Painting a Transmission
JayC
JayC is offline
PostPosted: Thu Jun 07, 2012 10:01 am    Post subject: Painting a Transmission Reply with quote
Hello All,
I'm in the middle of a restoration of a VW Thing and I am currently working on the transmission. While I have it out, i want to repaint it, primarily so it looks a better. I have already attacked it with a wire weel and cleaned up a lot of it, but because it has so many cracks, crevices, and indentations, I am thinking of just taking down to my local blaster and having them clean it up.
My question is: what do I have to worry about if it is blasted? What should I tell the blasting people to pay attention too? Specifically, I am concerned around the drive flanges. I don't think i have any leaks there at the moment, but can blast material get in through there? Should they be taped off before they do it (area circled in red below).
Also, on the bell housing, I am planning just the outside. I don't see a reason to do the inside.
Finally, any recommendations on paint? This is not a show car, just a fun project I am doing myself. Typically on all the suspension components, I have been using POR15 and then top coating. I think the POR15 would get all puddled up in the aforementioned nooks and crannies.
Thank you,
Jay
beetlenut
beetlenut is offline
PostPosted: Thu Jun 07, 2012 10:32 am    Post subject: Reply with quote
I cleaned mine up and used Master series products on mine. Took some time to mask off different areas, but I'm happy with the results
scrapyards are for quitters
Wetstuff wrote:
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again.
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104
JerryMCarter1
JerryMCarter1 is offline
PostPosted: Thu Jun 07, 2012 1:07 pm    Post subject: Reply with quote
man you have to have that thing sealed for a blaster -- Even then,, you should flush it
If you want it to last you have to shoot it with urathane -- auto paint -- no rattle can !
Jerry
Experience always triumphs over hearsay and You get to select which theory to believe
Matt K.
Paint and Body Nutcase
Matt K. is offline
PostPosted: Thu Jun 07, 2012 1:52 pm    Post subject: Reply with quote
Very nice detail!
This is my 23rd year in the Auto Body/Paint Game!
*Take a look at some of my custom paint: http://s110.photobucket.com/albums/n119/mrpaint_2006/ .( NOTE: these are some older jobs but still neat.)
BXRJIM
BXRJIM is offline
PostPosted: Fri Jun 08, 2012 1:06 pm    Post subject: Reply with quote
Don't give up yet JayC!
Buy some smaller wheels that you can fit into the crevaces and clean it up real good. Like Jerry said use good autopaint and you'll be a lot happier.
I used some old DP 40 I had in my cabinet and then Rustolium Hammered silver.
Your's looks real nice too beetlenut!
Jim
My new mission- '62 Ragtop
JayC
JayC is offline
PostPosted: Fri Jun 08, 2012 6:36 pm    Post subject: Reply with quote
Thank you guys... I'll keep on it. It actually looks better than my original picture (that was when it first came out).
Nice pictures!
jay
FRNKNSTNGHIA
FRNKNSTNGHIA is offline
PostPosted: Sat Jun 09, 2012 2:37 pm    Post subject: Reply with quote
I used lots of degreaser to remove the thick grudge with wire brush. Then i used gasoline to get out all the stuff in the crevices. After I got to the point where I was satisfied, I wiped it all down with paint thinner. Then I used VHT 5000 Degree primer followed by VHT High Temp Paint. Came out really good. Pic of tranny on my build thread.
