Busdepot dual battery relay
tizzfishin
tizzfishin is offline
PostPosted: Sun Jul 10, 2022 2:13 pm    Post subject: Busdepot dual battery relay Reply with quote
Has anyone here had the bus depot dual battery relay fail? Last night I was checking the engine compartment and noticed the wire that goes from the starting battery to the relay had fried and split. I replaced then wire and 15amp fuse on the relay but i don’t see a voltage spike from the alternator on the house battery anymore.
1971 westy
"An idea that is developed and put into action is more important than an idea that exists only as an idea"
tizzfishin
PostPosted: Sun Jul 10, 2022 3:22 pm    Post subject: Re: Dusdepot dual battery relay Reply with quote
With the hella type relay should the voltage spike to 14+ on the second battery when running like the starter battery does?
1971 westy
busdaddy
busdaddy is offline
PostPosted: Sun Jul 10, 2022 3:49 pm    Post subject: Re: Dusdepot dual battery relay Reply with quote
I can't imagine how a relay alone could cause that, unless you wired it wrong.
Слава Україні!
tizzfishin
PostPosted: Sun Jul 10, 2022 4:17 pm    Post subject: Re: Dusdepot dual battery relay Reply with quote
I think the wire may have gotten pinched and that’s why it shorted and fried.
1971 westy
