transmission mount?
T3man
T3man is offline
PostPosted: Sun Oct 16, 2011 6:15 am    Post subject: transmission mount? Reply with quote
Is the single rubber transmission mount at the rear, near the shift cone is the same in a bus as a type 3. NOt the two rubber pieces in the bell housing.
1962 Blue notchback n model
1964 White Variant S Type 3 Squareback Euro
1966 Blue sunroof fastback
1969 Bahama Yellow camper bus
2170 Silver Alien space ship. Leaks Nuclear waste!
Eric&Barb
Eric&Barb is offline
PostPosted: Sun Oct 16, 2011 8:41 am    Post subject: Reply with quote
Either of the "Bonded rubber mounting, front" for bus has totally different part numbers than the two front mounts listed for type 3.
In Stereo, Where Available!
Krustybus
Krustybus is offline
PostPosted: Sun Oct 16, 2011 9:40 am    Post subject: Reply with quote
Looks like it depends on the combination you have. What year bus, type 3, etc.
Searched trans mount on the CIP1 website:
http://www2.cip1.com/SearchResults.asp?Search=front+trans+mount
Tim
T3man
T3man is offline
PostPosted: Sun Oct 16, 2011 10:40 am    Post subject: Reply with quote
I have a 64 bus and 66 type 3 transmission.
dmuis
dmuis is offline
PostPosted: Sun Oct 16, 2011 11:37 am    Post subject: Reply with quote
If the tranny is already installed, the mount is the bus standard one for mid 59 - 67.
If you are looking to install the type 3 trans and it has the bus trans in now, you need to use the nosecone and hockey stick from the bus tranny with the standard mid 59 - 67 bus mount.
