Bruce Samba Member
Joined: May 16, 2003 Posts: 17302 Location: Left coast, Canada
Posted: Mon Oct 07, 2013 5:13 pm Post subject: |
In that long weld, I would clamp a copper bar on the other side of the panel while you weld. That way the bar pulls the heat out faster than you can drop the torch and grab a wet rag. Also, you can increase your heat and weld longer distances with the copper. Copper is magical! Experiment and see. _________________
eurodub Samba Member
Posted: Mon Oct 07, 2013 6:28 pm Post subject: |
i use a TIG welder with good results on beetle metal. the secret is patience as everyone said before, welding in small areas far apart so each cools as much as possible.
my split has overlapped door skin repairs made in the past, i got the doors from Belgium that way. i tried everything to seal the area but the paint and filler keep on bubbling. the only repair for me now is to weld it all the way once i get Mika's repair panels.
as for the door hinge rivets, VW suggested using bolts when replacing them.
you can see it in the below link
http://fridaysplit.blogspot.de/2012/05/mera-dorrar.html _________________ 1960 1200 model 117 deluxe ragtop
1974 T2 Westfalia Campmobile
1976 MK1 Golf |
Hebster52 Samba Member
Joined: March 14, 2003 Posts: 1774 Location: Finland, Jakobstad
sinclair Samba Member
Joined: July 01, 2004 Posts: 399 Location: New Forest UK
Posted: Mon Apr 01, 2024 2:02 am Post subject: |
johnshenry wrote: |
Turn off the lights and pass bright light along and view it from the other side to make sure it is completely welded up.
Great top tip!
I’d certainly seal the inside too to be sure. |
type4split Samba Member
Joined: May 23, 2007 Posts: 681 Location: Hamilton, Indiana
Posted: Thu Apr 04, 2024 6:01 am Post subject: Re: DIY door bottom repair with replacement panels |
Hebster. did you make the vertical support brace? _________________ '67 deluxe bus w/the little windows
'52 beetle
'55 convertible
'50-something convertible (*need ribbed 'vert quarter panel )
'63 "milo" beetle
Part, parts and more parts |
esde Samba Member
Joined: October 20, 2007 Posts: 5992 Location: central rust belt
Posted: Sat Apr 06, 2024 9:25 am Post subject: Re: DIY door bottom repair with replacement panels |
I harvested an interior part from another door, which was fine, and used the lower repair panel from Mika. I tried my best to use the flange for the repair, but ended up with a bit of warping that was disappointing. IN the end, a donor skin was found and the weld seam was higher up where it is easier to keep straight and hidden.
During the repair attempt, I made a plywood form, so I could reference when things were in line or starting to warp. While it didn't help me that time, I do still make forms to use as a reference..
Problem with the flanged repair, is that you cannot correct anything with a shrinking disc. So, the full skin was removed for a donor skin. You can use almost any skin up to 64 if you correct the door handle hole
lotta wasted time and money getting to the finish line here, at least it's in the rear view now.. _________________ modok wrote:
