no M-Plate?
sweetbus
sweetbus is offline
PostPosted: Mon Feb 11, 2002 3:18 pm    Post subject: no M-Plate? Reply with quote
I just got a split bus off ebay,It was a really cheap price and not too much rust. But no title and I just went out to look at the m-codes and the plates are gone, all thats there is the color tag . L360 and L289.
Any clue on how i can get info on it?, even the year would be helpful.
Thanx
roy
roy is offline
PostPosted: Mon Feb 11, 2002 3:34 pm    Post subject: no M-Plate? Reply with quote
What year is your bus?
roy
roy is offline
PostPosted: Mon Feb 11, 2002 3:42 pm    Post subject: no M-Plate? Reply with quote
Also, look at the fresh air vent on the passenger side. you should have a plate up there that will tell you the vin number...that in turn will tell what year you have
sweetbus
sweetbus is offline
PostPosted: Mon Feb 11, 2002 4:37 pm    Post subject: no M-Plate? Reply with quote
Great I found that now this is the # 255108409 now what does this tell me?
sweetbus
sweetbus is offline
PostPosted: Mon Feb 11, 2002 7:29 pm    Post subject: no M-Plate? Reply with quote
I wish that was what i had.... but it not a delux nor a walk through:(
but I will try the birth certificate
thanx
roy
roy is offline
PostPosted: Tue Feb 12, 2002 8:38 am    Post subject: no M-Plate? Reply with quote
Sweetbus, your bus is a '65. the 2nd 5 in the vin number indicates the year. I think the first 2 digits indicate something also, such as the model?. the rest of the numbers are part of the vin number.
roy
roy is offline
PostPosted: Tue Feb 12, 2002 3:41 pm    Post subject: no M-Plate? Reply with quote
Where do you get feb from?
I don't think you can tell what month a bus was made without the m-code plate. the vin number doesn't dictate the month at all.
Look at the vin numbers again and tell me if all type 2 vin numbers start with a 2.
Roy
59 crew
66 westy
roy
roy is offline
PostPosted: Tue Feb 12, 2002 3:48 pm    Post subject: no M-Plate? Reply with quote
Sorry Andrew, Looks like you are right
Feb '65 bus.
roy
roy is offline
Now, how did you figure the walk thru deluxe part.
sweetbus
sweetbus is offline
PostPosted: Tue Feb 12, 2002 9:35 pm    Post subject: no M-Plate? Reply with quote
the way things are lookin on this bus it scaring me a bit.... and body have a title from a totaled 65 bus they wanna get rid of?????
Kommercial
Kommercial is offline
PostPosted: Wed Feb 13, 2002 8:40 pm    Post subject: no M-Plate? Reply with quote
I have done alot of research of differences of VIN's thru the years, loactions, m-plates and etc at http://dropgates.com/identity
also i have all the *current* info for sending away for the birth certificate here
http://dropgates.com/resto/identitycert.html
BTW- the 3rd number in the VIN meaning the year, *only* applys to overhead plates, which were used Aug64 and on, not on vin#'s in other locations from 50 all the way to 67. (Aug64 and on m-plates behind seat had the year at the beggining of the vin) Also someone prolly just riveted that plate up there and title'd it off that plate back in the day which is why its a Dlux walkthru plate on a non Dlux walkthru bus. You should still have the VIN stamped in the engine compartment next to the apron on the passenger side.
-Wade
sweetbus
sweetbus is offline
PostPosted: Thu Feb 14, 2002 9:07 pm    Post subject: no M-Plate? Reply with quote
Ok the # stamped in the engine compartment is 225108409, it is the same as the plate in side the bus.... ohh damn i just now noticed my type on the vin i type a few days ago... shit im sorry guys.. so 225 in a microbus bench thats what i have....now onto the task of getting a damn title, its a bich in virginia .....
