isea Samba Member
Joined: October 19, 2011 Posts: 100 Location: Alameda, CA
Posted: Sat Nov 17, 2012 7:18 pm Post subject: Another fog lamp install thread |
I am really sorry to bring up a topic that is gone over some many times already on the Samba but I really just want to make sure I do this right.
The fog lights I have only have one wire coming out of them. I thought there would be two. Isn't there suppose to be a ground wire too?
I have a 20amp fuse. Should that be installed between the switch and the battery or the lights and the switch?
I have a 20amp switch. I am unclear but from what I have read it seems like I would be ok with the 20amp switch and no relay.
Clearly I am ignorant about this installation so be patient please.
And if you want to just spell out the directions like I'm a 5 year old from another planet that would be fine too
Thanks! _________________ '67 Beetle, Fresh 1600cc SP
2.5" drop spindles |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4658 Location: Whittier 90602
Posted: Sat Nov 17, 2012 7:38 pm Post subject: |
Is your car 12 volt? _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
isea Samba Member
Posted: Sat Nov 17, 2012 7:40 pm Post subject: |
sorry, yes it's a 12volt _________________ '67 Beetle, Fresh 1600cc SP
61SNRF Samba Member
Posted: Sat Nov 17, 2012 8:14 pm Post subject: |
Does it have an Alternator, or a Generator? _________________ -Bruce
isea Samba Member
Posted: Sat Nov 17, 2012 8:20 pm Post subject: |
It's a generator. _________________ '67 Beetle, Fresh 1600cc SP
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
isea Samba Member
Posted: Sat Nov 17, 2012 9:49 pm Post subject: |
OK, that's what I thought, but I wasn't sure. _________________ '67 Beetle, Fresh 1600cc SP
isea Samba Member
Posted: Sun Nov 18, 2012 9:35 am Post subject: |
OK, so is it safe to say I can run a 14 gauge wire from the battery to a 20amp switch then a 20amp inline fuse then the lights? _________________ '67 Beetle, Fresh 1600cc SP
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11212 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Sun Nov 18, 2012 9:36 am Post subject: |
How many Watts are your lights?
14 gauge should be ok, but can your switch handle the Amps?
Prolonged illumination of high wattage lamps can destroy switches in a short time.
As for fuse placement, it depends on your path for circuits. You need it close to the voltage starting source to protect the most. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
isea Samba Member
Posted: Sun Nov 18, 2012 10:02 am Post subject: |
You'll probably be ok using a 20 Amp rated switch only. (rather than adding a relay)
(Id really want to know how many amps those use.)
Id route a battery feed with the fuse at the battery, to supply your switch. That way the entire circuit added, from the battery is protected. Lower your fuse to 15 amps. I doubt those lights use that many amps, maybe 3-5 each.. Without measuring or knowing how many amps those lights use its a guess at proper amp rating fuse.
You can start low like 10, and if its ok.. leave it, if it pops after using without any other fault, up it to 15. _________________ aka Ken {o\!/o}
61SNRF Samba Member
Posted: Sun Nov 18, 2012 10:14 am Post subject: |
If the kit came with a 20 amp fuse, that's probably about twice what the lights draw, in other words ~10 amps total or 5 amps each.
Ohm's law say's: 12v x 10a = 120 watts total.
Most auxiliary lights will draw an excessive amount of electrical power for a stock 12v Beetle with a stock Generator. The car was not designed with any extra reserve of electrical power for accessories other than a transistor radio.
If you are serious about this, really need and will use the Fog lights, then you would be well advised to upgrade to an ALT with higher output, a Battery with a larger capacity, and for optimum performance run them through a relay. _________________ -Bruce
Miklo ¡Chale!
Joined: August 27, 2008 Posts: 2058 Location: Antelope Valley, Ca
Posted: Sun Nov 18, 2012 10:29 am Post subject: |
I believe those are the same fog light I have but not %100 sure...
My lights are H3 bulbs so each one is about 55W.
This is the diagram I basically used...
_________________ ✠Miklo✠
'55 Type1 "Ozma"
'66 Type1 "Charlotte" RIP
Antelope Valley's Mobile Air-Cooled Guru
| Dr OnHolliday wrote: |
| As I remember it, lowriding was not one of the criteria that Adolf gave to Dr. Porsche... |
isea Samba Member
Posted: Sun Nov 18, 2012 12:40 pm Post subject: |
great! thanks guys this is all very helpful _________________ '67 Beetle, Fresh 1600cc SP
onetuza Samba Member
Joined: June 20, 2012 Posts: 579 Location: Sebastian, FL
Posted: Wed Jan 02, 2013 7:31 am Post subject: |
What gauge wire from the battery to the relay? _________________ When I die, I want to go peacefully in my sleep, like my grandfather . . . .
Not screaming, like the other passengers in his car! |
Posted: Wed Jan 02, 2013 7:36 am Post subject: |
| onetuza wrote: |
| What gauge wire from the battery to the relay? |
With Length and actual amps it can vary.
16 Gauge is fine, 14 Gauge is better, but may not be needed.
Keith Samba Member
Joined: August 15, 2005 Posts: 3632 Location: Brodheadsville, PA
Posted: Wed Jan 02, 2013 11:07 am Post subject: |
| VOLKSWAGNUT wrote: |
| onetuza wrote: |
Got a version of this chart for 6V ? _________________ Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind |
Posted: Wed Jan 02, 2013 11:36 am Post subject: |
Best I can do on short notice....
I'd have to search my 6 volt American Archives.
http://www.gtsparkplugs.com/WireSizeCalc.html.
Wire gauge rating is more about AMP capacity, the voltage is the pusher of said amps.
Rule of thumb, measure the amps and select the correct gauge. Usually 1 size larger for 6 volts. Thats simply to keep resistance down and voltage drop to a minimum. _________________ aka Ken {o\!/o}
JSB Samba Member
Joined: September 06, 2005 Posts: 55 Location: SW Michigan
Posted: Wed Jan 02, 2013 11:49 am Post subject: |
Veedubdoug,
Nice diagram. Is that the same relay used for rear window defog? If not, do you have a part #? Thanks. |
