Volvo wiper motor for 12 volt conversion
Page: 1, 2, 3  Next
cncwhiz
cncwhiz is offline
PostPosted: Sun Dec 07, 2008 12:58 pm    Post subject: Volvo wiper motor for 12 volt conversion Reply with quote
I am posting some pics of a 200 series rear window wiper motor that I pulled out of a car at pic and pull. The motor on the left is a lowlight 57 motor that I restored. These motors look to be a direct swap with a brush swap. The Volvo motor is a single speed 12 volt motor. You could pull the armature out of it for your conversion or swap the brush/ connector setup and bottom cover and be good to go with 12 volt. They had it listed for 21.00. They guy at the counter had a super beetle and thought he was an expert on bugs and charged me 9.00 for my "regulator"
Russ Wolfe
Russ Wolfe is offline
PostPosted: Sun Dec 07, 2008 1:00 pm    Post subject: Reply with quote
Good find. Nice piece of research.
Gary: OK. Ima poop.
cncwhiz
cncwhiz is offline
PostPosted: Sun Dec 07, 2008 1:45 pm    Post subject: Reply with quote
I did not find it, Dr Darby did. But I agree its a good find.
blacktruck
blacktruck is offline
PostPosted: Sun Dec 07, 2008 5:11 pm    Post subject: Reply with quote
Dr d really got my attention with that,and now here you are with the
part...now say nothing matches or is terribly OG on a 63 beetle.
Is this piece a bolt on deal or do I need to fiddle around with the
gut swapping?
cncwhiz
cncwhiz is offline
PostPosted: Sun Dec 07, 2008 8:40 pm    Post subject: Reply with quote
It is not a straight bolt on. You need to remove the cap on your motor. Then you can do it two ways. take the Volvo motor cap off. remove the brushes. Take out the armature. Do the same thing to your motor and put the armature from the Volvo motor into your motor. The other way is harder and more work. You take the brushes and wire connector from your motor and put it on the Volvo motor. Then take your bottom cover from your motor and put it on the Volvo motor. If you want me to do it pm me and we can work somthing out. Its not too hard of job and your motor probably need new grease anyway.
blacktruck
PostPosted: Sun Dec 07, 2008 8:51 pm    Post subject: Reply with quote
that doesn't sound out of my league,thank you tho.
wasn't sure if it was necessary or an aesthetic thing
cool!
JinxedSydney
JinxedSydney is offline
PostPosted: Tue Dec 09, 2008 11:39 am    Post subject: Reply with quote
Going to pick one up now; cheapest I could get it for here is $35. One condecending prick wanted $100 from the "ma'am" who couldn't tell him the year of her Volvo; even when I explained it was for a VW. Going to drive by and egg his business. Twisted Evil
'63 Beetle "Gertie"
Yes, I am indeed a chick that does her own work on her own Dub.
cncwhiz
cncwhiz is offline
PostPosted: Tue Dec 09, 2008 11:55 am    Post subject: Reply with quote
Sounds like some of the people here who think their parts are made of gold?
fastinradford
fastinradford is offline
PostPosted: Tue Dec 09, 2008 12:52 pm    Post subject: Reply with quote
x2 brother,
JinxedSydney
PostPosted: Tue Dec 09, 2008 3:57 pm    Post subject: Reply with quote
Or maybe he was charging me an estrogen surcharge. Rolling Eyes
Well, the guys at the wrecking yard removed it for me (I was the door prop since the hydraulics were long gone) and even bench tested it. It is missing the small spring inside and we guess it fell off when it was wrestled from it's perch. I think I have a small spring that will work...hopefully.
'63 Beetle "Gertie"
cncwhiz
cncwhiz is offline
PostPosted: Tue Dec 09, 2008 4:12 pm    Post subject: Reply with quote
If you are referring to the spring on the brushes, the one on your motor might work? I have not torn it apart yet.
JinxedSydney
PostPosted: Wed Dec 10, 2008 2:07 pm    Post subject: Reply with quote
Finished the conversion, with much help from cncwhiz. Wink Works great!!! Cleaned all the parts and regreased. Thanks DrDarby and especially cncwhiz. Applause
'63 Beetle "Gertie"
cncwhiz
cncwhiz is offline
PostPosted: Wed Dec 10, 2008 2:22 pm    Post subject: Reply with quote
35 dollars for a 12 volt wiper conversion, sweet.
Russ Wolfe
PostPosted: Wed Dec 10, 2008 6:54 pm    Post subject: Reply with quote
I might run by my friendly salvage yard and see how many Volvo's he has.
I have known him for over 40 years. He should treat me right.
What wrenches do I need to pull them out?
Gary: OK. Ima poop.
JinxedSydney
PostPosted: Wed Dec 10, 2008 7:15 pm    Post subject: Reply with quote
The main motor has itty bitty 9mm ones. I couldn't tell you about what you need to pull it since the guys wouldn't let me do it. If possible, bring a 2x4 in case the door hydraulics don't work, since I'll be busy tomorrow! Wink
'63 Beetle "Gertie"
vintagevwnut
vintagevwnut is offline
PostPosted: Wed Dec 10, 2008 9:20 pm    Post subject: Reply with quote
I dont know Volvo's so what year and body style would that be from?
cncwhiz
cncwhiz is offline
PostPosted: Thu Dec 11, 2008 7:21 am    Post subject: Reply with quote
I found mine on a 240. I looked at 740 but the motor was gone. I believe that they are on 200 series wagons. To clarify it again, it is the "rear" wiper motor. The one I removed was primo. They don't get banged around and so the top cover is like new.
DrDarby
DrDarby is offline
PostPosted: Thu Dec 11, 2008 7:27 am    Post subject: Reply with quote
1980 - 1993 Volvo 245 (240 model station wagon) rear wiper motor. I'd bet the 145 (older) would work too.
Midwest Autosavers, Inc. Crystal Lake, IL
keifernet
Samba Search & Rescue
keifernet is offline
PostPosted: Thu Dec 11, 2008 7:29 am    Post subject: Reply with quote
One thing to watch out for... The 240 series wagons had wiring issues through the tailgate hinge. This caused many rear wipers to either "quit working" ( and those are in primo shape because many owners wouldn't pay to get them fixed) or some BURNED UP from wiring short.
SO... check the motor first before purchasing and don't buy a burned up unit.
You can flip the bail down and take off the "bread box" cover and see right away what you got.
Just thought I would pass that along. My family and I have had many 240 wagons starting way back for a 72 model bought new. And I have dealt with the wiring and burned up motors a few times Very Happy
I never though about checking them for use on the VW though. Neat that they work for that early single speed conversion.
fluxcap
fluxcap is offline
PostPosted: Thu Dec 11, 2008 8:45 am    Post subject: Reply with quote
Are these for sure the correct years? I spent about an hour and a half at our local pull-a-part and came home empty handed. I looked at about 10 wagons labeled as 1986 and 1987 and they all had the "newer" style wiper motor and not the type that looks like a early vw motor. I found a few 1984s, but they had already been robbed so I don't know what type they had. Laughing
Not doubting your information, but I was planning on calling a few of the other yards around here and just want to be certain as to what years to look for.
Thanks
Eric - 1966 camper bus
"It's like, how much more black could this be, and the answer is none.......none more black."
Page: 1, 2, 3  Next
