How to remove parking brake cables
[email protected]
jahzus28@yahoo.com is offline
PostPosted: Wed Mar 13, 2002 9:42 pm    Post subject: How to remove parking brake cables Reply with quote
I need help in trying to remove the parking break cables form the rear wheels of a 66 bus. Any suggestions would be appreciated.
23window
23window is offline
PostPosted: Thu Mar 21, 2002 3:47 pm    Post subject: How to remove parking brake cables Reply with quote
If I recall correctly,
You must first undo the cables from the front of the bus at the brake lever. Then go around back to the rear of the bus, loosen the lugs slightly while on the ground, jack the bus up, secure it on stands, remove the wheels, then the axel nuts, then drums. The cables must be removed by pulling them out of there tubes from the backing plates. Liberally apply grease when reinserting the cables in the tubes. good luck.
