eurovw Samba Member
Posted: Mon Sep 08, 2003 5:34 pm Post subject: Just bought a 70 Ghia Coupe, need help |
I need advice on the engine. The body is in great shape, pans are great overall a great car. I am so excited, I fell in love with the Ghia.
I want to put a new engine in the car, the car has the 1600dual port and I want more power, the car is a 4speed any suggestions? |
JamesT Samba Member
Joined: September 08, 2003 Posts: 605 Location: East Sooke, BC, Canada
Posted: Mon Sep 08, 2003 9:18 pm Post subject: Re: Help. |
If your engine has the wider oil passages with dual relief, Case savers and is in good shape, no problem. Using your stock crank, change all bearings, Bore the block out for some 92 or 94 mm P's&C's. Install a high lift cam, Posibly some big valve heads, toss on some webber 34's or 40's and have yourself a great running 1914. If you want to go any bigger than 2.0L, I've got two words for you: Upright Conversion. They can be costly to make, but if you're looking for the pig power, thats the way to go. They fit into Ghias much better than bugs. For some real speed, put the Tranie out of a 74 or later bug (It'll only have access to the diff from one side) in. If you wanna spend the big bucks, buy a new one like a Ranch performance pro street. Keeping your stock tranie will probably give you better acceleration and will be easier to drive.
When it comes to engines, go big or go home
James T |
eurovw Samba Member
Posted: Tue Sep 09, 2003 4:58 am Post subject: |
Thanks for your reply.
I have heard some guys say to simply add the dual carbs and a 74 bettle tranie.
I don't want to spend a fortune on the engine, just want a little more power.
Any sites I can check out for engine mods? |
Air-Cooled Head Samba Member
Joined: October 15, 2002 Posts: 4069 Location: Chicago Suburbs
Posted: Tue Sep 09, 2003 11:49 am Post subject: |
This site may give you some ideas.
http://www.geocities.com/enginecookbook/menu.htm
Go over the www.shoptalkforums.com and get into the Engine Rebuild forum. Lots and Lots of discussion on everything from mild to wild performance upgrades.
Good Luck! _________________ Everything known to man has been written.
Readers are Leaders! |
JamesT Samba Member
Posted: Fri Sep 12, 2003 7:43 pm Post subject: |
We got tons of power out of out 65 bus (with a late 1600 duel port) Just by adding a couple of Kadrons and a Bugpack quietpack with a merged header. IT cost less than $400 cdn and it sounds better now too. _________________ -James T
1968 Kombi
1995 Eurovan Camper
2006 Garbage Jetta TDI |
eurovw Samba Member
Posted: Fri Sep 12, 2003 11:18 pm Post subject: |
Where did you get the Kadrons and bug pack from ? |
JamesT Samba Member
Posted: Wed Sep 17, 2003 8:22 pm Post subject: |
He got the Kadrons at a swap meet for dirt cheap. I bought the quiet pac from Bow-wow autoparts in Victoria. It's simple to install. When switching to Kadrons, or any dual carb, you should put a thick, soft gasget on the intake. The weight of the carbs sometimes causes them to pull out an start a leak. To avoid eccessive noise, use new gasgets when installing th e exhaust system as well. _________________ -James T
1968 Kombi
1995 Eurovan Camper
