Bfichter Samba Member
Joined: July 23, 2010 Posts: 15 Location: Victoria bc canada
Posted: Sat Oct 01, 2011 12:45 pm Post subject: windshield install. |
I have some leaky seals on my 66 bus.
How do I install the glass and seals?
Im thinking you could put the seal on the van then the glass into the seal, or the seal onto the glass then get it on the van somehow.
I am I close? |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Kombi Samba Member
Joined: August 02, 2002 Posts: 562 Location: Edmonton, AB, Canada
Posted: Sat Oct 01, 2011 1:01 pm Post subject: |
To get your window out without breaking it cut the old seal.
the glass must be placed in the rubber first. place rubber seam at top
a string or wire is then placed in the outside channel around the rubber seal. I usually go around twice, leaving ends of cord exposed and crossed at bottom of wiindow
Place the window flush against the vehicle.
from the inside pull the wire into the vehicle so that the rubber lip covers the pinch weld.
My description probably only helps if you already know what you are doing.
seach I know there will be a better description on these forums.
If you don't want to risk it I know my local glass shop will do that for about $50 a side.
Edit: as above post says Manual is best to help through many situations _________________ Air and Water are needed to survive,
you just can't live as long without air!
Air Riders, VW Club |
sventinker Samba Member
Joined: June 10, 2009 Posts: 1481 Location: the sandbox
Posted: Sat Oct 01, 2011 1:38 pm Post subject: |
I put the seals on the glass, cleaned the metal real good, then sprayed the metal and rubber with window cleaner. The window cleaner is slippery ans basically evaporates when you are done leaving no mess. for the cord I used yellow marking line the stuff usually seen when brick layers are laying each course it is a twisted line that is smooth to the touch. I put the line inside the lip of the rubber where the metal window frame will end up. I only went around once and overlapped a few inches. I had no help just pushed the glass in the frame it will hold itself then while sitting in the seat I reached around the front of the glass applying pressure and started pulling the string. No special angles just nice and slow when it binds up adjust the angle so the string pulls easily. It is so basic I did it my first time perfect by myself (a helper would be nice). After I was done a little pushing on the glass near the edges and it seated in nice. good luck _________________ April 3rd 62 standard mgr/pw
374 North American equipment
Includes 6 popouts
025 Safety belts
195 Adjustable bench seat/backrest (until 1963)
dawerks wrote: |
Perfection only comes with delusion. |
http://www.oacdp.org/ |
Robertjm Samba Member
Joined: May 22, 2011 Posts: 261 Location: San Francisco Bay Area
Posted: Sat Oct 01, 2011 2:37 pm Post subject: |
The Wolfsburg West $3 DVD has a great video on how to do it. If you order your seals from them order the DVD too. Also has a good video on installing seat covers to make them look factory installed. _________________ 1967 VW Double Cab Pickup
2003 Mercedes ML-500
1995 Saab 900SE Turbo Convertible (Crossed over into Valhalla April 2014)
1972 VW Squareback (Autobahn in the Sky - July 1987) |
mr white Samba Member
Joined: October 02, 2005 Posts: 1193 Location: beautiful Oregon & Mohave County, AZ
Posted: Sat Oct 01, 2011 3:48 pm Post subject: |
All you need to do is put your glass in the seal.Put an absurd length of weed eater twine in your seal. Get some dawn soap and being generous,coat your seal all around. Put window into place,carefully push while a helper if need be pulls the twine so the inner seal sucks over the inner lip. should take you about 10mins a window once you develop the feel of it. As with most things,take your time and pay attention. Good luck! |
