coolwind57 Samba Member
Joined: February 17, 2008 Posts: 79 Location: S. Indiana
Posted: Thu Jun 03, 2010 7:33 pm Post subject: All LED tail lamps |
I've got a mess of a lighting situation.
I'd been thinking of the possibility of just ripping out the tail lamp assembly and replacing the opening with a sheet metal base with new universal LED lights installed which are designed as brake/turn signals.
I see these lights at most truck stops and you can get them in a variety of styles. I wonder if a fella could wire them up with the existing Vanagon wiring and have no issues with voltage and flasher speed, etc.
Anyone do this yet? _________________ 1983 Vanagon Diesel L
NA 1.6, 5-speed Manual
Burning Waste Vegetable Oil, baby!! |
Classicvibe Samba Member
Joined: August 03, 2009 Posts: 743 Location: Salt Lake City
Posted: Thu Jun 03, 2010 7:42 pm Post subject: |
You should start with tracking down the lighting issue you are having. Depending on where the wiring issue is, you may just be putting a new set of LED lights into the same situation. Do you have any detail on what and where the problem is? _________________ On a mission, the destination is just an excuse.
Syncro Solstice 2022...see you there!
1986.5 Wolfsburg Syncro Westfalia Poptop Weekender Transporter |
Posted: Thu Jun 03, 2010 8:28 pm Post subject: |
Classicvibe wrote: |
You should start with tracking down the lighting issue you are having. Depending on where the wiring issue is, you may just be putting a new set of LED lights into the same situation. Do you have any detail on what and where the problem is? |
My problem is that the connections directly to the bulbs are shot. Rusted and weak. I don't get the design of these connectors and those brake light assemblies as a whole. My front turn signal connectors are completely shot.
I am assuming that my wiring is good to go. Again, it is the connections that suck.
I'm thinking seriously about buying LED light assemblies and going for it. _________________ 1983 Vanagon Diesel L
Californio Samba Member
Posted: Thu Jun 03, 2010 9:13 pm Post subject: |
IIRC there was somebody in the classifieds who's making these up using the OEM plates and lenses. In Oregon I think. Good idea, I've thought about it many times. |
buildyourown Samba Member
Posted: Thu Jun 03, 2010 9:47 pm Post subject: |
There is a van here in Seattle that has what you are describing.
Round tail lights in a square sheet metal housing. It looked pimp. |
Terry Kay Banned
Posted: Thu Jun 03, 2010 11:23 pm Post subject: |
If your looking for front turn signal bulbs holder's I have several in like new condtion.
The ticket here is to slap the outside & the inside of the bulb holder & bulb base full of di electric grease.
It'll slow down the rusting of the bulb holder contact area for some time to come.
The front T/S bulbs holder's are No Longer Available from VW. _________________ T.K. |
doyll Samba Member
tozovr Samba Member
Posted: Fri Jun 04, 2010 4:38 am Post subject: |
One thing to consider when doing this mod is the stock reflectors. By law, the rear of every vehicle needs some amount of reflector. by going LED, you often lose a bunch. If your State inspection is a tough one, that may be an issue, but the safety factor is there in that LEDs will likely be brighter. you may just have to add the reflective strips like you see on landscape trailers etc. _________________ ...like a young Julie Andrews all whacked out on PCP, kinda fun but kinda scary too
'83 1.6TD
DX 5 Speed
"Whistler"
www.sinisterbikes.com |
RGS Paul Samba Member
Joined: April 20, 2007 Posts: 681 Location: Los Alamos, NM
Posted: Fri Jun 04, 2010 5:44 am Post subject: |
There are also companies that make boards of LED's that you could probably put in place behind the stock lenses. Check out Superbright LED's to see what I mean, they are the PCB Series Lamps. I looked at doing this and came to the conclusion that it wasn't interesting enough for me to follow, bulbs suit me just fine. I have considered going to a Land Rover/G-Wagen style light housing instead of the stock VW one, bigger more simple lenses for people to see.
One suggestion, don't rush this and hack at it with what you can find at the truck stop. Take the time to really engineer a solution otherwise it will be a nightmare. Tail lights are kind of important, don't want to get smacked up the rear!
Have fun,
Paul _________________ '87 Syncro 7-Pass. Adventure Touring Vehicle
"Simplicate, then add lightness." Colin Chapman |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15351 Location: Syracuse, NY
Posted: Fri Jun 04, 2010 6:59 am Post subject: |
My brother did this with his van (wiring was burnt from engine fire anyways) and it's the SHYT for night & rain & fog and anytime visibility is limited.
there's just NO SUBSTITUTE for better rear visibility on these vans, they are far to precious for some latte drinking cell phone using distracted parent with a dog on their lap to miss that on a rainy/snowy/foggy night
Especially with a few of the stock van colors that just dissapear on a wet night.
I added small LED red rear marker/clearance lights to mom's Bronze gold metallic westy to improve night time visibility. and will be doing the 4" round dual/quad LED tailight upgrade this summer.
the light output from my brother's is brilliant during daylight. you certainly get the attention. _________________
Abscate wrote: |
JeffRobenolt  Samba Member
Joined: February 25, 2007 Posts: 1531 Location: Wisconsin
Posted: Fri Jun 04, 2010 12:24 pm Post subject: |
Cmon Dan, we need pics!! _________________ For OEM Subaru and SixStar parts and harness modications
AVsubaruconversions.com |
deusexmaxima Samba Member
Joined: May 22, 2010 Posts: 42 Location: Southern Cal
Posted: Fri Jun 11, 2010 10:06 pm Post subject: |
I cant believe no one has made LED tails for the Vanagon. |
911pickup Samba Member
Joined: March 06, 2004 Posts: 625 Location: Near Goats on the Roof
Posted: Fri Feb 24, 2012 8:05 pm Post subject: |
Just because the bulbs are LED doesn't mean they will be brighter. Here' a quote from Superbrightled.com:
Brightness of LED Car Bulbs
Standard LED bulbs are generally not as bright as standard incandescent bulbs, they have many advantages over filament bulbs (longer life, faster on/off times, lower power consumption, more vivid colors) but brightness is not one of them. They are generally not as bright but some of them with large numbers of LEDs, will appear brighter than filament bulbs. As an exception, our High Power LED car bulbs are as bright or brighter than most standard filament car bulbs. The light is distributed differently so they can appear brighter in some applications and not as bright in others, it depends on the size and shape of the bulb housing and reflector. |
Posted: Fri Feb 24, 2012 8:22 pm Post subject: |
jrobewesty wrote: |
Cmon Dan, we need pics!! |
these are my taillights not brake lights (same as my brothers quads) in fall 3pm daylight
in the shadow though of Franconia Notch, NH
sorry for image size
I have these installed, it's fairly plug & play no modifications to the stock metal or wiring.
and this is the only image I have of mom's upper 2"round LEDs
there's 3 across the rear and 1 on each back corner side.
Abscate wrote: |
