Rear westy table refurbish
Bala
Bala is offline
PostPosted: Fri Jul 20, 2012 10:21 pm    Post subject: Rear westy table refurbish Reply with quote
Did a quick refurb on my rear table. Turned out to be easer than i was thinking.
Thought this might help for anyone who wants to give it a try.
How it looked before with peeling laminate and wrinkled trim:
I used "DAP" brand Weldwood contact cement. A nice coat and let it dry for 20 minutes or so.
It didn't seem like it was really needed, but I put some bricks on top to give a little added pressure while it bonded.
The corners seemed to take a lot of pressure to stay in contact, so I used some clamps to insure a tight bond.
I didn't get any pictures of the trim boiling/installation process, but it's pretty simple. Just boil a good amount of water in a large pot, and drop the trim in. It only takes about 1 minute for the trim to become super soft. I had a towel handy and dried it as I lifted it out of the water. You have to work fast. It cools and hardens very quickly. I used a hammer to gently tap the trim into place. It was not possible to get it fully settled into place by hand.
After the trim was installed:
I used "Marvel" air tool oil and put it on like automotive wax. A generous amount, then buffed it out to remove the excess. Not sure how long it will last, but it looks nice for now.
And, all finished:
1976 Westy
1966 Beetle
Poptopcamper
Poptopcamper is offline
PostPosted: Sat Jul 21, 2012 5:19 am    Post subject: Reply with quote
Nice job. The trim on the cabinets on my riviera have pulled loose and seem to have shrunk. I wonder if the boiling water trick would work with them? It's worth a try. Thanks for sharing.
If you only have one tool in your tool box, and it's a hammer, pretty soon, everything looks like it needs to be whacked!
1978 VW Riviera
2021 Dodge Ram 3/4 ton
2020 VW Tiguan
2001 Harley Electraglide Classic
1986 BMW R 800cc motorcycle
2002 Chevy Camaro Z28
1999 Harley Sportster 1200 Custom
Westfabulous
Location: The tropic of Canada, dodging the giant flying moose of Surrey!
Westfabulous is offline
PostPosted: Sat Jul 21, 2012 7:00 am    Post subject: Reply with quote
Nice work; looks great. Good tip on boiling the trim.
"I will gladly pay you Tuesday for a hamburger today."
white74westy
white74westy is offline
PostPosted: Sat Jul 21, 2012 7:42 am    Post subject: Reply with quote
Great work! Thanks for sharing. Cool
Kirk
Kirk is offline
PostPosted: Sat Jul 21, 2012 7:57 pm    Post subject: Reply with quote
I would have never thought about boiling it. Well done!
MAKE FORUMS GREAT AGAIN
Bear
Fasty
Super
Bala
Bala is offline
PostPosted: Mon Jul 23, 2012 10:31 am    Post subject: Reply with quote
Thanks guys!
The boiling trick wasn't my idea. I've heard it from several people, but never tried it until now. It works very well.
1976 Westy
1966 Beetle
sallittjob
sallittjob is offline
PostPosted: Mon Jul 23, 2012 12:02 pm    Post subject: Reply with quote
Looks great.
Did you reuse the existing trim or buy new trim and if so, where did you get it from?
57' Beetle Deluxe
1192cc SP
71' Super Beetle
1968cc DP
73' 412 Sedan
1679cc FI
75' Westy
1800cc FI
bugger101
bugger101 is offline
PostPosted: Mon Jul 23, 2012 6:17 pm    Post subject: Reply with quote
sallittjob wrote:
Looks great.
did you read the original post? Confused
75 west deluxe http://www.thesamba.com/vw/forum/viewtopic.php?p=5270450#5270450
2010 ford focus
Bala
Bala is offline
PostPosted: Mon Jul 23, 2012 8:54 pm    Post subject: Reply with quote
Yep, reused the old stuff.
It's kind of funny, it's about like boiling spaghetti. The trim is hard and almost brittle feeling, then drop it in the water and in about 10 seconds or less it gets super soft and pliable. I let it soak a little longer and moving quickly installed it. Reduce, recycle, reuse. Smile
1976 Westy
1966 Beetle
Kirk
Kirk is offline
PostPosted: Tue Jul 24, 2012 7:56 am    Post subject: Reply with quote
That was my question. More info on the boiling. You got the water hot, or a rolling boil. Then how long in the water?
Inquiring minds want to know.
Bear
Fasty
Super
Bala
Bala is offline
PostPosted: Tue Jul 24, 2012 9:28 am    Post subject: Reply with quote
Yes, rolling boil. Then I rolled the trim up and dropped it in. Maybe 40 seconds and it's good to go (don't walk away, it's that fast!). I used some tongs to move it around so it didn't burn on the bottom of the pot. Once it was ready I grabbed an end with the tongs and dried it with an old towel as I removed it from the pot (be careful to not burn yourself). The table was in my kitchen so I was able to go straight to it and start installing the trim. You only have a few minutes before it starts getting hard again. I installed it around the entire table, then went back with a hammer and tapped it into place. If you run your fingers along it you can feel where it hasn't fully seated. Once in place I don't think it'll go anywhere anytime soon.
1976 Westy
1966 Beetle
vw76westy
vw76westy is offline
PostPosted: Tue Jul 24, 2012 12:13 pm    Post subject: Reply with quote
if anyone wants brand new black t-mold
exactly the same as original
i have plenty and will offer to you guys for
75cents foot
just pm me
gowesty,busdepot and other places offer it for $1.25 - $1.50 a foot
message to the gods...
this is not a ad but a way to offer something to samba members & keep
the vultures out
order your BAY WINDOW T-SHIRT here http://www.thesamba.com/vw/classifieds/detail.php?id=1526918
quote from bay window bus buyers guide........
The Type 4 engine is considered by many to be VW's finest air-cooled motor,
sallittjob
PostPosted: Wed Jul 25, 2012 7:15 am    Post subject: Reply with quote
bugger101 wrote:
sallittjob wrote:
Looks great.
Yes I did read it. The better question is did you read the post?
I don't see him mention reusing the old trim anywhere in that paragraph without reading between the lines.
Thanks for the clarification Bala.
57' Beetle Deluxe
1192cc SP
71' Super Beetle
1968cc DP
73' 412 Sedan
1679cc FI
75' Westy
1800cc FI
Mfitz79california
Mfitz79california is offline
PostPosted: Mon Feb 04, 2013 2:03 am    Post subject: demintions Reply with quote
I am trying to rebuild the rear table for my 79 delux could you give me the dimentions of you rear table. Mine is missing and i cant find a link on a full rebulid. [/i]
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Mon Feb 04, 2013 8:12 am    Post subject: Re: demintions Reply with quote
Eric
1977 Deluxe Westfalia - 2.0L FI Type IV, Completely Original
Photographer for HotVWs, VolksWorld, AirMighty, VW Camper & Commercial, Hayburner, and more.
My Photography Page.
fleff
fleff is offline
PostPosted: Mon Feb 04, 2013 10:13 am    Post subject: Reply with quote
I havent worked with this trim, and i like the boiling water trick, but to gain some time, i might use a heat gun while plying it in.
'76 VW Campmobile
'98 VW Passat
'69 Piper Comanche
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Mon Feb 04, 2013 10:41 am    Post subject: Reply with quote
Heat gun works great, just don't melt it.
Eric
