Low Oil psi and Acceleration flat spot
Dane559
Dane559 is offline
PostPosted: Sun Sep 25, 2011 1:25 am    Post subject: Low Oil psi and Acceleration flat spot Reply with quote
Hey guys, My 71 super with a 1600dp recently made the trip from Fresno to Sacramento and back about 400mi round trip with no problems what so ever.. Since then I have changed my 009 distributor to a vac advanced 050 with electronic points.. I timed it by ear, because I no longer have a timing gun.. Now, This weekend, I took a trip up to modesto, wich is about 95mi. on the way up, I expirienced a bit of bogging in the ecceleration and slightly low psi.. that was there. On the way back, I had got about 10mi befor there was about 28psi as Im flooring it, and the ecceleration is sputtering and hitting flat spots.. anybody have any Ideas? Think its too advanced, Over heating and thinning oil? or bearings?.. whats the Pro's Takes???
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Sep 25, 2011 2:31 am    Post subject: Re: Low Oil psi and Acceleration flat spot Reply with quote
Borrow a timing gun.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
vw_hank
vw_hank is offline
PostPosted: Sun Sep 25, 2011 2:31 am    Post subject: Reply with quote
Time it!!! your oil psi is more then likely A result of the timing cosing the motor to run hot and thining out the oil.
1302s sunroof..
1600cc motor. Glenn ring 010. full toplineparts.com suspension. factory front disk brakes. Tram type-3 rear brakes. Hurst shifter. empi-8's. low-back's. tons of mods!
baked beetle
baked beetle is offline
PostPosted: Sun Sep 25, 2011 6:46 am    Post subject: Reply with quote
ummm. yea.
These days people like me are hard to find- we don't give a damn what you think, about what we think. - JR
____________________
66' His
57' Theirs
63' Hers
62' Drag Bug - Theirs 13.1 @ 101 mph (GONE)
mark tucker
mark tucker is offline
PostPosted: Sun Sep 25, 2011 6:55 am    Post subject: Reply with quote
or retarded and having to work to hard to get nowhere.get a timing light&check it. it also might need to be curved for your motor.
Dane559
Dane559 is offline
PostPosted: Sun Sep 25, 2011 9:41 am    Post subject: Reply with quote
Thanks guys. will check the Timing today.. I know its a dumb move to time by ear, but I had no other choice at the time..
bugnut68
bugnut68 is offline
PostPosted: Sun Sep 25, 2011 3:02 pm    Post subject: Reply with quote
I've never heard of a 050 distributor with vacuum advance?
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
Dane559
Dane559 is offline
PostPosted: Sun Sep 25, 2011 4:20 pm    Post subject: Reply with quote
So, Timing was 10 degres advanced, moved it to 4 degres retarded.. Valves were way out of adjustment, set em to .006, oil level was high, got that evened out.. now I hope I dont run into this problem again, or its going to be my Main Bearings.. :O an we dont want that, now, do we...
@Bugnut, It says Bosh 050, vac advance and retard, w electronic points..
spectre6000
spectre6000 is offline
PostPosted: Mon Sep 26, 2011 7:27 am    Post subject: Reply with quote
You could have gone to any FLAPS and picked one up before driving 95 miles on it... Static timing light is better than nothing...
Valves were out because you overheated it. How much oil is too much? It should have blown itself out by the time you got 95 miles on it... Is your case properly vented?
Jason Hopper
-'58 German Market Deluxe Beetle (in progress)
-'84 M1009 CUCV
-'81 K10
"Buy the best, cry once." -Gene Berg
"A cheap man will always buy the cheapest thing available, and then buys another one hoping for a better result, and then spends the rest of his life in misery complaining about it. A thrifty man will buy a good part once and never think about it again." -RockCrusher
"Don't feed the Shitty Parts Monster!" -Me
mcmscott
mcmscott is offline
PostPosted: Mon Sep 26, 2011 7:29 am    Post subject: Reply with quote
If you need help I'm not far from you
bugnut68
bugnut68 is offline
PostPosted: Mon Sep 26, 2011 2:25 pm    Post subject: Reply with quote
Interesting... the only 050 I've ever seen was purely mechanical advance.
