delibessleep Samba Member
Joined: January 09, 2005 Posts: 764 Location: Nine Mile Falls, WA
Posted: Mon Sep 12, 2011 6:55 pm Post subject: Fridge maintenance |
Hello,
I have a Dometic 182...and nothing seems to work (LP, 120V, DC)
So I pulled it to perform the recommended maintenance.
I had it 24 hours upside down, as suggested. When I flipped it right-side up, I could hear liquid falling within the fridge.
What does this mean?
Also, the electronic rod that runs through a tube within the insulated flashing...I suspect that is the thermocouple...how do you check this?
I really hope this works! The piezo starter and air pump function; the jet is clear. The original fan motor had seized, so I replaced it with a Radio shack version. If the fridge works, I'll invest in the biscuit fans, but until then... _________________ 63 Single Cab
87 Westy
18 Alltrack
Biology is destiny...choose your mutations carefully |
