water pump squeeling after replacement
onslowb
onslowb is offline
PostPosted: Sun Jul 01, 2012 4:55 pm    Post subject: water pump squeeling after replacement Reply with quote
I just changed my water pump and upon starting for the first time it's squeeling loudly. I revved the engine once to see if the noise would go away but it just got louder and I got a burning smell and a small puff of smoke from the pulley. Tried tightening and loosening the belt but no change. Reservoir is filled and cap off. Does this sound like a bad pump, or did I do something wrong? Pump is Hepu.
2.1 1987 weekender
pioneer1
pioneer1 is offline
PostPosted: Sun Jul 01, 2012 5:03 pm    Post subject: Reply with quote
remove belt and check the pump pulley for spin,noise & play.
"Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project
onslowb
onslowb is offline
PostPosted: Sun Jul 01, 2012 5:11 pm    Post subject: Reply with quote
Checked that and it doesn't seem to be moving or noisy. I expected to start the engine and it would suck up all the antifreeze from the tank but nothing got sucked in.
Ahwahnee
Ahwahnee is offline
PostPosted: Sun Jul 01, 2012 5:28 pm    Post subject: Reply with quote
onslowb wrote:
Checked that and it doesn't seem to be moving or noisy...
With the belt off can you spin the H2O pump pulley?
onslowb
onslowb is offline
PostPosted: Sun Jul 01, 2012 7:04 pm    Post subject: Reply with quote
Yes. It spins easily and has little to no play.
pioneer1
pioneer1 is offline
PostPosted: Sun Jul 01, 2012 7:10 pm    Post subject: Reply with quote
The coolant needs to get hot enuf to open the thermostat before it will flow thru or get "sucked" into the rest of the system
onslowb
onslowb is offline
PostPosted: Sun Jul 01, 2012 7:47 pm    Post subject: Reply with quote
That's what I figured but I thought it would flow in thatdiversion loop around the engine. Is there a step I'm missing bout priming the pump or something?
RicoS
RicoS is offline
PostPosted: Sun Jul 01, 2012 8:00 pm    Post subject: Re: water pump squeeling after replacement Reply with quote
Check the amount of axial thrust.
I had a van that started to squeal like that chubby, ruddy guy in the movie "Deliverance". I checked, then replaced the H2O Pump belts to no avail. The pump seemed rock solid with no leaks or redial slop. Then I noticed the extreme amount of axial movement.
When I yanked the pump it was obvious what was causing the loud squeal as I could plainly see that the pump impeller was milling away the engine case. As it turned out, the squeal was caused by an extreme case of "tool" chatter.
Richie
onslowb
onslowb is offline
PostPosted: Sun Jul 01, 2012 8:48 pm    Post subject: Reply with quote
i took off the smaller hose on the top of the water pump and lots of antifreeze came out....so there is liquid in there. I started the engine with the belt off and it was quiet so it is definitely something with the pump or alternator. I can't see anything else scraping like engine tin or anything. maybe I put the pulley on backwards?
