Painted Transmission with Undercoat...Was That a Bad Idea?
Vanapplebomb
Vanapplebomb is offline
PostPosted: Wed Jan 09, 2013 8:07 pm    Post subject: Painted Transmission with Undercoat...Was That a Bad Idea? Reply with quote
Dustymojave, an off road VW enthusiast I have a lot of respect for, made a comment on one of my posts. I had painted my transmission with a couple coats of rubberized spray on undercoating. Dusty wrote me this...
dustymojave wrote:
Unless you're in extremely corrosive conditions, VW engines blocks (cases) and transmission cases are better off bare. They do a fair amount of their cooling by air contact with the very heat-conductive magnesium-aluminum alloy. Painting them is like wrapping them in a blanket. Especially thick stuff like rubberized undercoat or bed liner.
I clearly didn't think about that before I went ahead and painted it. I just wanted to throw this out to a larger group of people to see if I can get a general consensus of if I screwed up or not. Am I in danger of overheating the transmission?
1800 Type 4 Berrien 295
kreemoweet
kreemoweet is offline
PostPosted: Wed Jan 09, 2013 8:46 pm    Post subject: Reply with quote
I've never known a (manual) transmission to get warm enough to ever have to worry
about the heat dissipation qualities of the case.
'67 bug: seized by the authorities
vwracerdave
vwracerdave is offline
PostPosted: Wed Jan 09, 2013 8:55 pm    Post subject: Reply with quote
That is true with the engine block but it won't hurt the transaxle. They only get up to 150-160*F, not hot enough to be a problem.
Vanapplebomb
PostPosted: Wed Jan 09, 2013 9:02 pm    Post subject: Reply with quote
Ok, thanks for the replies guys! Note to self: Never paint the engine block.
Quokka42
Quokka42 is offline
PostPosted: Wed Jan 09, 2013 9:10 pm    Post subject: Reply with quote
Even the engine block does very little cooling, and it can be argued that oil will drain quicker in a hot case. Leave the cooling parts such as cylinder heads, pushrod tubes and cylinders alone, or a thin coat of something on the cylinders, and paint away!
OK, the ribs on the sump provide a little cooling, but IIRC it's something like 2% of the total...
Lots of manual crankcases have been painted. "Polish" the edge of the ribs and it can look really cool.
If you are worried, change to a full synthetic fluid and max temps will drop by as much as it went up or more, plus the tranny will be less affected by the heat.
mcmscott
mcmscott is offline
PostPosted: Wed Jan 09, 2013 9:53 pm    Post subject: Reply with quote
vw transaxles from 61 thru 75ish were painted black from the factory
oconnell
oconnell is offline
PostPosted: Tue Dec 31, 2013 10:45 am    Post subject: not painted Reply with quote
having owned several type 1 and 4 vw's new none had painted transmissions.
oconnell
bossboy302
bossboy302 is offline
PostPosted: Tue Dec 31, 2013 11:09 am    Post subject: Reply with quote
smoke 'em if ya got 'em!
I'm NOT paranoid…..why, what have you heard?
mcmscott
mcmscott is offline
PostPosted: Tue Dec 31, 2013 11:10 am    Post subject: Re: not painted Reply with quote
oconnell
Having built over 1000 t-1 trans alone, I can assure you they were painted
There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250
Vanapplebomb
PostPosted: Tue Dec 31, 2013 4:08 pm    Post subject: Reply with quote
Wow, thread back from the dead.
drumbum68
drumbum68 is offline
PostPosted: Tue Dec 31, 2013 5:07 pm    Post subject: Reply with quote
I have never seen a type I tranny painted unless it came from a rebuilder. Why would the factory spend more money on something not necessary?
modok
modok is offline
PostPosted: Tue Dec 31, 2013 5:26 pm    Post subject: Reply with quote
It would not surprise me if they did paint them. If you paint fresh magnesium it usually falls of withing a few years anyway.........
junior55
junior55 is offline
PostPosted: Tue Dec 31, 2013 6:38 pm    Post subject: Reply with quote
Some of the rattlecan undercoats are more of a thinner plastic formula and less
of a thick tar product that never gets solid.
You may be ok if it is the first one.
mcmscott
mcmscott is offline
PostPosted: Tue Dec 31, 2013 7:05 pm    Post subject: Reply with quote
You mean like painting the car? Naw, that would be silly, much like the engine sheet metal was painted and so was the axle tubes, trust me the trans cases from the first syncros(61) to the late cases(75) were black
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250
jsturtlebuggy
jsturtlebuggy is offline
PostPosted: Tue Dec 31, 2013 7:44 pm    Post subject: Reply with quote
Sorry Scott,
Not all VW transaxles cases where painted.
I seen and worked on many starting in the 1970s and very few in Northern California had paint on them. These were from cars that had never had their trans out since leaving the factory.
This also includes the 1960 Bug my Dad bought new in 1960, the 1966 Squareback bought new in 1966 and the 1969 Bug chassis bought in late 1969 for the first dune buggy my Dad built. None of these had paint on them.
If you want to paint the trans case go ahead and do it. I would recommend just a light coat.
Driving with a constant load on trans (such as sand washes, sand duning) can get the trans extremely warm.
Joseph
Fair Oaks/Orangevale, CA
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960
Howard 111
Howard 111 is offline
PostPosted: Tue Dec 31, 2013 8:38 pm    Post subject: Reply with quote
Without looking, Rancho painted my tranny. What was used, they didn't say, but it seems to stick well.
Aaron M265
Aaron M265 is offline
PostPosted: Tue Dec 31, 2013 9:03 pm    Post subject: Reply with quote
My all original numbers matching never been apart transaxle from my 1500 'S' notchback was painted black from VW back in the day- September 1964.
Not true to say that all of them came painted or not. This one definitely did but.
Aaron
http://1500notchback.blogspot.com/
Need to contact me? Email is faster than a PM - [email protected]
For T3 Panel Van information:
http://www.thesamba.com/vw/forum/viewtopic.php?t=389465
SBD
SBD is offline
PostPosted: Tue Dec 31, 2013 9:36 pm    Post subject: Reply with quote
I pulled the transaxle out of my 1970 Ghia several years back. It was definitely the original and had never been out of the car because part of the original factory installed tar boards were put in over the top of the access cover for the shift coupler. I had to partially destroy them to remove the cover so I could pull the trans. I've still got the trans out in my shop (but the car is long gone). Now, because of you guys and this thread, I'm going to have to go out & look at it sometime (when it's not 5 degrees out) to see if there's any paint on it. Sad
