schoonerman Samba Member
Posted: Wed Feb 15, 2012 10:33 pm Post subject: spice rack |
Found this spice rack at Ikea and fits perfect on the door under the sink
even the colour matches.
_________________ 87 Westy/Vanagon |
SteelB12 Samba Member
Joined: December 21, 2010 Posts: 591 Location: Central Virginia
Posted: Wed Feb 15, 2012 11:32 pm Post subject: |
Does it come with all the spices in the bottles?? _________________ 1987 Westy |
SCM Samba Member
Joined: January 26, 2011 Posts: 3351 Location: Bozeman MT
Posted: Thu Feb 16, 2012 8:29 am Post subject: |
I made and installed a knife rack in that same location. I should post a pic later on since it's the best mod I've done to my camper so far. I took two thin bamboo cutting boards, cut dados into one peice to fit the knife blades, then glues the halves together, and screwed in place on the door. It works really well and keeps sharp things from moving around while I'm driving. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
joseph928 Samba Member
Joined: September 22, 2011 Posts: 2114 Location: flagstaff az.
Posted: Thu Feb 16, 2012 8:31 am Post subject: rack |
I like it. To bad I have to go 140 miles to an ikea store.  _________________ 1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug. |
campism Samba Member
Joined: September 07, 2007 Posts: 4665 Location: Richmond VA
Posted: Thu Feb 16, 2012 8:57 am Post subject: |
SCM wrote: |
I made and installed a knife rack in that same location. It works really well and keeps sharp things from moving around while I'm driving. |
Knife block for me, too. Others have installed magnetic holders for the knives. We actually keep spices overhead in what is generally called the "spice rack" in a Westy but which officially called a "curtain tray."
windnsea Samba Member
Joined: May 07, 2008 Posts: 424 Location: Pasadena, CA
Posted: Thu Feb 16, 2012 9:07 am Post subject: |
Humm...
So if you are a user of medical marijuana maybe you could cut a hole in the floor, hide a little floor safe down there and put in a 'spice rack' inside the safe.
Just Joking! |
Posted: Thu Feb 16, 2012 11:06 am Post subject: |
SteelB12 wrote: |
Does it come with all the spices in the bottles?? |
No, put in your favourites
I like the idea of a knife rack as well, may have to change things a tad _________________ 87 Westy/Vanagon |
keithwwalker Samba Member
Posted: Thu Feb 16, 2012 5:45 pm Post subject: |
No need. I figure I'll add a couple of Dead stickers and they'll leave me alone.
Ba-dump-ching! |
SCM Samba Member
Posted: Fri Feb 17, 2012 4:35 pm Post subject: |
campism wrote: |
I'll add a couple of Dead stickers ...! |
LOL, the one thing I feel I paid WAAAY too much for on my Westy is the "Play Dead" sticker. I'm embarassed to say how much so I won't. But here's a few pictures of my knife rack and my "spice bandolier".
The spice holder is sewn with 2-inch elastic webbing with a pocket at one end for whatever bendable metal you want to slide in there. I used an old hose clamp, cut off the screw, and sewed the pocket shut. The bottles are plastic food grade things from REI. I like it because it fits in any nook or cranny in the van and you can hang it from the curtain rail/shelf for super easy access when you're cooking.
owokie Samba Member
Posted: Mon Jun 12, 2017 3:54 pm Post subject: Re: spice rack |
Ever since I put the fridge door on the rear cabinet I've wanted to install a spice rack/shelf along the line of rhino designs but inset just behind the useless door and with more space. Had some time to finish and install today. I may remove and relocate the door/hinges permanently but will leave it on for now, extra protection from flying objects when driving. Pretty straightforward, shelves are repurposed from the rear heater cover I removed, brown bungee cord to hold things in place, and color-matched paint on the rest (which has held up surprisingly well on my fridge door).
VanAllen_84 Samba Member
Joined: October 17, 2016 Posts: 55 Location: Ventura County
Posted: Mon Jun 12, 2017 4:31 pm Post subject: Re: spice rack |
owokie wrote: |
Thought about the Rhino Design spice rack, but this is just freaking brilliant and an even better idea!! Would love to see pics of the inside and how you mounted shelves on the inside.
And you should definitely keep the door to protect against those unwanted flying projectiles!!
NICE WORK!!! _________________ 1984 VW Vanagon Westfalia 1.9L Water-cooled (aka "Osmo") |
Wellington Samba Member
Joined: September 21, 2004 Posts: 1994 Location: Montreal
Posted: Mon Jun 12, 2017 6:14 pm Post subject: Re: spice rack |
brilliant! |
