Automatic Transmission oil leak
Jodrell
Jodrell is offline
PostPosted: Sat Dec 15, 2012 4:31 am    Post subject: Automatic Transmission oil leak Reply with quote
1990 Vanagon
Is it possible to change oil seal on input shaft to transmission (shaft with splines on it that connects to engine) without going inside the transmission. I am also having difficulty trying to identify which is the correct seal from on line parts dealers. In my searches I refer to it as "input shaft seal",but nothing comes up for auto tranny, although something comes up for manual transmission. Any help would be appreciated.
mackaymanx
mackaymanx is offline
PostPosted: Sat Dec 15, 2012 4:41 am    Post subject: Reply with quote
Try 'torque converter seal' in your search.
Fhak915
Fhak915 is offline
PostPosted: Sat Dec 15, 2012 10:29 am    Post subject: Reply with quote
Replace the governor seal first. This can be done without too much trouble. Most autos leak here.
If you have the engine out, you can change the torque seal without going into the transmission.
Frank
86 AW EJ22
AtlasShrugged
AtlasShrugged is offline
PostPosted: Sat Dec 15, 2012 11:13 am    Post subject: Re: Automatic Transmission oil leak Reply with quote
Jodrell wrote:
1990 Vanagon
Use this. easy to replace with no transmission disassembly. You must seperate the transmission from the engine..sorry.
http://www.van-cafe.com/home/van/page_136_1009/torque_convertor_seal.html
Shop wisdom: use two seals side to side.
GrindGarage
GrindGarage is offline
PostPosted: Sat Dec 15, 2012 12:23 pm    Post subject: Reply with quote
x2
Use 2 seals. Check torque converter mating areas and make sure they are smooth and free of any burrs that may cut the new seal.
-cliff
91 Vanagon AUTO
97 Single Port EJ22 all smallcar.com
