What kind of screws for vent?
dougrbutler
dougrbutler is offline
PostPosted: Tue Sep 09, 2003 2:19 pm    Post subject: What kind of screws for vent? Reply with quote
What kind of sheet metal screw is supposed to hold down the overhead cover for the fresh air vent. Is it a Philips head or slotted and is it a pan head?
Thanks
jvigil
jvigil is offline
PostPosted: Tue Sep 09, 2003 3:33 pm    Post subject: Reply with quote
This picture shows slotted....but it doesnt look right to me. my bus isnt around here right now so i cant go look...
https://www.thesamba.com/vw/gallery/pix/13371.jpg
However...is there any place to buy air vent covers? I havent seen any in the classifieds and I am planning to install a stereo up there...Any help appreciated.
thanks
jake
23window
23window is offline
PostPosted: Tue Sep 09, 2003 3:46 pm    Post subject: Reply with quote
Hold on there, don't use sheet metal screws. Shocked
Its a phillips head screw and threaded. Something tells me 4mm threads.
Please view the pic I compiled below for a visual. Hope this helps.
hazetguy
hazetguy is offline
PostPosted: Tue Sep 09, 2003 5:13 pm    Post subject: Reply with quote
4 X .70 thread pitch. they are Phillips head! the correct headed screws are available, but they don't have the pointy tips like the originals (but you don't see the tips anyway).
i would **strongly** recommend running a tap through the holes before re-installing screws.
let me know if you can't find screws, i have plenty of new ones. (i'll be going to jerome so get a hold of me next week)
choadtx
choadtx is offline
PostPosted: Wed Jun 22, 2011 12:46 am    Post subject: Reply with quote
I know, I know, old post... But I was wondering if these screws on the vent are the same as what holds the door panels on? The PO has some crap screws and I'm not sure what the original should be...
Rick
Rick is offline
PostPosted: Wed Jun 22, 2011 6:57 am    Post subject: Reply with quote
no. vent screws are a machine screw in the aforementioned size, panel screws are a tapping screw.
PostPosted: Wed Jun 22, 2011 9:45 am    Post subject: Reply with quote
Since this is so old, please use this thread from the FAQ, which has the information:
http://www.thesamba.com/vw/forum/viewtopic.php?t=170131
Locked.
This topic is locked: you cannot edit posts or make replies.    Forum Index -> Split Bus All times are Mountain Standard Time/Pacific Daylight Savings Time
