Manfreds78bay Samba Member
Posted: Mon Jul 02, 2012 1:21 pm Post subject: Fiberglass Threads Showing on Popup |
The fiber threads on my top are coming through. What fixes this issue? I've read some threads about gel coating, but not sure if this fixes this issue. Or do I have to have a pro do this?
If you had it professionally fixed, what did it cost you? _________________ 1978 2.0L FI Campmobile
1982 AMC Eagle SX4 4.2L FI |
dreadlocks Samba Member
Posted: Mon Jul 02, 2012 2:35 pm Post subject: |
there was never a gel coat on it, paint it.. between each coat use a fine grit sandpaper to knock down the fibers sticking up.. keep applying coats until its all nice and smooth.
most fiberglass shops wont touch your 30+ year old fiberglass, this is probably gonna be a DIY unless you take it to a body shop and ask em to paint and smooth it for you.
Check this out from the FAQ: http://www.thesamba.com/vw/forum/viewtopic.php?t=58119 _________________ 2013 4dr Golf TDI w/Technology & Tow pkg
2001 GTI - 3.0L VR6 Turbo
1975 Westfalia - 2.0L Fuel Injected |
werksberg Samba Member
Joined: February 08, 2005 Posts: 2151 Location: Prescott Valley, AZ
Posted: Mon Jul 02, 2012 3:04 pm Post subject: |
I have had customers that bought my new 68 - 73 Pop top & luggage racks state they got marine shop estimates of $3k + just to gel coat their OEM tops....
It is not an easy job..... _________________ Werksberg Products....Products that work!
Follow my new products on my Facebook Werks Berg
Click the below ADs link for products & feedback.
Search "werksberg" on Photobucket for products photos & Please remember to buy "American made products!" |
ccpalmer Samba Member
Joined: September 17, 2006 Posts: 3850 Location: Ann Arbor, Michigan
Posted: Mon Jul 02, 2012 3:06 pm Post subject: |
werksberg wrote: |
It is not an easy job..... |
I paid $3500 to get my entire Bus painted inside + out; pop-top too. Pop-top turned out awesome; I'm pretty sure they just sprayed automotive paint on it; maybe primer. _________________ '71 Westy |
I think I would tend to go with a two part brushable polyurethane. Check with your local marine chandler or try Jamestown Distributors. Another way to go might be the elastomer they sell for RV roofs. Others will surely have their own opinions on this. |
Posted: Mon Jul 02, 2012 3:19 pm Post subject: |
ccpalmer wrote: |
werksberg wrote: |
I paid $3500 to get my entire Bus painted inside + out; pop-top too. Pop-top turned out awesome; I'm pretty sure they just sprayed automotive paint on it; maybe primer. |
Sounds like you got a killer deal. Yes, it will take lots of primer and spot filler to seal out all those FG strands holes as it is like a mini tubes....
But it also depends on the condition of the FG parts if they need FG repair work or other prep.... _________________ Werksberg Products....Products that work!
babysnakes Samba Member
Posted: Mon Jul 02, 2012 3:25 pm Post subject: |
werksberg wrote: |
I haven't done a pop top, but I've done canoes. It may be tedious and time consuming, but it's not hard. |
Posted: Mon Jul 02, 2012 3:31 pm Post subject: |
Then you know it is NOT like spraying regular paint then.... _________________ Werksberg Products....Products that work!
Posted: Mon Jul 02, 2012 3:52 pm Post subject: |
werksberg wrote: |
Then you know it is NOT like spraying regular paint then.... |
Correct. It can be brushed and sanded. We have a "Rolling on the Tremclad " thread. Not everyone is looking for a show winning finish. A lot of folks here are just looking to protect their ride. Brushing and sanding can bring a presentable finish while sealing in the 'glass.
Posted: Tue Jul 03, 2012 8:21 am Post subject: |
Thanks for all the help. This answered my questions. _________________ 1978 2.0L FI Campmobile
69satellite Samba Member
Joined: January 14, 2008 Posts: 208 Location: Kerrville, TX
Posted: Sat Jul 07, 2012 4:16 pm Post subject: |
I rolled mine with 2 coats of white tractor paint. Couldn't believe it looked as good as it does now. Not perfect but god enough for me |
1vwdog Samba Member
Joined: March 16, 2004 Posts: 285 Location: Poulsbo WA
Posted: Sat Jul 07, 2012 11:29 pm Post subject: |
Epoxy primer will do wonders. _________________ 71 Chianti Westy |
later Samba Member
Joined: September 16, 2004 Posts: 121 Location: Posen, Michigan
Posted: Sun Jul 08, 2012 7:53 am Post subject: |
One word...................."Imron"
It is a polyurethane enamel.
A friend of mine suggested using the same paint they use on Semi trucks, airplanes, bullet trains, boats. Anytime you have plastic/fiberglass you want that paint to flex even while cold and hot.
It is flexible and tuff. It holds up VERY well. It is designed to be used in extreme enviroment and remain a bit flexible.
I did my poptop with it.................no regrets after 15 years. No failure as of yet.
Follow directions and recomended procedures.
Gary _________________ "It could blow up at any time......but it should be OK."
(me) - "Im sorry Officer, its impossible to drive a straight line in a VW camper in a strong wind."
(Officer) - "Are you telling me sir that you are driving an unsafe vehicle?"...........(This no longer applys since installation of new Koni's.)
67sunbeam Samba Member
Posted: Sun Jul 08, 2012 9:07 am Post subject: |
Has anyone had luck with either the Evercoat or Bondo fiberglass repair kits? I have 2 small holes about the size of a quarter that I want to repair. _________________ 1974 Westy
1967 Sunbeam Alpine |
galexander Samba Member
Joined: April 17, 2003 Posts: 524 Location: Round Rock, TX
Posted: Thu Jul 12, 2012 10:53 pm Post subject: |
I painted my '79 Westy Pop top using White Rustoleum in the quart can.
Rolled it on with a 3 " roller.
Man, it looks great still, and that was like 7 years ago!
I used a scotchbrite pad with lots of water to smooth out the pop top and clean it first.
Then I Washed it, let it dry for a day or two and then painted it.
good luck _________________ enjoy the journey,
Gary
Check out our YouTube Channel, VW Life |
