Loose Input Shaft, how to fix?
Buggy Disaster
Buggy Disaster is offline
PostPosted: Thu Jan 17, 2013 4:53 pm    Post subject: Loose Input Shaft, how to fix? Reply with quote
I have a 67-69 beetle trans. I while removing the engine the input shaft came out 2-4 inches. I can push it back in and it will engage.
How do I fix this? The second gear syncro is shot, is it time for a new trans?
My 4 Seater 1835cc Build page
http://www.thesamba.com/vw/forum/viewtopic.php?t=452823&postdays=0&postorder=asc&start=0
jsturtlebuggy
jsturtlebuggy is offline
PostPosted: Thu Jan 17, 2013 7:52 pm    Post subject: Reply with quote
Yes trans will have to come apart to fix. Mainshaft is 2 piece with a 7mm stud and collar slid over 2 piece held on with a snapring. Some how it has came apart.
If you have other problems internal now is the time to get everything fixed.
Trying to use it the way it is could cause major damage.
Joseph
Fair Oaks/Orangevale, CA
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960
Dale M.
Dale M. is offline
PostPosted: Thu Jan 17, 2013 8:00 pm    Post subject: Reply with quote
What he said....
Check this diagram...
http://www.longenterprises.com/images/Diagram_Images/beetletransdiagram1.gif
Parts you are mainly interested in are 1, 2 , 3, 12 and 13 ...
1 and 2 are held together by 3 (threaded stud) and locked by reverse drive gear (12) and drive gear is locked into place by snap ring 13....
You can drop off passenger side axle and side plate to access these parts with out a full transaxle take down....
Dale
