Front brake caliper mounting orientation.
3foldfolly
3foldfolly is offline
PostPosted: Mon Sep 26, 2022 2:59 pm    Post subject: Front brake caliper mounting orientation. Reply with quote
68 Ghia with single pin. When caliper is mounted on car is the bleeder valve at the top or bottom of the caliper? Should of took a picture before I removed both calipers.
rcooled
rcooled is offline
PostPosted: Mon Sep 26, 2022 8:01 pm    Post subject: Re: Front brake caliper mounting orientation. Reply with quote
The valve should be at the top.
'63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
3foldfolly
PostPosted: Tue Sep 27, 2022 8:39 am    Post subject: Re: Front brake caliper mounting orientation. Reply with quote
After reading another thread that stated to bleed the upper bleeder valve on a caliper with 2 bleeder valves I was fairly certain the bleeder should be at the top. Your comment confirms this. Thank you!
