Blinky & Temp Gauge
VwDubber
VwDubber is offline
PostPosted: Sun Feb 26, 2012 1:25 pm    Post subject: Blinky & Temp Gauge Reply with quote
Quick Question.
Noticed that sometimes my Temp Gauge dosent move even after the engine has run many miles and then will suddently come up to the middle of the gauge where it always like to run. Also noticed that my Blinky light is sometimes acting funky. Not sure why, just wondering if it could be the gauge itself or connection in the Dash Cluster, I don't see any other common item?
Timwhy
Timwhy is offline
PostPosted: Sun Feb 26, 2012 3:46 pm    Post subject: Reply with quote
All of the above or none of the above! It seems that there isn't a one size fits all for each and every situation.
Maybe try cleaning the temp sensors' connections and adding a little dielectric grease to those connections?
'15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
VwDubber
VwDubber is offline
PostPosted: Sun Feb 26, 2012 4:26 pm    Post subject: Reply with quote
Well the problem is getting even stranger. Now my dash lights won't light and when I try to turn the brightness wheel my tach stops, and my oil and high beam lights come on very slightly. If I move the brightness wheel those lights go away but no dash lights.
Gone to take a look at it when I get a chance..
Maybe it's a poor ground etc? Rolling Eyes
seanjenn
seanjenn is offline
PostPosted: Sun Feb 26, 2012 5:08 pm    Post subject: Reply with quote
Yeah..it could be ground related, most of the dash grounds are directly above the fuse panel, pull the panel to get to them. There are two "crowns" up in there.
Take a close look at the big plug on the back of the cluster. All good? Fit nice and tight?
Maybe ignition switch related, doubt it, but maybe. Stranger things have been known to happen with a Vanagon.
1987 GL Sunroof
2.1 4 spd
crazyvwvanman
crazyvwvanman is offline
PostPosted: Sun Feb 26, 2012 6:08 pm    Post subject: Reply with quote
yes, that is classic behavior of a bad cluster ground.
Mark
tencentlife
tencentlife is offline
PostPosted: Sun Feb 26, 2012 6:39 pm    Post subject: Reply with quote
...or the 14-pin not being seated.
crazyvwvanman
PostPosted: Sun Feb 26, 2012 7:14 pm    Post subject: Reply with quote
Yep, the cluster ground goes through the 14 pin.
mark
Drifty84
Drifty84 is offline
PostPosted: Sun Apr 08, 2012 11:39 am    Post subject: Reply with quote
The dreaded blinky coolant level sensor has been the most recurring and annoying malfunction I've experienced in the seven or so years I've owned my '84 Westy. I've fixed and re-fixed it at least five times. It's been random and intermittent at times, but the "warning" function, i.e., flashing red light and full hot needle, has been a false alarm every single time. I have fixed it both by cleaning the contacts and replacing the coolant level sensor itself. But it always came back sooner or later.
I believe I FINALLY figured out the root cause of the problem and why it has kept recurring after time. The male contact blades on the coolant level sensor are steel and the female receptacles on the stock wire connector are brass. Not only do ferrous to non-ferrous contacts sometimes create problems such as electrolysis that frequently causes corrosion between the two metals, especially in high humidity environments, but steel and brass have different expansion/contraction characteristics in response to temp changes. This last time I noticed that the false blinky would not occur until the temp reached or approached normal operating range. That reminded me of other times when the warming of an electrical connection caused an open to occur. I surmised, apparently correctly, that the brass female was expanding more than the steel male, causing enough loss of contact between the two to trigger the blinky sequence.
I fixed the problem (I HOPE) simply by mashing the brass female connector slots slightly to make a very tight fit over the male CLS blades and slathering them liberally with dielectric grease. After a weekend of driving, no blinky. I'll repost if I prove myself wrong about all the above. But I'm optimistic right now.
'84 Westy, 1.9 4 spd.
GW 15" wheel & tire pkg.,
Hella H4 headlight kit,
Vano Shifter fix kit
RMW Stainless Exhaust
dubbified
dubbified is offline
PostPosted: Sun Apr 08, 2012 2:51 pm    Post subject: Reply with quote
Yo, that sounds like what I need to get on.. Intermittent oil light/temp, bayside wiring is all in order. Course, I've also got some other issues, missing Tach.. no power to rear wiper.. no power to hvac.. presently using a patch connection..
Krikey. I need to get these ironed out.. but this atleast gives me another lead to play with.
dubbified
PostPosted: Tue Apr 10, 2012 12:58 pm    Post subject: Reply with quote
The crazy thing, is I place the van in neutral, switch the van off, then fire it right back up, no buzzer.
Left turn, the buzzer/light go off.
Intermittent blink on temp and temp guage as well..
I need to check them contacts I think.
Drifty84
Drifty84 is offline
PostPosted: Wed Aug 29, 2012 1:13 pm    Post subject: Reply with quote
OK, I give up. After my post above just four months ago, Blinky is back. Evil or Very Mad I'm through playing this game. So I jumped the connector plug with a piece of wire and now I have no more Blinky. However, I also have no CLS warning light. But since the CLS Blinky disables the temp gauge (by sending the needle to full hot regardless of actual temp Rolling Eyes ), I much prefer a full time functioning temp gauge over the Blinky. I check the oil and coolant levels before every drive anyway.
With the CLS circuit hard wired closed, the Blinky test sequence still activates at start-up, as usual. (Although for a shorter period of just 2-3 blinks.) My question is, will Blinky still function as a high temp warning light in the event of an actual over-heating event?
MicahBF
MicahBF is offline
PostPosted: Wed Aug 29, 2012 1:30 pm    Post subject: Reply with quote
The blinking light never functions as a high temp warning light, it is only a low coolant warning light wired to the expansion tank.
Drifty84
Drifty84 is offline
PostPosted: Wed Aug 29, 2012 3:50 pm    Post subject: Reply with quote
If that's the case, it would seem to make even more sense to disable the CLS completely, since it throws false alarms so regularly as to make it virtually useless for its intended purpose and disables the temp gauge in the process.
AdrianC
AdrianC is offline
PostPosted: Thu Aug 30, 2012 1:34 pm    Post subject: Reply with quote
Gotta admit, I _love_ low coolant sensors. They're also great advance warning of a drip or slight leak, before the low level causes a REAL problem.
But - having said that - my blinky doesn't seem to send the gauge to full hot... It does work just fine on the level, though. It didn't used to, but then I took the sensor out the header tank and gave it a damn good clean.
Adrian
Zookeeper of a miscellany of motoring silliness, from 0.75bhp to 9ft tall.
Living life on the road in an '88 2.1DJ Westfalia Club Joker Hightop.
www.WhereverTheRoadGoes.com
crazyvwvanman
PostPosted: Fri Aug 31, 2012 11:17 pm    Post subject: Reply with quote
False. The temp gauge led is first and foremost a high temp warning led. The coolant level warning system was added later. The led serves both functions in watercooled vans starting in 83. The watercooled vans before that, and I mean diesels from 81 and 82, had only the high temp warning led. The coolant level warning circuit was added to and connects to the same wire that comes from the temp gauge sender. The relay fools the gauge blinker circuit into thinking the engine is too hot. The first version of the relay makes the led blink and makes the needle rise to full hot whenever the relay detects coolant level low in the tank. The later versions of the relay used from mid 85 on makes the led blink when coolant is detected low but lets the needle position reflect the engine temps. Any version of the relay will work in any year but the 85+ versions are best because they let the needle still read engine temp while the coolant warning is triggered. This has been covered in detail here several times, including photos and part numbers of the different versions of the relay.
To disable the coolant level warning system the best way is to remove the coolant level warning relay. The complete system is simple enough to fix that disabling it is foolish but what can you do. This is the internet so foolishness abounds.
Mark
