S.A. Lights
bus2
bus2 is offline
PostPosted: Sun Sep 25, 2011 11:50 pm    Post subject: S.A. Lights Reply with quote
Hello
Does anyone now of a source for the South African head light lense. I belive it is 5" dia. (high beam, Hella) I have one lense were the lense reflective coating is coming off. I know G.W. sells complete replacement set with bracket, but was hoping I could maybe just find the lense. I did try to Goggle the part number (303-131-040) but didn't have much luck.
Thanks for any help
Bus2
chojinchef
chojinchef is offline
PostPosted: Mon Sep 26, 2011 6:33 am    Post subject: Reply with quote
I do not have the kit yet, its on the wish list from Santa, but it seems the inner lights are the same as the Golf lens, maybe?
Hella H12719011 driving light insert lens?
Its a mistress; an expensive, whiney, needy bitch of a mistress. She is a chunky, dirty girl with bad skin, little motivation and yet she always makes me smile. She sure has been around before shacking up with me. She has a direct line to my wallet, plays with my emotions, is consistantly jovial yet with a sarcastic and sardonic side, is consistant in her inconsistancy, and every once in a while gives me a great ride and a fantastic memory.
onwardtothestars Premium Member
onwardtothestars is offline
PostPosted: Mon Sep 26, 2011 8:13 am    Post subject: Reply with quote
If the reflector is metal you can have it replated I think even if it's plastic it can be done. There's a metal plating company on broadway in Denver. Ace or acme or something is there name. I hav talked to them in the past about Replating some Audi european headlight reflectors
Beetle, Ghia, Vanagon Syncro, and more
PostPosted: Mon Sep 26, 2011 8:15 am    Post subject: Reply with quote
r39o
Samba Polizei
r39o is offline
PostPosted: Mon Sep 26, 2011 9:20 am    Post subject: Reply with quote
It is a special process to replate the lens. It must be optically right. It makes sense if you are restoring a true relic. Not worth the hassle since you can buy new ones. Spend the $70 (I think) and buy a new one.
Syncroincity
Syncroincity is offline
PostPosted: Wed Sep 28, 2011 7:50 pm    Post subject: Reply with quote
*EDITED* Cabriolet lights are NOT the same, sorry... I retract my statement. Embarassed Evil or Very Mad
'86 Syncro CHC Top AAZ Turbodiesel
'04 Passat Variant 4Mo 5MT
Vanagon Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=466866&highlight=
erdonline
erdonline is offline
PostPosted: Wed Sep 28, 2011 8:24 pm    Post subject: Reply with quote
Here's a link to some on eBay. They seem to be going for around $30 per light. I picked up one from a junk yard last year as an extra in case I bought the South African grill and lights. I'm still not sure if I'm getting the South African grill, and not sure if I want to keep or sell the light I have.
But they do come up on eBay, and, as previously stated, were used on earlier Cabriolets.
Ed
'85 Vanagon Westfalia
'84 Vanagon 7-passenger
'98 Mexican air-cooled Beetle
mtnwater
mtnwater is offline
PostPosted: Wed Sep 28, 2011 9:11 pm    Post subject: Reply with quote
Ed
link? searched briefly, but was quickly overwhelmed when I searched for "cabriolet driving lights"
It'd be great to find a source for these - both my reflectors are badly rusted from condensation.
kamzcab86
kamzcab86 is offline
PostPosted: Wed Sep 28, 2011 10:38 pm    Post subject: Reply with quote
Deleted due to Syncronicity's post below. Don't want anyone going out and searching Cabriolet part numbers. Wink
~Kamz Anxious
2016 Golf GTI S
Syncroincity
PostPosted: Thu Sep 29, 2011 12:23 am    Post subject: Reply with quote
Ebay has a pretty good BS filter; after your search words, add anything you want excluded from the results with a dash before it,
ie -LED -HID -keychain etc etc... and most importantly, "-fits"
This will eliminate the 30,000 returns you get from sellers of bulk crap, and the A-holes who describe a turbonator as "fits" a VW cabriolet.
Syncroincity
PostPosted: Sat Oct 01, 2011 9:57 am    Post subject: Reply with quote
Statement retracted. Cabriolet lights are NOT THE SAME as the SA units.
They are made by a different factory, to different specs.
The SA lights have a larger plastic keeper/ adjuster piece, they don't fit into German lights without boring out the holes.
The bolt pattern is a smaller circle on the SA lights, trying to mount German lights to the metal carrier requires bending the mount tabs on the lights inward quite a bit, and generally making a mess of them.
I did manage to get it mounted to the carrier bracket, but it sits at an odd angle, and sticks out too far, almost flush with the outside of the grille. It turned into quite a project to get one in place. Embarassed
Looks like getting the correct replacement light assembly is the only option here. I would add extra sealant around the edge of the glass lense, and POR-15 or paint the back of the reflector to prevent rust. There's not enough sealant in the lense in some of these and that's whats letting moisture inside, which ruins the reflector, and the finish is generally poor, both my original SA lights are significantly rusted around the outer lip and at the tack welds. Quite shoddy materials, only the lense itself seems to have actually come from Hella Germany. Evil or Very Mad
kamzcab86
PostPosted: Sat Oct 01, 2011 10:28 am    Post subject: Reply with quote
That's a bummer, but good (or, in your guys' case, not good) to know. I edited my first post as a result.
~Kamz Anxious
2016 Golf GTI S
Syncroincity
PostPosted: Sat Oct 01, 2011 1:32 pm    Post subject: Reply with quote
Here's the crux of the biscuit. Note how much taller the mount tabs are on the Cabriolet lights, the SA tabs are very near the glass lense.
10 internets to the one who spots what's wrong in that 2nd picture. Wink
