kit comes with options for both 2wd and 4 (2wd having the cutout for the fuel filler), so this is left over.
_________________ '84 Adventurewagen 1Z TDI, '08 Audi Avant Quattro 6spd BHW TDI |
Another_VW Samba Member
Joined: October 08, 2022 Posts: 1 Location: South Florida
Posted: Sun Oct 16, 2022 4:39 pm Post subject: Re: Karma - Part it forward |
| xoo00oox wrote: |
FREE! 1 pair of very lightly used 7" LED headlights. I used these only for about a month, didn't like them. Will not ship, pick up only!
Have you changed your mind on the shipping, I’m interested |
