One 3 rib to 6 rib Transmission swap question
vwjoe
vwjoe is offline
PostPosted: Fri Dec 23, 2011 10:14 am    Post subject: One 3 rib to 6 rib Transmission swap question Reply with quote
I have read the other 300 and somethings posts for the tranny swap
from a 3 to a 6 rib tranny. But I have seen different answers.
Anyway here is my question. On the 6 rib before putting it in, I need to swap out the drive shaft and the bell housing,,, DO I NEED TO SWAP OUT THE NOSE CONE TOO??
Please if you are not 100% sure and have no hands on experience in this do not answer. Im not looking for opinions, I'm looking for facts.
Thank you.
bigbore
bigbore is offline
PostPosted: Fri Dec 23, 2011 10:46 am    Post subject: Reply with quote
NO
where its cold and snowy
rustbus
rustbus is offline
PostPosted: Fri Dec 23, 2011 11:52 am    Post subject: Reply with quote
the shift rods are different lengths, it may be a good idea to look at swapping those too... check ratwells site for an elaborate description and theres some good threads about it on samba if you get your search terms right
May of '72 Deluxe. Red Bay Bus 2.0L L-Jet CS & 091 trans conversion
my Bus thread
El_Güero
El_Güero is offline
PostPosted: Fri Dec 23, 2011 12:56 pm    Post subject: Reply with quote
bigbore wrote:
NO
X2.
"Sé que en algún lugar sus dedos pelean con un tornillo" (Remembering Carlos Amat)
"Si quiero estar encabronado
hazte a un lado...cabrón!"
MaddMatt
MaddMatt is offline
PostPosted: Fri Dec 23, 2011 1:59 pm    Post subject: Reply with quote
El_Güero wrote:
bigbore wrote:
NO
X2.
X3
It will make it. Trust me.
Owned: 71 Superbeetle, 72 Superbeetle, 63 Baja (on 69 pan) 74 baja, 74 Karmann Ghia
Own: 71 Deluxe Bus
