syncrodan Samba Member
Joined: November 29, 2010 Posts: 131 Location: georgia
Posted: Tue Feb 19, 2013 8:08 pm Post subject: Bostig engine install method question |
Ok, it looks like the only way to go is to install the engine and gearbox already mated together. I'll be doing this on a lift, how have you done it?
It seems to me that I should position the pair under the van, lower the van down, move the engine hoist in and hook it up, then maybe lift the nose of the gearbox and set it on a jack stand to level it off. with the hoist holding the engine and a stand supporting the trans, I could slowly lower the van to a good height and then bolt it up. This is my idea, but maybe someone has a better way? Wish I still worked at the VW dealer, we had these Beissbarth tables for just such occasions, man those were sweet. |
chojinchef Samba Member
Posted: Tue Feb 19, 2013 8:12 pm Post subject: |
If you are doing it on the ground: Just as you said. Mate the trans and engine together, slide under the van (I used a bread rack). Lower van over assembly. Use jack to lift up trans mount and secure. I then used jack and wooden blocks to raise up engine a aside at a time, to get to proper height and insert fasteners to secure the bar to the chassis.
Attach periphery goodies.
Enjoy the hell out of it.
The hoist method works too. There are two hooks on top of engine that will work just fine. Maybe better, as they allow for movement to get the bolts in the holes. Just remember to spin them around when done, or they tear into your hatch insulation.
I lost my hoist in the move. I think my ex sold it to me ex neighbor.
How far from Atlanta are you. _________________ Its a mistress; an expensive, whiney, needy bitch of a mistress. She is a chunky, dirty girl with bad skin, little motivation and yet she always makes me smile. She sure has been around before shacking up with me. She has a direct line to my wallet, plays with my emotions, is consistantly jovial yet with a sarcastic and sardonic side, is consistant in her inconsistancy, and every once in a while gives me a great ride and a fantastic memory.
insyncro Banned
Posted: Tue Feb 19, 2013 8:18 pm Post subject: |
I use a 1 ton transmission jack to install mated drivelines. |
Borlandrs Samba Member
Joined: August 25, 2012 Posts: 56 Location: Southern Maryland
Posted: Tue Feb 19, 2013 9:16 pm Post subject: |
I mated the transmission and slid it under the van on cardboard. I didn't lower the van but used a floor jack and blocks to lift the end of the transmission up to connect those mount. While doing this, I used additional blocks under the sides of the cradle to stabilize it laterally, because as you lift the trans, the other end gets balanced on the oil pan rather than the cradle. I think I also attached the hoist and used that to help keep it from rolling too. Then it was easy to lift it into place with the hoist, which allowed sway to get the cradle bolts aligned and installed. Good luck! _________________ 1990 Westy GL, Bostig Zetec |
I'm in Augusta Ga, right off I20 |
solarguy Samba Member
Joined: February 02, 2012 Posts: 85 Location: las vegas nv usa
Posted: Tue Feb 19, 2013 11:29 pm Post subject: |
I used a hoist for the motor and a jack for the Trans that way I could take it up level. |
Reck Samba Member
Joined: January 20, 2015 Posts: 74 Location: Santa Fe, NM
Posted: Sun Jun 07, 2015 8:32 pm Post subject: Bostig install clearance needed? |
I'm hoping this thread isn't completely dead.
I've just dropped the engine and transmission and slid the assembly out from under my vanagon. Will be receiving the Bostig kit soon, but first needed to send the trans out for overhaul. I'm working in my driveway, with somewhat uneven ground. Getting the car high enough on the jack stands was difficult. The clearance to slide the engine/trans out (while sitting on the legs of my hoist, like in the Bostig removal video) was marginal. I'm thinking the Zetec sits rather higher, and that I might be in trouble.
I realize that I will be somehow sliding the engine/trans assembly under the car without the help (and added height) of the wheels and legs of the hoist, but I'd like to know what clearance I will need to plan for. Does anyone have a measurement from the HCOP bottom to the top of the cam covers?
Alternatively, does anyone drop the engine down from above and then bolt it to the trans?
Much appreciated,
Eric |
61Scout Samba Member
Joined: November 06, 2011 Posts: 1297 Location: Shoreline/Yakima WA
Posted: Sun Jun 07, 2015 10:05 pm Post subject: |
Eric (Reck), reading about "uneven ground" and "jack stands" immediately conjures up an image of a dangerous situation. I don't know you or your experience level and I mean no disrespect, but wanting you to be safe... jack stands are made to be on cement, period. If you use them on any other surface, be aware that jack stands will definitely sink into gravel and hot asphalt. I work in a tiny garage and often have projects outside, and on jack stands, but I've also welded a 1/8" steel plate across the entire bottom on all my stands. And probably needless to say, but chock the front wheels on both sides, and if you can slip a large piece of lumber under the rear tires as an additional safety.
In regards to your question, here's how I approached my project (though not a bostig)... I put the assembly on a cart and measured from the floor to the top of the engine. Add one or two inches and raised the rear end of the vehicle accordingly, measuring from the lip (under the windows). Then I slid the assembly underneath and raised the lump using a come-along hooked to a steel frame I built that straddled over top of the deck. That way I could control the pitch/angle and easily raise/lower the lump and have room to work underneath without anything in the way.
-Kevin _________________ 1986 Westfalia Weekender Wolfsburg, RJE 2.3
1985 Tin Top, Subie 2.2 + 5MT
Floppy Mirrors no more: http://www.thesamba.com/vw/forum/viewtopic.php?t=653018&highlight=
Remove the front spindle nut with ease: https://www.thesamba.com/vw/forum/viewtopic.php?t=679567&highlight=
Remove the rear wheel bearing housing without messing with the big 46mm nut: https://www.thesamba.com/vw/forum/viewtopic.php?t=679507&highlight=
-Nec Spe, Nec Metu |
indytriple Samba Member
Joined: April 27, 2009 Posts: 710 Location: Brownsburg, Indiana
Posted: Mon Jun 08, 2015 4:21 am Post subject: |
I just jacked the rear end of the van up pretty high using jack stands, and a friend and I slid the transmission/engine under the van on a piece of large cardboard. I used a normal jack under the transmission end first, attached that end and then moved the jack around to the back and jacked the engine up. No engine hoist. No trouble. About all you need for this method is smooth concrete, a friend and some cardboard. _________________ "See The Glass As Already Broken."
87 Vanagon Westy Auto Bostig
www.bluegrassbicyclecompany.com |
JudoJeff Samba Member
Joined: May 24, 2013 Posts: 1179 Location: Near Springfield, MA
Posted: Mon Jun 08, 2015 4:55 am Post subject: |
sycrodan,
It's easier than you think right now. I use wooden blocks under the vehicle to raise it up. Mated the engine and transmission, slid it under van on cardboard, pushing with my legs. Hooked up the engine hoist. Used a floor jack on the transmission end, and slowly raised everything up. Connected transmission bolts, then four of the cradle bolts. Did this all by myself, no problem, except then I was sick with the flu for the next seven days....... _________________ ________________________________________
1989 Vanagon GL Westfalia Camper, Burned up on 7/31/16.
1987 Vanagon GL Westfalia Camper, Bostig & Rebuilt, sold
1986 Vanagon GL Westfalia Camper, Bostig Sold May 10, 2021
1999 Ford GTRV Westfalia camper (30% bigger Westy layout) |
jobenaus Samba Member
Posted: Mon Jun 08, 2015 10:01 am Post subject: |
Reck (Eric) I remember tilting the zetec a bit so you don't have to lift the body any higher to get enough clearance and slide it under on cardboard.
alnvilma Samba Member
Posted: Mon Jun 08, 2015 1:14 pm Post subject: |
Like others: pushed it with my legs, on cardboard.
I used wheel ramps and the height was perfect in conjunction with a hoist and floor jack. |
Reck Samba Member
Posted: Mon Jun 08, 2015 11:32 pm Post subject: |
Thanks for the replies. It sounds like the added height of the Zetec isn't creating undue headaches for anyone. My hoist legs added 7 - 8" of height to the WBX, with its big wheels and the box-tube sections. Putting the engine on cardboard and sliding it takes that extra height away and it all probably equals out.
61Scout, thanks for the concerns. You're right, I made it sound pretty dodgy. The jack stands are on plates of 3/4" OSB board that is performing fine, zero crush with flat, solid ground underneath. |
