License plate light
jrob83046
jrob83046 is offline
PostPosted: Mon Oct 25, 2021 10:50 am    Post subject: License plate light Reply with quote
License plate not working on my 70 VW. The blub was bad. I replaced that and hooked it up directly to a battery I have. The light works. The wires were cut and it wasn't hooked up. I found the wires behind the fan shroud but no power to them. I had really not rather try to run the problem down. My question is would it be alright to the coil the hot coil wire. When I turn the ignition on the light would be on. Just wondering if this would be a problem. Thanks
Cusser
Cusser is offline
PostPosted: Mon Oct 25, 2021 11:16 am    Post subject: Re: License plate light Reply with quote
The license plate light feed comes from a connector behind the tarboard on the right hand side, and the license light also needs its ground wire connected.
Do you have operational tail lights??? You could wire to those, it's the same circuit. If no tail lights working, investigate those first, bigger safety issue. Each side has its own ground connection tab, behind the tarboards.
KTPhil Premium Member
KTPhil is offline
PostPosted: Mon Oct 25, 2021 11:18 am    Post subject: Re: License plate light Reply with quote
Bad idea. The coil circuit is unfused. If your license lamp shorted you'd fry the ignition wire from the coil up to the ignition switch.
Cusser
Cusser is offline
PostPosted: Mon Oct 25, 2021 12:05 pm    Post subject: Re: License plate light Reply with quote
Bad idea. The coil circuit is unfused. If your license lamp shorted you'd fry the ignition wire from the coil up to the ignition switch.[/quote]
Yes, very bad idea. Fix it correctly. Lots of folks on this site are dealing with mickey-mouse wiring on their VWs from previous owners.
ashman40
ashman40 is offline
PostPosted: Mon Oct 25, 2021 2:29 pm    Post subject: Re: License plate light Reply with quote
Not sure why, but many people find that the PO disconnected their reverse lights. The reverse light wires are black and sit in front of (front being front of car) the fan shroud. Are you maybe confusing the license plate lamp wires with the reverse light wires?
As Cusser pointed out, the license plate lamp is basically a second right rear parking light. In the below pic of the right side taillight wiring junction...
You can see two junctions, the 6-wire junction and a 3-wire Y-junction. The Y-junction is where the single grey/red wire splits into a grey wire that runs to the taillight and a grey/blue wire that runs to power the license plate lamp. The grey/blue wire eventually meets up with a solid brown wire which is a ground wire. These two wires run to the license plate lamp. Make sure you don't mix them up anywhere along the way. If you accidentally connect the grey/blue wire to the ground position on the license plate lamp assembly it could directly short the power wire to ground and cause the fuse to blow.
AshMan40
jrob83046
PostPosted: Mon Oct 25, 2021 4:10 pm    Post subject: Re: License plate light Reply with quote
I do have tail lights. No back up lights. I do have a fuse coming off the coil. I will check the wiring by the picture shown. I would like to fix it right. The wiring looks pretty well stock to me. I will post what I find. Thanks for the help.
ashman40
ashman40 is offline
PostPosted: Mon Oct 25, 2021 4:33 pm    Post subject: Re: License plate light Reply with quote
Post some pics. The fuse coming off the ignition coil #15 (+) terminal normally runs to the reverse light switch at the front nose cone of the transmission before splitting to the left/right reverse lights in the taillight assemblies. All of these wires were black right up to the taillight junction where they turned into blue wires that ran to the reverse lamp in the taillight assembly.
AshMan40
KTPhil is offline
PostPosted: Mon Oct 25, 2021 4:41 pm    Post subject: Re: License plate light Reply with quote
Old reverse light switches tend to short out, typically leading to instant ignition kill when shifted into reverse. Most folks don't understand the circuit and either remove the fuse or cut the wire so it will run.
They are relatively cheap and easy to replace, with minimal oil spillage.
Cusser
Cusser is offline
PostPosted: Mon Oct 25, 2021 6:47 pm    Post subject: Re: License plate light Reply with quote
That's very true !!! Most folks are idiots when it deals with electrical !!!
jrob83046
PostPosted: Tue Oct 26, 2021 6:07 am    Post subject: Re: License plate light Reply with quote
I hate to say I'm a idiot but when it comes to electrical i am really close. Lol. That is a weak point I have always had.
Starbucket
Starbucket is offline
PostPosted: Tue Oct 26, 2021 2:19 pm    Post subject: Re: License plate light Reply with quote
I can't believe ashman40 posted a pic with a house hold wire nut and not saying never use one of these in your car. Laughing
Cusser
Cusser is offline
PostPosted: Tue Oct 26, 2021 4:32 pm    Post subject: Re: License plate light Reply with quote
That could be a crimp connector just different from a traditional butt connector; called a closed-end crimp connector.
https://www.google.com/search?q=Closed-End+Crimp+C...p;biw=1408
jrob83046
PostPosted: Tue Oct 26, 2021 6:27 pm    Post subject: Re: License plate light Reply with quote
Got it. I was looking at the wrong two wires behind the fan. I found two that had been cut. Checked for power with the lights on and had it. Like I said the wires had been cut at one point. I hooked them back up and it works fine. Thanks for the suggestions.
