34 pict 3 POS help!
joshbuchan
joshbuchan is offline
PostPosted: Sun Aug 12, 2012 12:56 pm    Post subject: 34 pict 3 POS help! Reply with quote
Just about ready to launch this little carb! built a manx with a 1776 and cant get the thing to run right........I have lots of experience with dual IDA and IDF's but nothing with stock singles Embarassed
motor has stock cam and DP heads everything is fresh, DVDA dist. with points, dwell set to 48, timing at 5 deg BTDC and around 30 at 3000 rpm.
I have done hours of reading on the 34pict and have had no luck yet.....
thing is running stupidly rich and wont idle....when I look down the throat of carb fuel is drooling out of the cast tube in the middle of bore (I believe this is the main circuit.....comes up from main jet and though air corrector into tube)
has a stock idle and air corrector and I reamed the main out to a 135.
the only thing I haven't checked is the fuel pressure as I don't have a tee but I would think if it was high the float level would be high which it doesnt seem to be?
Any stock carb gurus have any insight on this for me? have had carb off way too many times to count and it's getting a little old
cheers Josh
aryue
aryue is offline
PostPosted: Sun Aug 12, 2012 1:47 pm    Post subject: Reply with quote
Your dealing with either a bad float valve, which screws into the top half of the carburetor - or - the float itself needs replacing.
Last but not least - measure your fuel pressure from the pump. It's supposed to be 2 PSI.
- Andrew in Austin, TX -
OldandSlow - but still chuggin.
http://www.ph.utexas.edu/~yue/VW/VWBus.html
joshbuchan
PostPosted: Sun Aug 12, 2012 5:07 pm    Post subject: Reply with quote
Thanks for the reply Andrew! Didn't mention I just rebuilt the carb and kit had replacement inlet valve with new .020" copper gasket under it. Carb body was run through an ultrasonic cleaner and all blown out and throttle shaft seems pretty snug.....
If float or needle valve were pooched wouldn't the bowl be overfilled? When I remove top while carb still on motor level is about 9-10mm from gasket surface (didn't actually measure it and it has been a hot day here and sitting all day bowl has half evaporated)
baked beetle
baked beetle is offline
PostPosted: Sun Aug 12, 2012 5:22 pm    Post subject: Reply with quote
make sure the discharge tube isn't ready to fall out and get eaten by your engine. It's probably leaking cause it's loose.
These days people like me are hard to find- we don't give a damn what you think, about what we think. - JR
____________________
66' His
57' Theirs
63' Hers
62' Drag Bug - Theirs 13.1 @ 101 mph (GONE)
joshbuchan
PostPosted: Sun Aug 12, 2012 5:34 pm    Post subject: Reply with quote
you talking about the brass accelerator pump squirter? not puking from there its the cast aluminum part that extends into the centre of venturi it's not removeable
uglyduck
uglyduck is offline
PostPosted: Sun Aug 12, 2012 6:32 pm    Post subject: Reply with quote
What is your compression ratio? Too high and could possibly be sucking fuel from the venturi @ Idle.
clonebug
clonebug is offline
It's got to be a float problem.
I think spec is 11 mm down from carb top if I remember correctly.
the rebuild kit should have two different thickness washers...try the thicker one, it should be around .032 in thick.
That might take care of it. It is a cheap test otherwise.
I would guess your float valve isn't holding and you need a better quality one.
That is also a cheap test to see if it is. You should verify your fuel pressure first though.
I run 3.5-4.0 lbs of pressure on my turbo buggy and I have no trouble with fuel pressure.
richardcraineum wrote:
I'm so ignorant of efi I don't even know the difference between batch, sequential blah blah blah ..
cbeck wrote:
His user name in a previous life was dick head.
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936
joshbuchan
PostPosted: Sun Aug 12, 2012 6:44 pm    Post subject: Reply with quote
Compression ended up just below 8:1 so not outragous are these solexes that sensitive?
I'll pick up a tee tomorrow and check pressure
Alstrup
Alstrup is offline
PostPosted: Mon Aug 13, 2012 2:25 am    Post subject: Reply with quote
Float height is too high. i bet you used the thin copper washer that was in the rebuild kit. - That was not a good choice. But how could you know if you´ve never worked with these. The washer needs to be 1,3 - 1,5 mm thick. By then you will most liely need at least a larger main jet, and possibly a ,57-,60 idle.
Ignition is not right. With a DVDA dizzy the timing at idle should be 5 degrees AFTER TDC with both hoses on. Max advance with hoses on, about 38-40 degrees. Max advance w. hoses off 29-30 degrees.
T
Greezy Joe
Greezy Joe is offline
PostPosted: Mon Aug 13, 2012 2:49 pm    Post subject: Reply with quote
Too high of an idle stop screw adjustment can cause this problem. Idle stop adjustment should be about the same as doing idle on Webers or any other carb, back out until the screw doesn't touch and screw it in until it touches and screw it in a 1/2 to 1 turn and start adjusting things from there.
Current:74 Ghia Coupe w/ 2276
71 Ghia Vert w/ 1835
07 GMC Truck
12 Jeep Wrangler
73 Harley FLH 93 cid
89 Harley 883 Sportster (1200)
Owned before: 58, 69 Ghia Coupes, 64 Canvas Sunroof, 68, 72, 73, & 74 Bugs, 63 Single Cab, 65 Bus, 66 & 70 Camper
" Duct tape can't fix stupid, but it'll muffle the sound".
joshbuchan
PostPosted: Mon Aug 13, 2012 8:41 pm    Post subject: Reply with quote
Update..... Fuel pressure is 2.8 psi checked with a $10,000 calibrator Wink
Changed copper washer under needle valve to thicker one, re-set fast idle arm to touch and then half turn in and got it running.
Starts nice and got the small screw to react now but I think the right side of the throttle shaft Has a little vac leak.....fiber bushing has a bit of play, not much but it wiggles. Spray it with carb cleaner and wants to die.
One other thing I checked was the dual vac can on distributor.... Retard side holds a vac but advance doesnt?
Lastly trying to adjust the acc squirter and having a hard time getting it to hit the edge of the butterfly. Is it the rear side you aim it at? I can hit it when car isn't running but when it's running as soon as the stream of gas leaves the nozzle it gets sucked into the center of Venturi..... What am I doing wrong?
aryue
aryue is offline
PostPosted: Tue Aug 14, 2012 9:06 am    Post subject: Reply with quote
Ah, the joys of a worn carburetor bushing and a leaky vacuum advance diaphragm.
The accelerator discharge nozzle isn't going to hit the edge of the butterfly when the engine is running.
That leaky vacuum advance is a problem. The 34 PICT 3 was designed to utilize a vacuum advance distributor to prevent the dreaded off-idle stumble or low RPM dead spo.
If you plan to use this carb for while - you may want to attempt to replace the throttle shaft bushings yourself. An eBay seller robinson129434 offer brass bushes <- as they called in the UK.
The guy has consistently good feedback:
http://feedback.ebay.com/ws/eBayISAPI.dll?ViewFeed...world=true
Alstrup
Alstrup is offline
PostPosted: Tue Aug 14, 2012 9:14 am    Post subject: Reply with quote
The idea with the spray giong to the edge of the butterfly is correct according to the maintenance books. BUT, it is actually better to aim it at the aux supply , so that the squirt hits the edge of the aux supply. It will then create a range that gets mixed better into the air, hence better atomisation and less risk of stumble due to the fuel going back to droplets.
T
joshbuchan
PostPosted: Tue Aug 21, 2012 9:38 am    Post subject: Reply with quote
sooooo lots of fidling and it's better but not great
made some brass bushings and then for extra insurance also o-ringed the throttle shaft. opened up a 26mm venturi up to 28mm and re jetted to 140 main and a 60 idle.
couldn't find a replacement vac can so I threw in a german 009 for now
starts and idles great, better power but seems to "load up" whenever I am either cruizing and put my foot back in it, try and lug it off the line or come to a stop and don't blip the throttle before taking off first............ any ideas? is this the dreaded off idle hesitation that you read so much about with the ol 009? to me it feels like there is an excess of fuel hanging out waiting for the throttle to be cracked and it clears once reved up??? Acc pump squirter is set as reccomended above and adjustment is halfway between middle and + side, so 3/4 of a maximum shot. Was going to try and back off on this a bit??
one thing I did when I had the carb apart was put the butterfly out of a parts 34pict meant to run on a SVDA (has a smaller bypass air hole than DVDA model) in antisipation of running the 009..........read loads on this where guys put a rivet in the bigger hole and push out the center pin..... suppose to help with the 009 stumble?
Alstrup
Alstrup is offline
PostPosted: Tue Aug 21, 2012 10:27 am    Post subject: Reply with quote
Idle jet is most likely too large. Go ,55 - maybe ,57
Did you make the acc pump squirt direction as I wrote previusly ? If so, there should not be the need of more than average pump amount.
Main jet may still be too small. Try the 0,55 idle and 145 main solution and see where that gets you.
T
joshbuchan
PostPosted: Tue Aug 21, 2012 11:47 am    Post subject: Reply with quote
Yes pump squirts as suggested, I'll try and dial that back first then source some more jets
joshbuchan
PostPosted: Tue Aug 21, 2012 11:58 am    Post subject: Reply with quote
What is the small jet beside the idle jet? The one that is behind a little brass plug
aryue
aryue is offline
PostPosted: Wed Aug 22, 2012 5:52 am    Post subject: Reply with quote
That is the auxiliary fuel jet - also known as the power jet.
According to my understanding - the auxiliary fuel jet activates at wide open when the engine is running at high RPM. On a 34 PICT 3 - it is usually a .47mm. It does get crudded up over time and I ream it by twirling it onto my .45mm jet gauge.
Hopefully, Alstrup will correct me, if I have this wrong.
aryue
aryue is offline
PostPosted: Wed Aug 22, 2012 6:13 am    Post subject: Reply with quote
starts and idles great, better power but seems to "load up" whenever I am either cruizing and put my foot back in it, try and lug it off the line or come to a stop and don't blip the throttle before taking off first............ any ideas??
A 28mm venturi will have a lower air velocity when driving at partial throttle and when coming off of idle. The amount of air drawn into the carb will be the same at low rpms - but with less velocity - it will affect which jets should be installed for your particular 1776cc.
Two things:
* Choosing between a ..55mm, 57mm and .60 idle jet will depend on what camshaft and what size valves installed in your 1776. Plus, your elevation above sea level.
* I would pony up the bucks and get an SVDA to go with this particular carburetor.
- Andrew in Austin,TX -
joshbuchan
PostPosted: Wed Aug 22, 2012 7:55 am    Post subject: Reply with quote
Cam is stock 1600
Elevation is between 0-200 ft.......I live on an island
SVDA Would be ideal i know but......This is a major budget build, thing is for sale to fund my 55 rag so trying not to spend anouther $150
