bluebus86 Banned
Posted: Mon Oct 10, 2011 8:44 pm Post subject: van hunting at idle |
Got a 1986 2.1 liter 2 wd Vanagon. when at idle, whe has started to hunt, the hunting of rpms is intermittant, sometimes she wont do it, but about half the time she hunts +/-100 rpm to maybe a maximum of +/- 200 rpm at idle.
I know the throttle switch is closing (i have the Vanagon ecu tester box conected, the light on it shows the throttle switch closed). The engine has some fairly recent new vacuum hoses and intake seals /boots.
Any one got some ideas on where to look for a fix?
thanks! |
hdenter Samba Member
Joined: October 14, 2008 Posts: 2940 Location: San Luis Obispo, CA
Posted: Mon Oct 10, 2011 9:29 pm Post subject: |
You are on the right track with going over all the new vacuum lines and connections. Also take a look at the idle control valve and it's hoses. See if you can isolate a common denominator at the times it happens. Is it only when the car is first started, Only while you are turning the steering wheel (if you have power steering) etc. Is this a new problem that has developed recently? Is the van new to you? You could try the WD40 spray trick, but it makes a mess.
Good Luck,
Hans _________________ '79 triple white convertible bug
'84 sunroof vanagon
'85 weekender |
captdave Samba Member
Joined: May 05, 2008 Posts: 87 Location: Prince Rupert, Canada
Posted: Tue Oct 11, 2011 10:39 am Post subject: |
Take a good look at all air hoses. It could be un-metered air. You could try passing a turned on, unlit propane torch around the area of the air hoses. If the engine speeds up that is probley your problem. Just be carful not to cause an explosion!!! |
Posted: Tue Oct 11, 2011 10:40 am Post subject: |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 10226 Location: Mt Lemmon, AZ
Posted: Tue Oct 11, 2011 10:58 am Post subject: |
I'll be interested in what you finally find that cures it.
You might try this -- next time it is hunting undo the oil filler tube cap and see if the hunting ceases (works on mine). If it stops the hunting then it may be telling you something -- but I don't know what. |
seanjenn Samba Member
Posted: Tue Oct 11, 2011 11:14 am Post subject: |
If you don't have propane handy to help find the leak, use something like intake cleaner, starting fluid etc. that stuff is super flammable and will give you a change in idle for sure. Absolutely put a little red tube on the spray nozzle first and keep your extinguisher handy.
Could also have air leak where the "butterfly" shaft goes through the throttle body. _________________ 1987 GL Sunroof
2.1 4 spd |
randywebb Samba Member
Posted: Tue Oct 11, 2011 12:57 pm Post subject: |
repl. O2 sensor solved this problem on mine _________________ 1986 2.1L Westy 2wd Auto Trans. |
DAIZEE Samba Member
Joined: January 26, 2010 Posts: 7552 Location: Greater Toronto Area Ontario West Side
Posted: Tue Oct 11, 2011 1:41 pm Post subject: |
Some may not like this comment but Vanagons seem to be describable in many different ways: hunting, bucking, and many more titles in past threads. I just wondered if this one had a license  _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
84 Vanagon GL Wolfsburg Westy WBX 4 speed (sold) |
