To ceramic coat, or to not ceramic coat That is the question
Page: 1, 2, 3, 4, 5  Next
JustBuggy
JustBuggy is offline
PostPosted: Wed Feb 15, 2012 8:47 pm    Post subject: To ceramic coat, or to not ceramic coat That is the question Reply with quote
I've been hearing about ceramic coating. It sounds like the ceramic coat is applied to the tops of the pistons and the combustion chamber. Is this a good thing and if so why?
Would this work on a turbo engine?
vwracerdave
vwracerdave is offline
PostPosted: Thu Feb 16, 2012 5:42 am    Post subject: Reply with quote
It works well on a very high end race car where your racing for a world record or a National championship. On a street car or an off-road play car your wasting your money.
JustBuggy
PostPosted: Thu Feb 16, 2012 6:01 am    Post subject: Reply with quote
What if it was offered to you for free?
mark tucker
mark tucker is offline
PostPosted: Thu Feb 16, 2012 6:21 am    Post subject: Reply with quote
if it is done properly do it,I have it on my street car motors,most of the heat go,s out the exhaust.also coat the bearings&rocker& bushings&lashcaps ,cam gear with dfl.
ALB
ALB is offline
Then I would take it. The idea or theory is it keeps the heat where it's supposed to be, and whether barrier coating the combustion chambers and piston tops is worth it in a higher end street motor is only determined by the budget and analness of the owner. If started, this debate could go on for a while...
On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!!
JustBuggy
PostPosted: Thu Feb 16, 2012 6:28 am    Post subject: Reply with quote
This sounds ideal for a turbo engine!
What is DFL?
Rocket Jim
Rocket Jim is offline
PostPosted: Thu Feb 16, 2012 6:48 am    Post subject: Reply with quote
If coating the combustion chamber and tops of pistons a good idea then wouldn't coating the entire exhaust port be a good idea?
yamaducci
yamaducci is offline
PostPosted: Thu Feb 16, 2012 7:12 am    Post subject: Reply with quote
Calico Coatings in NC does all the NASCAR engine parts. I also had them do all the bearings and they turned out fantastic. If the heads were fully disassembled I would have done the combustion chambers and exhaust ports.
The tops of the pistons also get the heat rejection coating like chambers and ex ports. The outside of the heads can get a heat dissapation coating. For me it was a matter of timing. While the heads were out in California being put back together I discovered they needed to be apart to have the chambers done. The pistons were also at another shop. Now that I know and still on the quest for better cooling for my tubo engine; I would do it for the added benefit on next rebuild. For now I am working on adding two fins to the CE heads to manage heat.
-John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
3rd Brake Light Safety Stars- I still have a couple with blue light left. Email me if interested.
JustBuggy
PostPosted: Thu Feb 16, 2012 7:17 am    Post subject: Reply with quote
Do I get this right? They only coat the combustion chamber in the head and not the tops of the valves?
yamaducci
PostPosted: Thu Feb 16, 2012 9:13 am    Post subject: Reply with quote
There are coatings for everything. It depends on what you feel will give the most benefit and how big your wallet is.
Calico and others will suggest piston top ceramic heat repell, Skirt dry lube, Heat repell in the chambers, valves and exhaust ports and heat dissipation coating on the entire outside of the head. The heads should be all apart including guides.
If you wanted to go wild you could dry lube the springs, valve stems, lash caps, rocker bushings, shafts, pushrod cups....
Take a look: http://www.calicocoatings.com/industries/coating-solutions/automotive-racing/
Also the diamond coating is like the "SLR" treatment to cams and lifters.
-John Cox
mark tucker
PostPosted: Thu Feb 16, 2012 1:37 pm    Post subject: Reply with quote
yes my export is also coated with ceramic then dfl on top of it,and the intake ports are dfl as are the intake valve backs&ceramic on the face&the exhaust valve has it on both sides.
JustBuggy
PostPosted: Thu Feb 16, 2012 11:42 pm    Post subject: Reply with quote
I've also read about the dry film lubricants. This sounds like a good thing as well. How do you apply them?
mark tucker
PostPosted: Thu Feb 16, 2012 11:45 pm    Post subject: Reply with quote
same method,just different coating.I use both.
JustBuggy
PostPosted: Fri Feb 17, 2012 8:19 am    Post subject: Reply with quote
Thank you Mark, I'm going to have to look these guys up!
I'm not trying to build a super hot racing engine. However I will be using the stock cooling fan and tins along with the turbo.
I'd like to do what I can to keep as much heat out of the head and in the exhaust as possible. Seems to me to be a smart thing being exhaust heat does serve a good purpose and I don't want to overheat the heads.
mark tucker
PostPosted: Fri Feb 17, 2012 8:23 am    Post subject: Reply with quote
yup keep a kool head there.
I wonder if coating the sourounding tin would let the compartment stay cooler, probably would.
gimmesomeshelter
gimmesomeshelter is offline
PostPosted: Fri Feb 17, 2012 12:33 pm    Post subject: Reply with quote
Hello-
If you're seriously interested in ceramic coatings, you should talk to Jake Raby. He's experimented with many coating combinagtions, and will be able to send you in the right direction.
Cheers,
Paul
"I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman
JustBuggy
PostPosted: Fri Feb 17, 2012 6:39 pm    Post subject: Reply with quote
I'd love to hear what Jake says about this subject!
OOooohhhh, Jake?
Cool
Chris659
Chris659 is offline
PostPosted: Fri Feb 17, 2012 8:21 pm    Post subject: Reply with quote
Coating the exhaust header will keep more heat in the pipes and away from the heads some too.
I was also thinking about doing the underside the tins and leave the side facing the engine satin black like stock. Would I need the same type of coating as the exhaust or is it something different that I would need?
Jake Raby
Jake Raby is offline
PostPosted: Fri Feb 17, 2012 8:51 pm    Post subject: Reply with quote
My coating development has been focused on engine internals.
Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell"
Rocket Jim
PostPosted: Sun Feb 19, 2012 3:17 pm    Post subject: Reply with quote
What are the costs of having combustion chambers and pistons ceramic coated?
Page 1 of 5
