010 trans pressure test
pegscraper
pegscraper is offline
PostPosted: Wed Nov 17, 2021 10:34 am    Post subject: 010 trans pressure test Reply with quote
Anyone have any info on main pressure, test. 010 transmission. I know what it should be. Not sure how to do it. Trying to test the pump before I remove the trans.
Thanks in advance Smile
jlrftype7
jlrftype7 is offline
PostPosted: Wed Nov 17, 2021 11:36 am    Post subject: Re: 010 trans pressure test Reply with quote
I don't have my Bentley in front of me since I'm at work, but I thought you needed to remove the test port plug that's on the Drivers Side, outer casing of the Trans, and hook up a Transmission Test Gauge/ hose to it.
Maybe someone can post the page from the manual if you don't have access to one.
‘84 Tin Top - Hilga....Auto
kourt
kourt is offline
PostPosted: Wed Nov 17, 2021 1:18 pm    Post subject: Re: 010 trans pressure test Reply with quote
Greetings,
Nice first post.
The Vanagon has the VW 090 automatic. Since this is the Vanagon forum, I assume you are asking about the 090 automatic, and not the 010, which dates from 1972.
The pressure testing for the 090 is covered in Bentley 37.17-37.18.
What kind of problem are you trying to solve? It sounds like you believe the ATF pump may be underperforming.
kourt
pegscraper
PostPosted: Wed Nov 17, 2021 3:52 pm    Post subject: Re: 010 trans pressure test Reply with quote
This has the 010. I think jlrftype7 has solved my problem. This one has the oil cooler connected to the test port.
