JER*FAB lowered spring plates
IAMIROY
IAMIROY is offline
PostPosted: Wed Oct 19, 2011 5:37 pm    Post subject: JER*FAB lowered spring plates Reply with quote
Has anyone used these lowered spring plates on their Type 3 or Type 1?
Soul Built
Pimpin' Aint Easy
Soul Built is offline
PostPosted: Wed Oct 19, 2011 6:28 pm    Post subject: Reply with quote
I have them on my Type 1. I've never seen a Jer*Fab product that isn't made extremely well. Im local enough to live within 10 minutes of his "lab"
Barracudabrendon
Barracudabrendon is offline
PostPosted: Wed Oct 19, 2011 7:07 pm    Post subject: Reply with quote
Jer*Fab plates are top notch A+++
Building quality HWE style racks for your Type 2 Kahuna Metal Works.
1957 Bus
Turbo Mini Single Cab
1964 N Model Squareback
Ruthless Fastback Drag car
IAMIROY
IAMIROY is offline
PostPosted: Wed Oct 19, 2011 8:05 pm    Post subject: Reply with quote
Thanks guys. We'll give them a try then.
lawn ninja
lawn ninja is offline
PostPosted: Thu Oct 20, 2011 9:53 am    Post subject: Reply with quote
What do they run, cost wise? I wanted a set for my 65. They extend out farther in the rear too in order to correct the toe in issue, right?
Jason
My 64 1500 S Notchback project here
My 58 sedan project here
My 63 Ghia here
IAMIROY
IAMIROY is offline
PostPosted: Thu Oct 20, 2011 1:15 pm    Post subject: Reply with quote
They are $150 if you give them your old ones, $200 no core.
http://www.thesamba.com/vw/classifieds/detail.php?id=817690
VWporscheGT3
VWporscheGT3 is offline
PostPosted: Thu Oct 20, 2011 3:32 pm    Post subject: Reply with quote
Iamiroy, Palmdale eh? i grew up off of 15th west and AVE P. i moved up to Carson City , NV in 2004... hows good ole Palmdale?
IAMIROY
IAMIROY is offline
PostPosted: Thu Oct 20, 2011 4:03 pm    Post subject: Reply with quote
Hey GT3. Palmdale is the same ole same. I actually just moved back here. I moved to Spokane, WA in 1990. I had enough of the snow after 21 years. My kids grew up and moved on so I decided to come back to friends and warm weather Smile
I am actually in Quartz Hill area. How's Carson City? I heard it's nice there.
Did you go to Palmdale High?
Matthew Tolbert
Matthew Tolbert is offline
PostPosted: Thu Oct 20, 2011 4:27 pm    Post subject: Reply with quote
i have the 2" on my notch. just measuring with a tape measure i have the toe adjusted to around 1/4". i plan to have it aligned properly one day. the only thing with them is i need to drill a hole for the emergency brake cable to pass through so it isnt coming into the backing plate at a wierd angle. he may do this for you if you ask since i have seen it done on the 4" plates he makes. hope this helps.
Matthew Tolbert
1958 ragtop
1961 doublecab
1965 Notchback S
IAMIROY
IAMIROY is offline
PostPosted: Thu Oct 20, 2011 7:46 pm    Post subject: Reply with quote
Thanks Mathew. Can you post a pick of your notch with the 2" drop in back.
Thanks.
68notch
68notch is offline
PostPosted: Thu Oct 20, 2011 9:47 pm    Post subject: Reply with quote
Can someone explain the advantage if any of these spring plates over simply adjusting the torsion bars as most do?
John
68 Aussie notch
2011 Citroen Berlingo
https://www.facebook.com/Fastacraft
RHD dash pad project http://www.thesamba.com/vw/forum/viewtopic.php?t=475227
Soul Built
Pimpin' Aint Easy
PostPosted: Thu Oct 20, 2011 10:03 pm    Post subject: Reply with quote
When you install these plates, your car retains the stock torsion tension as well as eliminating the toe-in effect caused by lowering your car. It reduces premature tire wear created by lowering by the torsions. Again, I have mine on my T1.
68notch
68notch is offline
PostPosted: Thu Oct 20, 2011 10:18 pm    Post subject: Reply with quote
And these are suited to the type 3 also?
John
68 Aussie notch
IAMIROY
IAMIROY is offline
PostPosted: Fri Oct 21, 2011 6:52 am    Post subject: Reply with quote
Yes, Type 1 and Type 3 swing axle.
Matthew Tolbert
PostPosted: Fri Oct 21, 2011 11:02 am    Post subject: Reply with quote
here it is with 17" raiders and 2" drop plates from jer fab
Matthew Tolbert
1958 ragtop
1961 doublecab
1965 Notchback S
68notch
68notch is offline
PostPosted: Fri Oct 21, 2011 5:26 pm    Post subject: Reply with quote
Nice car, if only I were rolling wide 5's.
If the cars are lowered with the torsion bar adjustment wouldn't the tension still be the same since the bar is just in a different position?
The car still weighs the same and the bars carry that same load??
John
68 Aussie notch
supaninja
supaninja is offline
PostPosted: Fri Oct 21, 2011 5:46 pm    Post subject: Reply with quote
All those plates do is fix the toe-in issues and give you the correct suspension travel back(where the plates rest in between the springplate stops under static load). This guy explains it pretty well:
http://i5.photobucket.com/albums/y163/chucky1974/ninja.gif
Nick
Megasquirted Type 4 powered Notch http://www.thesamba.com/vw/forum/viewtopic.php?t=427890&postdays=0&postorder=asc&start=0
Blog of Doom http://supaninjanick.wordpress.com/
View user's profile Send private message Send e-mail Yahoo Messenger Facebook Classifieds Feedback
IAMIROY
IAMIROY is offline
PostPosted: Fri Oct 21, 2011 9:41 pm    Post subject: Reply with quote
Nice Notch Matthew. Thanks for the pic.
RennyRB
Samba Textbook Gangsta
RennyRB is offline
PostPosted: Fri Oct 21, 2011 9:52 pm    Post subject: Reply with quote
This tension nonsense has got to stop.. If you use the same torsion bar, neither a stock plate or a lowered plate are going to effect different tension on that bar.
These are for toe-in corrected and if you are extremely low, will give you back your travel. At 2 splines on stock plates, I dont hit my bumpstops, so the travel point is a bit moot.
Take all this with a grain of salt, I don't expect to end this argument anytime soon..
1967 Squareback
vlad01
vlad01 is offline
PostPosted: Sat Oct 22, 2011 12:06 am    Post subject: Reply with quote
^This.
exactly what I thought, I see no benefit unless you are super low.
