Engine Compartment Question
McHuntley
McHuntley is offline
PostPosted: Wed Sep 17, 2003 3:58 am    Post subject: Engine Compartment Question Reply with quote
I am curious, When the Bay Window bus went from the type1 engine to the type 4/pancake engine, did the engine compartment get shorter? Or is it the same height?
Is there a big difference between the two?
I am curious, as I think my next bug project will be a bus.
Thanks,
matt
Any opinions stated here are my own, otherwise someone else would have said them.
ratwell
ratwell is offline
PostPosted: Wed Sep 17, 2003 10:51 am    Post subject: Reply with quote
It changed for the 1972 model (August 1971). In Europe, both engines were available with the Type I being standard and the Type IV being optional so yes, both engines fit perfectly well given that you have the appropriate engine support bar and tinware. One company sells fiberglass "tinware" to let you install the earlier engine if you wish.
'78 Westfalia CDN
'76 Doublecab Sweden
Read the Baywindow FAQ
