good coil-overs
vugbug68
vugbug68 is offline
PostPosted: Fri Dec 05, 2008 8:51 am    Post subject: good coil-overs Reply with quote
Does anyone know where I can get a set of NICE coil-overs for a standard bug. I've seen them on cars in magazines but I cant seem to find what I'm looking for online. I'm not talking about the cheap ones that only give you like 4 positions... I want the fully adjustible threaded ones.
I think there are a couple brand names Pro and Red 9, that make coil overs but I cant find any websites or info on them.
71 Super
66 Corvair
69 Baja Bug
vugbug68
vugbug68 is offline
PostPosted: Fri Dec 05, 2008 1:38 pm    Post subject: Reply with quote
Fine I will reply to myself, I finnally found this site:
http://www.red9design.co.uk/type1.htm
this is what I'm looking for, now I need to find a company in the U.S. so I wont have to pay up the wazzoo
71 Super
66 Corvair
69 Baja Bug
Tonytalksalot
Tonytalksalot is offline
PostPosted: Thu Jul 05, 2012 7:30 am    Post subject: Reply with quote
Let me know if you found these in the states or not, thanks bud.
torsionbar
torsionbar is offline
PostPosted: Thu Jul 05, 2012 8:37 am    Post subject: Reply with quote
the rear suspension on a beetle is already ride height adjustable. just reindex the tbars and set the height wherever you want it - doesn't cost a penny, aside from labor time. want a firmer spring rate? easy, just swap in larger tbars. it's a great design, and porsche used it on the 911 for a quarter century - from 1964 through 1989.
what is the benefit of using these coil-overs on a beetle? quite frankly, if they don't allow you to adjust compression and rebound rates (like moton and jrz do) then they're completely useless imo. and adjustable rate coil overs are silly for a street car, this is race car stuff we're talking about.
the compression and rebound rates of the shock absorber must match the spring rate of the spring. in low-dollar non-adjustable coil over kits, they are usually wildly mismatched, resulting in laughably awful ride quality and poor handling. that said, i'm not familiar with the brand in this photo.
Max Welton wrote:
[air cooled vw's] are no longer suitable for the general public. The owner has to be be able to maintain the car. And that is after fixing all the deferred maintenance items and ill-conceived modifications. If you can't do those things you are pretty much screwed.
Tonytalksalot
PostPosted: Thu Jul 05, 2012 3:35 pm    Post subject: Reply with quote
These coilovers are for the front. Lol
cfvwtuner
cfvwtuner is offline
PostPosted: Thu Jul 05, 2012 6:10 pm    Post subject: Reply with quote
If you have a super those wont do shit.
Also, coilovers are for watercooled cars.
Also, TOPLINE for supers
Rolling Eyes
Tonytalksalot
PostPosted: Fri Jul 06, 2012 9:24 am    Post subject: Reply with quote
We're talking about std beetles, you remove the front shocks and torsion bars, replace them with thru rods and coils for shocks.
Dropped spindles and coils should get you on the floor with the adjustability for dampening and height adjustment.
flyboat
flyboat is offline
PostPosted: Fri Jul 06, 2012 2:53 pm    Post subject: Reply with quote
Are the thru rods used to act as anti-sway bars?
79 super Vert
62 Ragtop Bug
66 tintop Westy
Porsche 914
09 Z06 Vette track car
jhoefer
jhoefer is offline
PostPosted: Fri Jul 06, 2012 4:34 pm    Post subject: Reply with quote
They normally just hold the trailing arms into the beam, with the ends free to rotate. But swapping one to a sway bar is simple. Replace the through-rod with a torsion bar and pin the torsion bar to the trailing arms at each end. You could also just cut out the center spring pack mount in the tube and use the old spring pack for the sway bar if you think it's sized right.
