johnstuarthughes3636 Samba Member
Joined: May 08, 2011 Posts: 12 Location: Sedalia, Colorado
Posted: Wed May 21, 2025 7:49 pm Post subject: 6v heat sensor |
I acquired a couple of 6v MotoMeter temperature gauges for my 6v bugs. Does anyone have a line on where I can acquire 6v heat sensors that will work with these gauges? _________________ 1951 Hoffman standard sedan
1954 Deluxe sedan
1955 European sunroof sedan
1970 Cabriolet (in pieces)
1965 Daily driver bug |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 25789 Location: Olympia Wash Rinse & Repeat
Posted: Sun May 25, 2025 8:30 pm Post subject: Re: 6v heat sensor |
Temp sender will be an NOS or used item. Good hunting to you if you chose only to go with the original sender.
You might want to talk to this seller, have seen him selling early gauges with modern guts & sender to work.
https://www.thesamba.com/vw/classifieds/detail.php?id=2666134 _________________ In Stereo, Where Available! |
wagen19 Samba Member
Joined: November 16, 2007 Posts: 550 Location: germany
Posted: Sun May 25, 2025 9:49 pm Post subject: Re: 6v heat sensor |
johnstuarthughes3636 wrote: |
I acquired a couple of 6v MotoMeter temperature gauges for my 6v bugs. Does anyone have a line on where I can acquire 6v heat sensors that will work with these gauges? |
One problem is:
some old gauges til around 1970 need PTC senders, not the common NTC ones.
The next:
the axle on some old gauges is not centered. So it´s not possible to integrate new common inner "material" into old gauges which would go along modern NTC senders. |
