Assembly diagrams with fastener sizes?
Argos33
Argos33 is offline
PostPosted: Sun Feb 17, 2013 9:18 pm    Post subject: Assembly diagrams with fastener sizes? Reply with quote
Hi all,
I am in the process of reviving an 86' weekender, and long story short just about every part on the vehicle has at some point been taken apart, moved, replaced, stored, etc. The previous owners kept tack of some of it, but inevitably I am left with lots of random bolts, nuts, etc.
Does anyone know of assembly diagrams that show the fastener/bolt sizes? Currently I am looking for the two bolts to attach the clutch slave cylinder, and bolts that attach the bushing plate to the side of the transmission for the shift linkage. I have been pairing up bolts, nuts etc and checking to see if they work, but it is pretty inefficient. I have some nice thread gauges, etc I just need to figure out what goes where.
I appreciate any help/resources! Thanks!
Evan
syncrodoka
syncrodoka is offline
PostPosted: Sun Feb 17, 2013 9:47 pm    Post subject: Reply with quote
The clutch slave bolts are 8x25
The shift rod to tranny bolts are 8x30
chazz79
chazz79 is offline
PostPosted: Sun Feb 17, 2013 9:49 pm    Post subject: Reply with quote
those are 8x1.25..... roughly 40mm long. They are through bolts with nuts in the other side so just use whatever.
standard 5/16 (1/2" headed) bolts from the hardware store will do fine.
One day as a lion, or a lifetime as lamb
The green monster in bits and peices: http://www.thesamba.com/vw/forum/viewtopic.php?t=332556&highlight=green+monster
Argos33
Argos33 is offline
PostPosted: Sun Feb 17, 2013 10:45 pm    Post subject: Reply with quote
Thanks guys, that helps a lot! Definitely will speed things along.
Evan
