window seals '71
djspn
djspn is offline
PostPosted: Wed May 30, 2012 8:29 am    Post subject: window seals '71 Reply with quote
I've search a lot of window seal threads lately, it seems the quality of the seals changes w time w the various vendors.
I want to replace the 3 side window seals on the windows that have vents (not the seals on the vents).
I want to order some other parts at the same time, is the quality of the Wolfsburg West seals as good as any these days?
I didn't see any threads that dealt w changing the seals on these windows w vents, is the procedure basically the same as the rear and non vented side window? I have experience w them.
Thanks
cr@M
cr@M is offline
PostPosted: Wed May 30, 2012 10:28 am    Post subject: Reply with quote
The WW ones are good quality. I recently did mine with their chrome trim set and installation wasn't hard. The 90* corners are a a bit tricky, but plenty of Windex and patience got them in just fine.
1972 Deluxe named Lucidity
1973 Transporter
"He who fights with monsters must see to it that he himself does not become a monster...
when you gaze long into the abyss, the abyss also gazes into you."
-Friedrich Nietzsche
djspn
djspn is offline
PostPosted: Thu May 31, 2012 8:29 am    Post subject: Reply with quote
Thanks cr.
Peace
'71 Bus .....stock running gear [ex SVDA and pertronix]
