Mikesarge Samba Member
Posted: Thu Sep 23, 2021 6:09 pm Post subject: OBD1 2.2 to OBD2 2.5 Subaru swap - anyone done it? |
So, in my quest for ever more mid-range torque, I’ve come to a couple of conclusions regarding my early ej22.
1- I can cobble together a turbo kit for this with stuff I have sitting around. It’ll sound cool, probably be pretty torquey, but reliability will become an issue. Not ideal.
2- I can frankenmotor this thing. Not a perfect solution either, as it’s still a shade tree hacky sort of solution, and it seems like the power is higher up in the revs for these too. I need torque in the middle!
3- I can swap in a later, more powerful dual port engine and harness, reusing all of the hardware currently on this thing.
3 seems like the best solution, but for the fact that I bought this with the swap, and all of the guides for wiring are for adapting a stock harness to a subaru, not for updating the Subaru setup.
Has anyone done this? Can you provide me some guidance, and prevent me from turbocharging my current setup? _________________ 1986 Syncro westfauxlia EJ-frankenmotor
1980 911 SC 3.1 |
Joined: January 01, 2007 Posts: 17839 Location: sticksville, ct.
Posted: Thu Sep 23, 2021 6:37 pm Post subject: Re: OBD1 2.2 to OBD2 2.5 Subaru swap - anyone done it? |
the only thing you may have to change other then the harness is the exhaust (single port vs dual)
i'd go 2.5 with a set of cams. would be the most bang for the buck
i built my 70 deluxe with a frankenmotor and cams. pulls like a ox on meth. but, it was a pain to build. heads CC'd to drop compression, custom head gaskets etc and it's running the 2.2 management which is fine, except for the million dollar coolant fed IAC valve.
i think you'd be money ahead with the 2.5 and some cams. _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Silverghost500 Samba Member
Joined: August 01, 2018 Posts: 1198 Location: Atlanta, GA
Posted: Sat Sep 25, 2021 9:24 am Post subject: Re: OBD1 2.2 to OBD2 2.5 Subaru swap - anyone done it? |
@skills, what cams are you running in your 2.5's? _________________ 1986 Volkswagen Vanagon Westfalia "Von Westy"
Honda K24A conversion
3-Speed Automatic
Von Westy YouTube Channel
https://www.youtube.com/channel/UCbhyZYxJEQrUuLnMbLleeIA |
