will paint stick to that yello zink plating
R.C.N. Bugs
R.C.N. Bugs is offline
PostPosted: Thu Sep 27, 2012 9:05 pm    Post subject: will paint stick to that yello zink plating Reply with quote
the have tins that look gold in color i think its yellow zink coating can you primer and paint over that with good adhesion
risk
risk is offline
PostPosted: Fri Sep 28, 2012 10:46 am    Post subject: Reply with quote
I just scuffed mine up with a red scotch brite, then shot them with single stage black enamel. Seems to be holding up great so far.
j.goodspeed
j.goodspeed is offline
PostPosted: Sun Sep 30, 2012 10:28 pm    Post subject: Reply with quote
Many replacement parts are shipped in Gold or clear zinc. Hood hinges etc... Scuff them with a scotch brite pad and follow with a self etching primer. This will bond with the zinc plating and be a good substrate for your top coat.
risk
risk is offline
PostPosted: Mon Oct 01, 2012 7:16 am    Post subject: Reply with quote
yeah, now that you mention it..i used nason's version of dupont variprime, then layed down the black. scat heavy duty cylinder tins
