WesleyGarrard Samba Member
Joined: October 08, 2007 Posts: 541 Location: Pekin, Il
Posted: Tue Feb 07, 2012 6:04 pm Post subject: New alternator, now detonation? |
Would a new alternator cause detonation? I recently replaced the old externally regulated alternator for a new internaly regulated one after it was no longer providing adequate voltage. Now it seems after the new alternator has been installed there is detonation. It has dual carbs so they were not touched, nor was the distributor moved.
I have checked the obvious areas, valves, carbs, checked the timing, checked for exhaust leaks and vacuum leaks and still no change. My next step is to check the plugs and plug wires but was wondering if possibly the renewed voltage to the car has increased the spark intensity at all. Probably a crazy idea but I may never know if I do not ask. |
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Tue Feb 07, 2012 9:17 pm Post subject: |
Whats the chance you got a tank of bad gas? _________________ Mother Nature is a Mean Evil Bitch! |
mrbigmax Samba Member
Joined: September 10, 2011 Posts: 1289 Location: Modesto, CA
Posted: Wed Feb 08, 2012 12:56 am Post subject: |
| When do you hear this sound? |
Posted: Wed Feb 08, 2012 9:59 am Post subject: |
| drscope wrote: |
| Whats the chance you got a tank of bad gas? |
That is possible, however I filled up with 90 octane after noticing the detonation. Last night I tried some 93 octane. I have not driven it much since then so I will see what that does
| mrbigmax wrote: |
Under load. It doesn't do it when idling. |
