pghmike Samba Member
Joined: February 21, 2011 Posts: 24 Location: Pittsburgh
Posted: Fri Jun 08, 2012 9:31 am Post subject: cargo boxes on top of cab & on rear hitch |
| with an extended summer trip coming up and a family of five, i am looking to maximize cargo space... to challenge things a bit more than normal, we rock climb and will have shoes, harnesses, helmets, ropes and a ton of gear in addition to all the normal stuff... i have put tracks up top and a roof rack and thule box, but i want more... there is an Action Packer that is 43 long x 17 wide x 20 high which would seem to fit perfectly in the cargo space on top of the cab... i'm wondering how much that big box up front and high like that is going to kill my mpg... i'm also looking into the stowaway carrier on the swing away arm for the back... i am thinking it would be pretty convenient to utilize all three options (thule on top, action packer in front of that, and stow away in the back)... so two questions: 1. should that action packer up top and front be avoided? and 2. the people at stowaway have said that i need a tongue weight capacity of 300 lbs to haul their box on my rear hitch... will i be fine doing that in my 86 weekender? (i have a custom steel bumper w. 2" hitch) |
joseph928 Samba Member
Joined: September 22, 2011 Posts: 2114 Location: flagstaff az.
Posted: Fri Jun 08, 2012 11:02 am Post subject: to much gear |
Yes you can do all this, cost, lost MPG, hassle to get to all of this. Just get a small trailer, 150 lbs. aka harbor freight $400.00 this is what I did, and when I take the box off the trailer I can hall my Harley! Yes I had to build the box but that was easy.  _________________ 1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug. |
climberjohn Samba Member
Joined: January 11, 2005 Posts: 1840 Location: Portland Orygun
Posted: Fri Jun 08, 2012 12:59 pm Post subject: |
Try a search on < Rola >
This is a burly cargo bag that fits well on top of the cargo area over the front 2 seats. This search will also lead you to many related threads.
link to the bag:
http://www.amazon.com/Rola-59102-Expandable-Hitch-Cargo/dp/B000E7WLJW _________________ '86 Westy, 2.5 Subaru power
Know your limits. Exceed them often. |
j_dirge Samba Member
Joined: August 08, 2007 Posts: 4641 Location: Twain Harte, CA
Posted: Mon Jun 11, 2012 7:28 am Post subject: Re: cargo boxes on top of cab & on rear hitch |
| pghmike wrote: |
300lbs seems like overkill.. perhaps they are quoting this wieght if the box were full of heavy items?.. like sand bags or some such?
Stuff stored off the back or front.. and on top.. should be the lightest of your cargo. Sleeping bags, lawn chairs, etc. Keep tool boxes and water jugs inside, low, and centered, (if at all possible).
300lbs on the rear hitch is beyond most VW hitch capacities. Only a couple of aftermarket semi-custom products fit the bill.
And once you have a proper 300lb receiver in place, the VW suspension is not really up to the task in stock configuration. Many of the tires used on Westy are not really suited to those loads, either.
As CJ points out.. LOTS has been written on receiver/hitches, rear suspension, towing, cargo boxes, GVWR, etc.
Use the search. _________________ -89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
| danfromsyr wrote: |
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
presslab Samba Member
Joined: September 29, 2008 Posts: 1730 Location: Sonoma County
Posted: Mon Jun 11, 2012 7:49 am Post subject: |
How about on the front?
I keep my bikes on the back, and put my SCUBA stuff in the front.
If your custom hitch is stout, it should be ok. Sometimes I carry a dirt bike on the back (400 lbs all up) and this is too heavy for stock springs; I have air bags instead. _________________ 1986 Vanagon Westfalia EJ25
1988 Subaru GL-10 EJ20G --- 2000 Honda XR650L
2010 Titus El Guapo --- 2011 On-One 456 Ti |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15407 Location: Syracuse, NY
Posted: Mon Jun 11, 2012 9:31 am Post subject: |
WOOOT Air bags.. ;-p
| presslab wrote: |
If your custom hitch is stout, it should be ok. Sometimes I carry a dirt bike on the back (400 lbs all up) and this is too heavy for stock springs; I have air bags instead. |
| Abscate wrote: |
| These are the reasons we have words like “wanker” |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6344 Location: Portland OR
Posted: Mon Jun 11, 2012 9:39 am Post subject: |
300 lb tounge rating is just a rating. It doesn't mean you want to carry that much in a box off the rear. You'd be suprised how much force can be applied though even from a 50 lb load through the lever arm of a box and the bouncing motion of the road. It's much more than 300 lbs. _________________ 89 Westy 2.1 Auto |
GWTWTLW Samba Member
Joined: April 22, 2008 Posts: 2174 Location: Portland, OR
Posted: Mon Jun 11, 2012 9:45 am Post subject: |
| PDXWesty wrote: |
| You'd be suprised how much force can be applied though even from a 50 lb load through the lever arm of a box and the bouncing motion of the road. It's much more than 300 lbs. |
I always run a tie-down from the top of the hatch to the back end of the rack to reduce the stress from bouncing. I haven't had any issues. This will be my first trip with the GW bumpers though. My old hitch was welded to the tow hooks. _________________ 89 Syncro Westy - GW 2.5, now with a double knob job
@gwtwtlw |
JeffRobenolt  Samba Member
Joined: February 25, 2007 Posts: 1531 Location: Wisconsin
Posted: Mon Jun 11, 2012 9:57 am Post subject: |
It is real heavy, even empty
_________________ For OEM Subaru and SixStar parts and harness modications
AVsubaruconversions.com |
Posted: Mon Jun 11, 2012 10:10 am Post subject: rear box |
also notice the license plat and lights, in most states you have to do this! Can't count all the ones that don't do this, dumb and illegal!  _________________ 1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug. |
Posted: Mon Jun 11, 2012 10:14 am Post subject: Re: rear box |
| joseph928 wrote: |
also notice the license plat and lights, in most states you have to do this! Can't count all the ones that don't do this, dumb and illegal!  |
That's a great point. Cops are looking for anything to pull you over. Recently I was pulled over for my bikes on the back obscuring my license plate. Of course once they pulled me over they shone their lights all around the insides.
In the front my plate is all the way to the right, so you can still see it beside the cargo bins. _________________ 1986 Vanagon Westfalia EJ25
Posted: Mon Jun 11, 2012 10:18 am Post subject: |
| PDXWesty wrote: |
| 300 lb tounge rating is just a rating. |
Thats true.
I did an honest 325 lbs of tongue wieght when pulling my Moore 24 around town.. fairly regularly for over a year. Well beyond what I would recommend anyone do for any extended miles.
I'd not recommend more than 150-200lbs it without looking into mods like what Presslab has done with true airbag suspension. Even at 100-150lbs you'd probably want some load assist.
I am currently on load assist air shocks and s.org springs.. On this last trip I had about 200lbs off the back with 4 bikes on a tray and a big spare in close to body. Worked prettty well.. but I have $$$ into my suspension now... and I still ate a CV
I am working up towards another 80lbs on the rear for fuel and odds and ends. The CV failure has me moving towards 930s earlier than later. Maybe next month.
(Depends on what I find when I pull the boot and do some forensics.)
No way I'd do this again with OEM suspensions and tires. At least CVs are relatively cheap.  _________________ -89 GL Westy, SVX.. finally.
| danfromsyr wrote: |
WestyBob Samba Member
Joined: June 11, 2004 Posts: 2346 Location: Portland, Oregon
Posted: Mon Jun 11, 2012 10:34 am Post subject: Re: cargo boxes on top of cab & on rear hitch |
The action packer in the front westy luggage rack ... if full should give you slightly better aerodynamics than when the rack is empty regarding mpg's.
I have an older swing-away with cargo box .... it weighs 'tons' and wouldn't recommend for a westy except for maybe day trips.
Perhaps the front carrier like danfromsyr shows in the pic mounted in back with a cargo box attached would work well. You can get a less expensive, lighter version from Harbor Freight if there's one in Pgh.
Pulling a HF trailer with Thule/Yakima cargo boxes attached is not a bad idea as another mentioned if you don't mind dealing with trailers. DogPilot, no longer on this forum, had worked up a good version in a past thread that carried cargo plus bikes.
Bicycles and even jerry cans can be carried on a Gary Lee hatch ladder rack or a Paulchen-style hatch bike carrier. |
Posted: Mon Jun 11, 2012 11:24 am Post subject: Re: rear box |
| joseph928 wrote: |
We were stopped in Utah because our plate was blocked. He was nice about it but we still had to zip tie our license plate to the back of the rack for the rest of the trip. I will probably leave it where it is for now and not move it again until asked. _________________ 89 Syncro Westy - GW 2.5, now with a double knob job
@gwtwtlw |
