connorsvw2 Samba Member
Joined: August 16, 2008 Posts: 362 Location: Denver, CO
Posted: Sun Oct 30, 2011 4:23 pm Post subject: GoWesty 2.5 engine failures-what would you do? |
A question for the group, esp the WBX builders-
A good friend of my father-in-law bought a fully redone Westy from GoWesty, including their 2.5L engine. He absolutely loves the van, but here's the issue:
in 30k miles of driving he has now had 2 engine failures, most recently while driving on the highway-sudden loss of power and unusual engine noise. Van is at the mechanics now, unclear what the problem is save for loss of compression. He does not know what the post-mortem on engine #1 was either. GoWesty will replace his engine.
GoWesty is treating him very well; thankfully he has the extended warranty and they are covering his next engine (#3).
Question is what should he replace the 2.5 with? All of their larger engines appear to use a modified/?welded crank, and forged JE pistons with decreasing CR's as the displacement shrinks (9.7:1 on the 2.5). Their 2.4 also seems to use a special crank and smaller pistons than the 2.5; the 2.3 looks like a shorter stroke and same pistons as the 2.4.
Owner states GoWesty feels he is not driving the van properly, ?lugging the engine which he very strongly denies. This makes me suspect the issue may be with the pistons/CR, and the most recent failure at highway speed with loss of compression makes me wonder if a detonation issue destroyed a piston crown, rather than a crank/rod failure which should have been obvious to his mechanic (i.e. hole in block). Knowing the owner, I'm sure he has not skimped on fuel quality.
He will likely need to stay with GoWesty for engine replacement-I doubt they will refund his money at this point (otherwise I would have him contact 10cent immediately for an engine). His mechanic won't work on Subaru conversions, or I would steer him towards that option as I have done.
What would you all recommend he do? Get another 2.5 (9.7:1 CR), drop to 2.4 (9.4:1 CR), 2.3 (9.0:1 CR), or even the 2.2 (8.7:1 CR)? Too bad these engines don't have knock sensors-I'm currently rebuilding a 2.0L 16V GTI engine with 10.8:1 CR and 2 knock sensors which would alleviate his detonation problems but it's going into my A2 GTI. _________________ '85 Westy Wolfsburg camper/2002 2.5 Subaru since 2003.
'85 GTI 1.8L 1-owner 8v-gave up on 9A 2.0L 16v transplant. Keeping her stock!
'99 Passat 1.8T Variant-AKA "The Money Pit". Still limping along...
'09 Subaru Outback XT 5-speed, 245 hp rocket (wife's car) |
D Clymer Samba Member
Joined: December 22, 2005 Posts: 2987 Location: Issaquah, WA
Posted: Sun Oct 30, 2011 5:07 pm Post subject: |
I think before a judgement can be made about what to do for an alternate engine, it would need to be known what kind of internal failure happened to the GW 2.5. It would be important to know if it is piston/ring related, or if it is a main/rod bearing oil starvation issue. It would also be good to know what caused the failure of the first engine.
Another possiblitity, aside from having GoWesty install one of their lesser engines, would be to have them replace the 2.5 and then post it up for sale. If it sells, then your friend can go the Subaru 2.5 route. If not, GoWesty can continue to warranty the engine if it fails again.
I certainly don't buy into the idea that the engine is being driven wrong. An engine being offered to the public needs to be tough enough to handle different driving conditions and styles.
David |
noganav Samba Member
Joined: January 06, 2006 Posts: 1236 Location: San Diego CA
Posted: Sun Oct 30, 2011 6:00 pm Post subject: |
Is it just me, or does this same story come up quite a bit on here.
Even on the GoWesty site they have a couple stories of multiple "freak" engine failures with their engines. The infamous red syncro had at least one at the end of the warranty, and they initially were re-selling with a new engine, but without an engine warranty. I've read at least one other on their site, plus one multiple engine failure horror story from a list member here.
Is it because there are so many out there, or is this a case of where there's smoke, there's fire. I wonder. Might be worthy of a poll... |
fredn Samba Member
mtwrench540 Samba Member
Joined: October 25, 2009 Posts: 351 Location: monterey,va
Posted: Sun Oct 30, 2011 6:54 pm Post subject: gw |
does any body know if luca is still involved with gowesty,i heard that there had been some major changes there!!! _________________ 87 wolfsberg,74 181w/1915 and lots of patina! learned to fix vw's from hot vw mag in 1964,VWOA instructor,DSM,69 to73,service mgr at different porsche-audi dealers etc,etc,now retired!!! first vw new 64,transplanted 356 eng in 65,400characters are not enough space!! |
r39o Samba Polizei
Posted: Sun Oct 30, 2011 8:47 pm Post subject: Re: GoWesty 2.5 engine failures-what would you do? |
| connorsvw2 wrote: |
| He will likely need to stay with GoWesty for engine replacement-I doubt they will refund his money at this point (otherwise I would have him contact 10cent immediately for an engine). His mechanic won't work on Subaru conversions, or I would steer him towards that option as I have done. |
Find a new shop! The guys who work on our cars when I do not want to, are more than happy to service my Suby Vanagon. They have a couple that customers installed the Sibari power train and now let them do the routine service.
OR I'd say as an alternative to send the new GW engine directly to 10C and let him make it bullet proof. Lugging indeed...... _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
fredn Samba Member
Posted: Sun Oct 30, 2011 9:18 pm Post subject: |
A partial summary of the never ending problems in Shorepig's thread:
"The saga to date: - first 2.3 gw motor w/all related expenses $9000
(got about 1000 miles out of this one)
- second 2.3 gw motor / related expenses $2200
( got about 6000 miles out of this motor)
- second 2.3 gw motor / new piston set $1700
(hopefully this one will last, not counting on it)
So I certainly wouldn't call that a deal, would you? After a year and a half of breakdowns, stress, and a total cost of $12,900 we will come out of it with what has proven to be an unreliable motor than MIGHT last....for a while...or maybe a long time. At this point all we can do is keep our fingers crossed and hope for the best.
I'm trying to stay optimistic..believe it or not." _________________ 1982 Air Cooled Vanagon Carat Weekender Interior
| tencentlife wrote: |
| ...most are doing what most auto forum participants do, parroting things they've heard |
Posted: Sun Oct 30, 2011 9:33 pm Post subject: |
Owner does not know what happened to engine #1 except that it was suggested he was "lugging" the engine. Engine #2 is at mechanics-perhaps he will hear more from them soon. Not clear to me if the mechanic is to do anything more than send the engine back to GoWesty. I may ask the owner to see if the mechanic will speak to me directly about what he has found.
The Shorepig link was very interesting. Really makes me wonder about the detonation issue. The GW home page shows they are now using JE forged pistons, which are US-made pistons with a good rep in the inline-4 VW world (they make one of the few available piston types for my 9A 16V engine) and ARP rod bolts-all good stuff. However, no getting around the high CR with no knock sensor-it would be great if a stand-alone knock sensor (like my KE-Jetronic GTI has) could be added to this engine like with the older A2 K-Jetronic models.
As this van was completely refurbished before being sold by GW, any of the ancillary engine components used (dizzy, ECU, etc) were installed and inspected by GW. As I noted, they have been very good to the owner in terms of doing right by him, but his question is what to replace the 2.5 with.
I know that 10cent does not build a 2.5, and I assume this is for good reasons. I personally am leaning towards recommending the owner install the GW 2.3 engine, as I THINK this is the largest size 10cent builds. _________________ '85 Westy Wolfsburg camper/2002 2.5 Subaru since 2003.
Posted: Sun Oct 30, 2011 9:48 pm Post subject: |
| connorsvw2 wrote: |
I know that 10cent does not build a 2.5, and I assume this is for good reasons. I personally am leaning towards recommending the owner install the GW 2.3 engine, as I THINK this is the largest size 10cent builds. |
That's why it really would be good if you can find out what type of engine failure occurred. The 2.3 still uses a welded stroker crank from DPR just like the 2.4 and 2.5. The difference is that it is stroked only 2mm while the 2.4 is stroked by 6 mm and the 2.5 by 8.5mm. Both the 2.3 and the 2.4 use 96.5 mm pistons while the 2.5 uses 97mm - the diameters of the pistons are very similar on all three of these engines. Just looking at the components it isn't obvious that either the 2.3 or 2.4 would be more durable than the 2.5.
See if you can pin it down to either piston/ring failure or bottom end main or journal bearing failure. Knowing that would make it easier to give a recommendation.
As far as the knock sensor goes, yes it would be nice to run one with a wasserboxer, but you'd have to figure out where to locate the knock sensor. The location VW used on the inline engines doesn't work for a wbx because it is a wet sleeve engine and at mid-cylinder height all you have is a water jacket which is not directly connected to the cylinder.
D |
Posted: Sun Oct 30, 2011 10:08 pm Post subject: |
The one other big difference is the 2.3 has a 9.0:1 CR, whereas the 2.5 is 9.7:1...
I'll see if I can speak with the mechanic. I agree it would be very helpful to know what happened, even if he can only guess. His mechanic is a well-respected Vanagon mechanic here in town who by all accounts knows his stuff.
Is Shorepig the only other GW engine failure on the Samba? I probably should do a search. After reading the entire post, I'm still not quite clear what happened-sounded like detonation and blown piston, followed by late bearing failure (?secondary to high loading from detonation).
How/where does Porsche mount their knock sensors on the water-cooled flat 6's? _________________ '85 Westy Wolfsburg camper/2002 2.5 Subaru since 2003.
Howesight Samba Member
Joined: July 02, 2008 Posts: 3429 Location: Vancouver, B.C.
Posted: Sun Oct 30, 2011 10:32 pm Post subject: |
My two cents:
For $400 wholesale, GoWesty could buy and then for $100 of mechanic's time, install and set up, the J&S Safeguard knock control system on all their high-compression engines.
Fewer returns, lower warranty costs, higher customer satisfaction and - - restored reputation. I have used the J&S system on a Toyota turbo project, and it truly is remarkable.
http://www.jandssafeguard.com/index.html
Vanagons have so much competing wind, road and gear train noise that it really is hard to hear knock.
If GoWesty won't do this, maybe the OP's friend should consider installing one him/herself. _________________ '86 Syncro Westy SVX |
Posted: Sun Oct 30, 2011 10:49 pm Post subject: |
| connorsvw2 wrote: |
How/where does Porsche mount their knock sensors on the water-cooled flat 6's? |
The Porsche M96 motors are not wet sleeve motors. They use a standard coolant passage configuration around a cast in cylinder bore. Porsche did set an engineering precedent for something more similar to the wbx with their knock sensor placement on the 3.6 liter air cooled motors. On those, they mounted an aluminum bridge to the base of the cylinders of one bank and then mounted the knock sensor to the bridge. I've always thought this would be the way to do it if you were to fit a ks to a wbx. It would also be interesting to see how Alfa Romeo did it on the 164. Their V6 is actually a wet sleeve engine and that one is new enough that it would have had knock sensors.
9.7:1 is pretty high for a non-knock sensor engine, even with premium unleaded. Conventional wisdom in the VW watercooled tuning circles, which you are obviously also a part of , is that 9.5:1 is the highest you can go without a ks running premium, and that's even a little high. If that turns out to be the problem, I would stick with the 2.5 but maybe find a specialist who can pull it back apart and find a way to lower the compression ratio. It would depend on the design of the pistons, but it might be possible to machine the piston crowns a little bit to increase the bowl volume.
I have a feeling GoWesty is going to want to take that engine away and not have an independent mechanic open it up to see what's wrong. They do a good job of keeping problems with this engine below the surface. They pretty much have to given its $6900 price tag.
To their credit, I think their smaller engines stay together very well. The Shorepig fiasco is the only one of its type I've heard of.
David |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12177 Location: Port Manteau
Posted: Sun Oct 30, 2011 11:39 pm Post subject: |
holy cow, $7k for a WBX? That's insane _________________ Casey--
'89 Bluestar ALH
'01 Weekender --> full camper
NEAT, no ICE. |
Posted: Mon Oct 31, 2011 8:24 am Post subject: |
I spoke with the owner this AM. First 2.5 was an earlier version without oil squirters, and was already installed/used in the Westy he bought from GoWesty with unknown service or break-in hostory.
Sounds like failure mode on that engine was a loss of compression (85 PSI) with 80% leakdown in 1 cylinder.
He only uses premium fuel.
He told me GoWesty told him to consider an aftermarket knock sensor...Has anyone successfully installed an aftermarket KS unit (I looked at the one referenced above, looks nice) on a WBX, due to the concerns David raised above?
He'll call his mechanic today about current engine. I asked him to inquire about compression, leakdown testing and possible borescope inspection if 1 cylinder is the problem again.
As an aside, GoWesty's engine page mentions they require Magnafluxing of their welded cranks, and reject 0.5% of these cranks. I was always under the impression that welded cranks were virtually impossible to Magnaflux due to the multiple stress risers welding and offset grinding creates. I personally would prefer that a welded stroker crank to be shot-peened and/or nitrided for additional strength. _________________ '85 Westy Wolfsburg camper/2002 2.5 Subaru since 2003.
buildyourown Samba Member
Posted: Mon Oct 31, 2011 10:38 am Post subject: |
| Kinda off topic, but I'm curious how knock sensors work on an engine with a distro. On an electrical ignition, when knock is sensed the computer retards timing, correct? |
r39o Samba Polizei
Posted: Mon Oct 31, 2011 11:07 am Post subject: |
| connorsvw2 wrote: |
Sounds like failure mode on that engine was a loss of compression (85 PSI) with 80% leakdown in 1 cylinder. |
Not sure what squirters and high leak down have in common, but maybe the piston melted or rings ate it or or or.....it could be several things or a combination conspiring together. It is a sample set of one.
| connorsvw2 wrote: |
| He told me GoWesty told him to consider an aftermarket knock sensor...Has anyone successfully installed an aftermarket KS unit |
RED FLAG! WHAT????
Seems they sort of know already. Why the F don't they install that, if it is an issue that they can detect and diagnose from far away?!?!?!?!?!?!
| connorsvw2 wrote: |
| He'll call his mechanic today about current engine. I asked him to inquire about compression, leakdown testing and possible borescope inspection if 1 cylinder is the problem again. |
Nice to know, but does not help "that" much.
FYI: There is an inexpensive scope available at Costco currently.
| connorsvw2 wrote: |
| As an aside, GoWesty's engine page mentions they require Magnafluxing of their welded cranks, and reject 0.5% of these cranks. I was always under the impression that welded cranks were virtually impossible to Magnaflux due to the multiple stress risers welding and offset grinding creates. I personally would prefer that a welded stroker crank to be shot-peened and/or nitrided for additional strength. |
Highly tweaked mass produced performance VW engines are NOT for the masses. I have seen many tuned engines fail for many reasons in the last years. Welded / stroked, heat treated, nitrated, shot peened do break. Journals fail due to several factors and maybe not just one in particular. Rings flutter. Valves snap off. Cam gears come loose. Oil pump drives snap. You name it. Point is all these parts have to be very reliable if the tuned engine is to hold together. They are NOT using all factory parts (and as we know there is a lot crap out there) so there will be failures. Part of their equation, I bet.
But, on a personal note, they claim so so much testing. Basically they, to me, are saying these are such super duper great engines and everybody needs one cause they are so darn good. Well maybe they are and maybe not. It is great they stand behind their power plants. It is just that at some point the customer is so worried that they really do not want to be put through the exercise again. Wastes their time. I lose confidence at this point with any jobber I am involved with.
At this point I will beat the Suby drum. I do not do this often. But, when was the last time you heard of a unknown engine failure with a Subaru? My buddy ran one out of oil. Some have other issues. But they are known issues and can be dealt with ahead of time. This is one of the reasons I did the Suby deed. I had NO idea that GW engines could have these sorts of issues. Enough now.
I feel personally VERY sorry for this person. They thought they were buying the premium product, paying the premium price and it breaks a lot. My dad, The Master, says this: "You are lucky to get a good job, no matter what you pay." It is not the way it "should" be.
GOOD LUCK! _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6344 Location: Portland OR
Posted: Mon Oct 31, 2011 11:20 am Post subject: |
http://www.gowesty.com/library_article.php?id=1452
Everybody loves to bash GoWesty, but I know a lot of people with GW engines that have never had a problem. Like they said, when you have sold thousands of engines, there will be some people with problems. it's unfortunate but there isn't a product out there with 0% failures. They report a 2% failure rate which seems pretty good to me (as long as I'm not in the 2%). _________________ 89 Westy 2.1 Auto |
r39o Samba Polizei
Posted: Mon Oct 31, 2011 11:38 am Post subject: |
| PDXWesty wrote: |
Everybody loves to bash GoWesty, but I know a lot of people with GW engines that have never had a problem. Like they said, when you have sold thousands of engines, there will be some people with problems. it's unfortunate but there isn't a product out there with 0% failures. They report a 2% failure rate which seems pretty good to me (as long as I'm not in the 2%). |
I am not sure I am GW bashing or not, actually. I think it is more a sign of the times and the end user.
In the 50+ years we built "stock" engines I do not recall (and I asked too) if we had such a failure rate (I am about 20 years shy of being there the whole time.) I am told there were no catastrophic failures of stock engines during that time. Those engines included VW, Porsche, Mercedes and the odd Opel / Ford (no Fiat or Ferrari! just German.) We had customers wear out engines in high demand applications like buses and (a few) high mileage breaks, but must engines ran for many years and a lot are still on the road. Those were a few thousand we guess. But different times those were when the parts were good and the only thing from China was lunch. As stated, we built stock engines. The tuned stuff was for racing and not daily driving. We assumed the factory basically knew what they were doing. That formula worked for us. I believe most tuned engines are not for the masses. _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
Posted: Mon Oct 31, 2011 11:43 am Post subject: |
@ $7k per unit, I'm not sure I'd characterize this engine as being anywhere near available to the "masses". If I'm gonna damn well spend that kind of cash on an engine, it's gonna run on purified mixture of mink's blood and puma piss. _________________ Casey--
'89 Bluestar ALH
NEAT, no ICE. |
dubbified Samba Member
Joined: March 03, 2010 Posts: 1508 Location: Redmond, WA
Posted: Mon Oct 31, 2011 11:46 am Post subject: |
I think Zeitgeist hits the nail on the head.
at 7K.. uggh.
I'd convert my entire engine to a diesel, and strap it with boatloads of KermaTdi mods. |
