wolfywho Samba Member
Posted: Wed Apr 25, 2012 4:36 pm Post subject: Wiper Switch Identification - Part #: 111955517C |
Hey guys,
I purchased this NOS switch to replace my broken switch. It is a 111955517C windshield wiper switch. It has a push button for the washer fluid, as expected. It is a 1 speed switch, as expected. It's a "twist" on/off, instead of a "push/pull" on/off switch. Trying to ID what it's from. Bought it from a guy in France to replace my '66 Beetle wiper switch, but noticed that it's not a push/pull switch when I received it. My old one is a push/pull on/off switch, and the '66 Beetle manual states that it's push/pull as well. Maybe they were twist style in the European market?
_________________ '66 Beetle Project & My 1983.5 SVX Powered Vanagon Westfalia
http://www.vwblvd.com/
YouTube Channel
http://www.youtube.com/user/wolfywho
1966 VW Beetle - Body Removal - One Person - Remove Body Chassis Bug - (2x Speed)
http://www.youtube.com/watch?v=RAe4wcvIp1E |
glutamodo The Android
Joined: July 13, 2004 Posts: 26429 Location: Douglas, WY
Posted: Wed Apr 25, 2012 6:30 pm Post subject: |
Oh, there's a 1967 1300A-1300-1500 European Owner's manual in the Technicial archives... it does say to turn the switch.
I think that at some point SWF started making all switches in the twist style... if it's got the square body it's twist.
-Andy |
Posted: Wed Apr 25, 2012 8:01 pm Post subject: |
Thanks Andy. I saw that too, but I thought they went to a 2 speed wiper motor/switch in '67. Figured it wasn't relevant to this particular switch. Were there 1 speed wiper motors in '67? _________________ '66 Beetle Project & My 1983.5 SVX Powered Vanagon Westfalia
YouTube Channel
Posted: Wed Apr 25, 2012 8:45 pm Post subject: |
Yeah, those particular Euro models were all 6V, and single speed wiper motors. The USA got 12V, and the two speed wipers for Bugs, a year ahead of the rest of the world. |
Posted: Thu Apr 26, 2012 3:59 am Post subject: |
glutamodo wrote: |
Interesting stuff. Thanks Andy. It seems I have a 1 year only part here then? A '67 European Single Speed Wiper Switch.
-wolfy _________________ '66 Beetle Project & My 1983.5 SVX Powered Vanagon Westfalia
YouTube Channel
KombiMarc Samba Member
Joined: January 29, 2010 Posts: 431 Location: Phoenix, Az
Posted: Thu Mar 27, 2014 8:19 pm Post subject: |
Ok dumb question, I bought this same switch to put in my 65. Not realizing it's wrong switch. I have 12v system if this is 6v switch can't be good to use? Any sparkles out there that can help? _________________ ________________
Thanks Marc
________________
'65 Type I
'65 Type II Kombi Rebuild Thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=459009 |
Posted: Fri Mar 28, 2014 6:49 am Post subject: |
Switches are fine for 6V and 12V. However they are different from single speed vs two speed wiper motors. What do you have? You can make different combinations work though:
Posted: Fri Mar 28, 2014 8:09 am Post subject: |
Awesome info!! Although the switch I have only has 4 tabs on it. 54 54d, 31 and 31b. My wiper motor must be a 6 volt cuz it only has the tabs. I'll post some pics. Thanks in advance!! _________________ ________________
Thanks Marc
________________
'65 Type I
Posted: Fri Mar 28, 2014 2:28 pm Post subject: |
Ok here is the switch I have
Pic 2
And here is the electrical side of the wiper
Three codes match to wiper motor codes, except 31. Is that power to switch? _________________ ________________
Thanks Marc
________________
'65 Type I
Posted: Fri Mar 28, 2014 5:36 pm Post subject: |
31 is a ground. The switch should ground just by being bolted to the dashboard. The 31 tab there is actaully a tab to connect other items needing a ground point up to. The wiper itself is grounded via the brass tab on the mounting bolt at grommet where it bolts to the cowling.
as in the diagrams I posted above, power in is 54. |
Posted: Fri Mar 28, 2014 6:06 pm Post subject: |
Oh, so power to 54, from same tab power to motor and then just match up 54d and 31b to motor?
Will give it a try, thanks! _________________ ________________
Thanks Marc
________________
'65 Type I
coxbzh Samba Member
Joined: March 01, 2016 Posts: 22 Location: Brest meme
Posted: Fri Feb 14, 2020 3:51 am Post subject: Re: Wiper Switch Identification - Part #: 111955517C |
hello
Excuse me but on the first assembly what we connect on terminal 31?
this is the montage I'm trying to do
Best regards
David |
Posted: Fri Feb 14, 2020 7:57 am Post subject: Re: Wiper Switch Identification - Part #: 111955517C |
I already said it above, that the switch itself grounds just by being bolted to the metal dashboard, and the switch terminal 31 is more of a ground tap than anything else. I guess that if you were trying to test a switch and wiper motor off the car, then you would want to hook 31 to ground.
In practice, terminal 31 on the wiper switch was a ground source for things like the ground connection for the high/low beam switch on the 1967 turn signal arm. _________________ Andy T.
"What is Glutamodo, Horror of Toyko, besides total, fiendish, quality-a-you brain!" |
coxbzh Samba Member
Posted: Fri Feb 14, 2020 11:05 pm Post subject: Re: Wiper Switch Identification - Part #: 111955517C |
Ok thanks! |
Big Bill Samba Member
Joined: June 21, 2005 Posts: 1803 Location: Fortuna Calif.
Posted: Mon Oct 12, 2020 6:26 am Post subject: Re: Wiper Switch Identification - Part #: 111955517C |
Does anyone have a photo of the Mounting/Grounding tab that glutamodo talks about. Mine has the threaded tab on the cowl but I cant see where it attaches to the wiper motor itself it may not even be the correct wiper motor. The brass tab is also not present. Thanks |
Posted: Mon Oct 12, 2020 8:12 am Post subject: Re: Wiper Switch Identification - Part #: 111955517C |
The 31 ground tab on the switch location depends on who made the switch, what part number it was and when it was made. I don't know when it was added to the single speed switch, it might have been on non-USA 1967 6V models, as that's when you first saw it on the USA 12V 1967 switches. The 1967 switch is what I mostly am talking about, in finding ways to make it work on the 1966/older applications.
The switch itself, is bare metal where it meets the dashboard, and that is how it gets its ground. _________________ Andy T.
Posted: Mon Oct 12, 2020 8:19 am Post subject: Re: Wiper Switch Identification - Part #: 111955517C |
Thanks Andy T I am actually talking about the wiper motor itself. It looks like there is a threaded ear attached to the cowl that is a support for the wiper motor itself?? Mine may have the wrong motor I am not sure first 67 I have owned, alot to learn about this year model. Thanks Bill * EDIT* I will post a photo of the area I am confused about. |
Posted: Mon Oct 12, 2020 12:39 pm Post subject: Re: Wiper Switch Identification - Part #: 111955517C |
Beautiful just what I was looking for ...Thank You. |
