Gnarlyleech Samba Member
Joined: April 23, 2012 Posts: 222 Location: Southwest Louisiana
Posted: Fri Aug 31, 2012 12:48 pm Post subject: Oil breather draft tube boot. Mo' probs. |
Man I have some strange luck when it comes to these VW's. The new draft tube boot I purchased didn't have a slit in the end of it. So I made a small one with my knife and blew through it to double check. Anyone ever had this problem?
Here is a picture of it before I cut a slit.
_________________ "Good judgment comes from experience and a lot of that comes from bad judgment"
My 1966 Beetle Project Thread http://www.thesamba.com/vw/forum/viewtopic.php?t=520182 |
Michael Fischer Samba Member
Joined: April 20, 2004 Posts: 1585 Location: Salem, OR
Posted: Fri Aug 31, 2012 1:33 pm Post subject: |
I've never bought a new one. Always just re used factory ones. |
Joined: January 01, 2007 Posts: 17829 Location: sticksville, ct.
Posted: Fri Aug 31, 2012 2:58 pm Post subject: |
i have had cheap, knock off one like you describe and had to do the same thing. also, make sure the locating tit on the I/D is there, otherwise, it could (will) pop off _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Fri Aug 31, 2012 3:00 pm Post subject: |
When you say tit, are you referring to the nipple like bump? _________________ "Good judgment comes from experience and a lot of that comes from bad judgment"
74 Thing Samba Member
Posted: Fri Aug 31, 2012 3:18 pm Post subject: |
There is a hole in the tube and a corresponding male nub inside the boot that are supposed to match. |
Posted: Fri Aug 31, 2012 3:20 pm Post subject: |
Are we still talking about volkswagen engines?
Just joking guys. I double checked and I did get everything installed correctly. _________________ "Good judgment comes from experience and a lot of that comes from bad judgment"
Alpha_Maverick Samba Member
Posted: Sat Jun 13, 2015 7:21 am Post subject: |
I know this is an old post, but I thought I'd revive it to ask a related question: I've had 3 aftermarket boots crack and split after only a few hundred miles of driving. After a couple thousand (between oil services) they usually fall off. Does anybody make one that will actually last? _________________
Alstrup wrote: |
hmm well, wiggly I like 5,5inchers in the rear at least. |
THINGONER Samba Member
Joined: April 13, 2008 Posts: 681 Location: riverside ca
Posted: Sat Jun 13, 2015 5:17 pm Post subject: |
I would try Wolfsburg West |
Mely Samba Member
Joined: October 04, 2024 Posts: 25 Location: Worcester, MA
Posted: Wed Jul 16, 2025 12:19 pm Post subject: Re: Oil breather draft tube boot. Mo' probs. |
I have a standard 76 Beetle, still fuel injected.
Does this boot go somewhere on my car?
Anyone have a photo of their FI breather tube?
Thanks in advance. |
SBD Samba Member
Joined: October 24, 2012 Posts: 3294 Location: SOUTH DAKOTA
Posted: Wed Jul 16, 2025 2:33 pm Post subject: Re: Oil breather draft tube boot. Mo' probs. |
If your factory oil fill doesn't have a road draft tube extending down under the engine compartment through a hole in the engine tin then you don't need this part. I don't think the fuel injected Beetles had one. _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52744 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Jul 16, 2025 2:47 pm Post subject: Re: Oil breather draft tube boot. Mo' probs. |
The down tube was eliminated in 73 or 74, the tube to the air cleaner is much larger (~20mm) instead. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Mely Samba Member
Posted: Wed Jul 16, 2025 3:49 pm Post subject: Re: Oil breather draft tube boot. Mo' probs. |
Thanks SBD and busdaddy.
I thought so.
Yet another part listed for my car that doesn't fit!
Across several websites.
Wish these sellers weren't so lazy with the copying and pasting. |
