Ignition wiring diagram
That 70's Bus
That 70's Bus is offline
PostPosted: Thu Sep 11, 2003 9:56 pm    Post subject: Ignition wiring diagram Reply with quote
Could anyone hook me up with firing order for a 78 transporter if you were lookin down at it from trunk plz. Bus running rough and lost power. sounds like its missing(idling rough) an im hoping its my bad tune up . need for work torrow help!!!!!
Amskeptic
Amskeptic is offline
PostPosted: Fri Sep 12, 2003 7:55 pm    Post subject: Reply with quote
Staring down at engine from access lid as you stand at back of bus:
#1 is front right, #2 rear right, #3 front left, #4 rear left.
Distributor should have #1 facing rear sort of towards the engine hatch striker plate, now go in a counter-clockwise circle from there #4, #3, #2.
That's your firing order.
Colin
WAVEPIMP
WAVEPIMP is offline
PostPosted: Sat Sep 13, 2003 8:08 am    Post subject: Reply with quote
Also when the bus is running wiggle the wires that go to the fuel injectors and see if the engine starts running smoother if you have fuel injection. Mine was doing that recently and #4 cylinder FI conector wasn't getting a good signal and when I moved the wire going to the injector the engine started running fine. So I cleaned the terminals and no problem anymore. Just something you might look at to help you out.
Laters
ratwell
ratwell is offline
PostPosted: Sat Sep 13, 2003 9:38 am    Post subject: Reply with quote
More specifically if you pop the cap the rotor will be facing a notch in the top of the body of the distributor.
'78 Westfalia CDN
'76 Doublecab Sweden
Read the Baywindow FAQ
flat4freak1978
flat4freak1978 is offline
PostPosted: Sat Sep 13, 2003 6:47 pm    Post subject: Reply with quote
me too. stupid fuel injector connections
1978 bus. 2.0 f.i. manual trans. "the great gonzo"
flat4freak1978
PostPosted: Sat Sep 13, 2003 6:48 pm    Post subject: Reply with quote
hey wave pimp howed you clean the connectors?
