sarge1775 Samba Member
Joined: October 05, 2016 Posts: 31 Location: Campobello SC
Posted: Fri Feb 02, 2018 5:36 pm Post subject: Shocks |
Looking to replace front and rear shocks on my 1967 VW Beetle. Have coil over shocks in front. Oil shocks in rear. Have a 2276cc 4.12 r/p racing transmission, racing axles. want to make sure I have enough support for this setup. Open to all suggestions.
Thanks |
esde Samba Member
Joined: October 20, 2007 Posts: 6373 Location: central rust belt
Posted: Fri Feb 02, 2018 5:54 pm Post subject: Re: Shocks |
Koni red oil shocks. Once you get them adjusted where you want them, they are great. Adjusting them is a pain, you have to unbolt one end of the shock. If you want more, easier adjustment, try these:
https://www.thesamba.com/vw/forum/viewtopic.php?t=606719&highlight=gaz
Best pair of shocks I've ever put on a beetle. Now have several friends running them, no complaints at all. They will make them adjustable for compression and rebound also.
SD _________________ modok wrote:
74 Thing Samba Member
Posted: Fri Feb 02, 2018 5:59 pm Post subject: Re: Shocks |
| Koni reds all around. You have to pay some, but they work very, very well! |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16805 Location: State College, PA
Posted: Fri Feb 02, 2018 6:06 pm Post subject: Re: Shocks |
If you dont want to go Konis or Billstein, then KYB Gas adjust on the rear and KYB Excels on the front. BUT the specific model will depend on how lowered you are. Different valving on different models and this is where a lot of folks mess up. The gas adjust gives a slight raise and are way too stiff for the front, but work well on the rear.
And look at sway bars and camber compensators... _________________ D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
cousineddy Samba Member
Joined: October 05, 2009 Posts: 50 Location: United States
Posted: Fri Feb 02, 2018 8:03 pm Post subject: Re: Shocks |
Do the Konis come in different lengths for lowered bugs? _________________ 65 bug blow thru 2276 turbo
73 Thing |
Das67bus Samba Member
Joined: April 06, 2008 Posts: 256 Location: Prescott, AZ
Posted: Fri Feb 02, 2018 9:02 pm Post subject: Re: Shocks |
| 74 Thing wrote: |
I agree! The Koni's are well worth it. Do it right and you won't regret it.  _________________ SLOW RIDE........TAKE IT EASY!!!
-Foghat
COMFORTABLY NUMB!!
-Pink Floyd |
