My horn button turns on my brights...
RyanV
RyanV is offline
PostPosted: Tue Sep 09, 2003 11:27 pm    Post subject: My horn button turns on my brights... Reply with quote
No horn just my brights on/offf. Anybody else seen this before? Isn't supposed to be on the floor left of the clutch? 72 adventurewagen
Cheers!
My current project is a 1972 adventurewagen.
jeremysmithatshawdotca
jeremysmithatshawdotca is offline
PostPosted: Tue Sep 09, 2003 11:37 pm    Post subject: Reply with quote
Your brights ought to be controlled by the signal lever. You must have a mix up in the wiring somewhere in your column.
RyanV
RyanV is offline
PostPosted: Tue Sep 09, 2003 11:42 pm    Post subject: Reply with quote
thought it was a clever idea, but i guess it must have been an accident. think i'll keep it that way and get an air horn: )
chabanais
chabanais is offline
PostPosted: Tue Sep 09, 2003 11:46 pm    Post subject: Reply with quote
Does your signal lever sound your horn?
Very Happy
"I spud therefore I yam."
PostPosted: Wed Sep 10, 2003 12:10 am    Post subject: Reply with quote
go to www.drivetheplanet.com , they're driving a vw from holland to china, and they're in india right now. Apparently there the right of way goes to the biggest car, or the car with the loudest horn, so they've started giving it to the locals with one of those compressed air horns! lol
Rich
Rich is offline
PostPosted: Wed Sep 10, 2003 9:47 pm    Post subject: Reply with quote
Wiggling my turn signal would make my horn beep. There was a piece of plastic inside the turn signal assembly that was cracked and causing a short of some nature. I heard that this is a common problem and I suspect that you have the same issue since the symptoms are similar.I replaced the signal assembly and the problem was solved.
Be careful when buying a replacement turn signal/brights switch as they are very year specific for the years around 1972. Count the wires.
Rich
chabanais
PostPosted: Wed Sep 10, 2003 10:40 pm    Post subject: Reply with quote
In European cars today, the turn signal lever beeps the horn.
keifernet
Samba Search & Rescue
keifernet is offline
PostPosted: Sat Sep 13, 2003 11:55 am    Post subject: Reply with quote
the wire that operates the horn and the wire that dips the lights high/low are both brown grounds ( the one to the headilght relay should have a white stripe) it is possible someone got confused and hooked them up wrong, or you could still have other issues in the signal swithc/ steering column.
